Re: New GMF Project [message #551040 is a reply to message #548488] |
Wed, 04 August 2010 22:55 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Arto Jarvinen![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=arto.jarvinen%40gmail.com) Messages: 32 Registered: May 2010 Location: Sweden |
Member |
I installed the DSL Toolkit which has a wizard for creating a DSL project. Not sure if it is what you want but afaik GMF is a subset of the the DSL Toolkit. I'm also a n00b still but I did manage to create my first simple class diagram editor for an Ecore model. The tutorial you are referring to is not entirely correct I think. I'm having problems with the layout example in part 3 for instance. -A
Edit: Or, you could add (install) the Modeling components to the basic Helios release and you'll have your wizard. I'll need to see if some of my issues are perhaps solved in this version...
Blog: http://www.ostrogothia.com/process/
[Updated on: Wed, 04 August 2010 23:19] Report message to a moderator
FUDForum. Page generated in 0.02786 seconds
