Home » Eclipse Projects » GEF » Logic Example I20030114 is broken under Linux
Logic Example I20030114 is broken under Linux [message #55097] Wed, 15 January 2003 11:24 Go to next message
Originally posted by: yannick_s.gmx.de
the Logic Example I20030114 can't be compiled at least under Linux/Motif
because of 2 errors in LogicLabelEditManager.java:
Lines 54 and 56: the code references directly the field FontData.height
which is Windows specific and doesn't exist under SWT/Motif.
Can anybody fix the problem in CVS: use the getter/setter instead of the
field.
Thank you,
Yannick
Re: Logic Example I20030114 is broken under Linux [message #55124 is a reply to message #55097] Wed, 15 January 2003 12:21 Go to previous message
Thanks for pointing that out. I fixed and released that class. Tomorrow's build should be okay.
Yannick Saillet wrote:
> field.
> Thank you,
> Yannick
Previous Topic:Connection and it's Labels
Next Topic:Problems in running latest GEF and Logic Editor Example I20030114 on Eclipse I20030114
Current Time: Sun Jul 13 00:37:56 EDT 2025
Powered by FUDForum. Page generated in 0.02609 seconds
