Home » Eclipse Projects » Mylyn » How to make my HttpSender visible?
How to make my HttpSender visible? [message #55208] Tue, 05 August 2008 10:17 Go to next message
Originally posted by: divis1969.mail.ru
I'm developing a Mylyn connector for my bug tracking system. It is using
SOAP, so I decided to use a Jira connector as an example.
I've added 2 plugins (core and ui) and can create a repository. Now I'm
trying to retrieve some data from the server.
The problem is MyHttpSender class that is not visible to an Axis when I
debug my plugins. This class is based on CommonsHttpSender (the copy from
Jira's one) and is declared in client-config.wsdd:
<transport name="http" pivot="java:com.myconnector.core.MyHttpSender" />
For some reason it is not known for Axis:
org.apache.axis.ConfigurationException: java.lang.ClassNotFoundException:
java.lang.ClassNotFoundException: com.myconnector.core.MyHttpSender
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:481)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:397)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:385)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:87)
at org.apache.axis.utils.ClassUtils$2.run(ClassUtils.java:187)
at org.apache.axis.utils.ClassUtils.loadClass(ClassUtils.java:1 60)
at org.apache.axis.utils.ClassUtils.forName(ClassUtils.java:100 )
org.apache.axis.deployment.wsdd.WSDDTargetedChain.makeNewIns tance(WSDDTargetedChain.java:157)
I did not find any specific configuration in Jira plugin, so I suppose
this can be fixed with debug configuration. I've tried to add a path to my
class to CLASSPATH variable, but it does not work.
So, I would appreciate any advice how to fix this.
Dmitry
Re: How to make my HttpSender visible? [message #55264 is a reply to message #55208] Tue, 05 August 2008 16:37 Go to previous messageGo to next message
The classloader of the Axis bundle can not see your class. Add this line to
the MANIFEST.MF plug-in of your connector:
Eclipse-RegisterBuddy: org.apache.axis
This will enable the org.apache.axis bundle to load your class.
Steffen
Dmitry Smirnov wrote:
> at
> at
> at
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at java.security.AccessController.doPrivileged(Native Method)
> at
> Dmitry
Re: How to make my HttpSender visible? [message #55291 is a reply to message #55264] Wed, 06 August 2008 08:44 Go to previous messageGo to next message
Thank you! This works fine.
Dmitry
Re: How to make my HttpSender visible? [message #55345 is a reply to message #55264] Wed, 06 August 2008 14:52 Go to previous messageGo to next message
And check here which explains the whole procedure:
Andi
> Steffen
Re: How to make my HttpSender visible? [message #55372 is a reply to message #55264] Wed, 06 August 2008 14:52 Go to previous message
http://www.eclipsezone.com/articles/eclipse-vms/
Andi
> Steffen
Re: How to make my HttpSender visible? [message #592173 is a reply to message #55208] Tue, 05 August 2008 16:37 Go to previous message
Steffen
> at
> at
> at
> at
> at
> Dmitry
Re: How to make my HttpSender visible? [message #592193 is a reply to message #55264] Wed, 06 August 2008 08:44 Go to previous message
Dmitry
Re: How to make my HttpSender visible? [message #592219 is a reply to message #55264] Wed, 06 August 2008 14:52 Go to previous message
Andi
> Steffen
Re: How to make my HttpSender visible? [message #592223 is a reply to message #55264] Wed, 06 August 2008 14:52 Go to previous message
Andi
> Steffen
Previous Topic:Include Web connector into the update side?
Next Topic:Database Table as Context
Current Time: Sat Jul 19 03:22:10 EDT 2025
Powered by FUDForum. Page generated in 0.04783 seconds
