Home » Modeling » M2T (model-to-text transformation) » JET: user regions and iterators
JET: user regions and iterators [message #55098] Fri, 09 January 2009 08:29 Go to next message
Originally posted by: johannes.nel.gmail.com
HI All
First off,is there a more appropriate list for JET?
When adding several user regions (with or without uniqueUnmodified
markers), I notice that in iterators it goes all weird.
For exmaple:
if I have a class
package
//user region @imports
class
//user region @variables
constructer{
//user region @constructer
//iterator
void {curItem/@name}{
//user region @{curItem/@name}generated
//end-iterator
so when i regenerate it the changes I made (and i do remove my generated
markers) inside the functions declared by the iterator is a repeat of
what i have in the @constructer tag.
this also failed without the uniqueUnmodified marker, same behaviour.
is this expected behaviour, and if so can someone give me a heads up on
how they work, else what am I doing wrong?
Johan
Re: user regions and iterators [message #55203 is a reply to message #55098] Mon, 12 January 2009 09:54 Go to previous messageGo to next message
Johan:
"Johannes Nel" <johannes.nel@gmail.com> wrote in message
news:gk7jff$jjm$1@build.eclipse.org...
> HI All
This is the correct place. It is shared between JET, XPand and MTL. Putting
JET somewhere in the subject line gets my attention faster. And, I've just
been slow getting back into things after the new year...
> markers), I notice that in iterators it goes all weird....
What is the text between the <c:userRegion> and the <c:initialCode> tag?
This is the text that JET searches for (literally - case and whitespace
matter).
Also, what JET version are you using? I have vague memories of breaking
something in the 0.8 stream which was subsequently fixed (with considerable
embarrassment).
Paul
Re: user regions and iterators [message #55228 is a reply to message #55203] Mon, 12 January 2009 10:02 Go to previous message
Hi Paul,
I use 0.9.1 08/08/01 build (Standard with the modeling edition of Ganymede).
The text in the user regions can be nothing, what the user created, or
optional code i only wish to insert if the generation marker is restored.
I make certain not to have user regions inside others, but as i said
iterators muck it up.
I am generating unit test and class shells from interfaces.
Paul Elder wrote:
> Johan:
>> HI All
> matter).
> embarrassment).
> Paul
Previous Topic:JET, custom XPAth function and iterating through the nodes which get passed in.
Next Topic:Formatting jet-generated java sources according to Eclipse formatting rules ?
Current Time: Sun Jul 13 19:46:34 EDT 2025
Powered by FUDForum. Page generated in 0.07741 seconds
