Home » Archived » M2M (model-to-model transformation) » New ATL use case: Models Measurement
New ATL use case: Models Measurement [message #55094] Fri, 27 July 2007 09:06 Go to next message
Dear all,
A new ATL use case is available: Models Measurement
This use case shows how to compute and generate measures on models, and
how to display them in different way. This use case is composed of two
main parts and is the continuation of this work:
http://www.sciences.univ-nantes.fr/lina/atl/www/papers/Measu ringModelRepositories.pdf.
The first step is the measurement process. Metrics are implemented for
KM3 metamodel or UML2 models using metric sets found in the literature [1].
The second step is the presentation process. The computed metrics can be
displayed in 3 different representations: Tabular HTML, SVG Bar Chart,
and SVG Pie Chart.
The use case is available at:
http://www.eclipse.org/m2m/atl/usecases/ModelsMeasurement/
As a complementary application to this contribution, an online service
is provided at SODIUS's web site under the name "MC-Meter". The
application offers you to freely measure your models and get a report on
them, using the Open Source contribution. The input models can be KM3
metamodels and UML2 models, and the report is sent back by email, using
HTML format. Sample of inputs and reports are available on the service page.
The online measurement service is available at:
http://www.mdworkbench.com/measuring.php
A complete list of implemented metrics is available at:
http://www.mdworkbench.com/measurement/metrics/definition.ht m
[1] Baroni, A.L.: Formal Definition of Object-Oriented Design Metrics.
Master Thesis, Vrije University, Brussel, Belgium, 2002.
Éric Vépa
SODIUS
6, rue de la Cornouaille - BP 91941
44319 Nantes, France
Email: evepa@sodius.com
www.mdworkbench.com
Draw more value from your models
Re: [ATL] New ATL use case: Models Measurement [message #55179 is a reply to message #55094] Sat, 28 July 2007 17:54 Go to previous messageGo to next message
Dear all,
The Web Service (http://www.mdworkbench.com/measuring.php) is
unavailable at this time (network maintenance of the server which
processed the request).
I will post here when it will come back to the normal (probably Monday,
during the afternoon).
Éric Vépa wrote:
> Dear all,
> and SVG Pie Chart.
> page.
Éric Vépa
SODIUS
www.mdworkbench.com
Re: [ATL] New ATL use case: Models Measurement [message #55290 is a reply to message #55179] Mon, 30 July 2007 08:09 Go to previous messageGo to next message
Hi all,
The Web service is back to the normal.
Sorry for the inconvenience.
Éric Vépa wrote:
> Dear all,
> Éric Vépa wrote:
>> Dear all,
>> and SVG Pie Chart.
>> page.
Éric Vépa
SODIUS
www.mdworkbench.com
[ATL][Update] ATL use case: Models Measurement [message #60025 is a reply to message #55094] Thu, 30 August 2007 12:56 Go to previous message
Dear all,
An update of the ATL use case Models Measurement is available at:
The measurement online service has also been updated at:
This use case now uses ATL 2.0RC2 and the new UML2 model handler.
The XHTML presentation used in the online service is now included in the
use case. This presentation is now interactive and you can emphasize the
values of metrics by setting a predicate in the input text on top of
each column.
If you want to try this interactive feature, complete samples of XHTML
presentation can be found on the online service page.
And thanks to the new UML2 model handler, any UML model in version 2.1
can be processed (profiled models are now supported even if no metric is
implemented on it).
All the transformations of this use case, are also available
independently in the ATL Transformations Zoo at:
http://www.eclipse.org/m2m/atl/atlTransformations/
Have fun !
Éric Vépa wrote:
> Dear all,
> and SVG Pie Chart.
> page.
Éric Vépa
SODIUS
www.mdworkbench.com
Previous Topic:[ATL] .asm not generated after install of ATL 2.0RC2
Next Topic:[ATL] comparaison of ATL with other transformation languages
Current Time: Sun Aug 31 21:25:40 EDT 2025
Powered by FUDForum. Page generated in 0.25573 seconds
