Home » Language IDEs » PHP Development Tools (PDT) » "waiting for XDebug session" problem
"waiting for XDebug session" problem [message #55058] Wed, 26 September 2007 09:16 Go to next message
Originally posted by: ad.tis-net.de
I'm getting some problems, trying to get xdebug to work. My system is:
OS : Windows Vista(32 Bit)
Apache : 2.2.4
PHP : 5.2.4
eclipse : 3.3.0
PDT : 1.0.0v20070917 (last version)
xdebug : php_xdebug-2.0.0-5.2.2.dll (last version)
I've renewed my workspace after updating PDT. And there is no problem
while loading php_xdebug_xxx.dll in apache - i can see in phpinfo()
output that it is properly loaded.
But after launching debug session it is stucking in the progress-view
while showing:
and nothing else happens. Does somebody has a clue about what's wrong?
Any help or hints will be appreciated.
Alex
Re: "waiting for XDebug session" problem [message #55095 is a reply to message #55058] Wed, 26 September 2007 11:03 Go to previous messageGo to next message
Have you looked at section 2.7.1 of
http://www.eclipse.org/pdt/documents/XDebugGuide.pdf
to see if that helps ?
Dave Kelsey
> Apache : 2.2.4
> PHP : 5.2.4
> eclipse : 3.3.0
> while showing:
> Cheers,
> Alex
Re: "waiting for XDebug session" problem [message #55121 is a reply to message #55095] Wed, 26 September 2007 11:31 Go to previous messageGo to next message
Thank you Dave,
Yes i have looked in and:
1. ini-File debug information should be correct(i used it on another
pc), but anyway here it is:
xdebug.remote_enable=1
xdebug.remote_host="127.0.0.1"
xdebug.remote_port=9000
xdebug.remote_handler="dbgp"
zend_extension_ts="c:\apache\php\ext\php_xdebug-2.0.0-5.2.2.dll "
xdebug.remote_log="c:\apache\logs\xdebug.log"
2. Windows-Firewall is disabled and i don't have another one.
3. Webserver is running, URL is correct.
Any other ideas?
> Dave Kelsey
>> Apache : 2.2.4
>> PHP : 5.2.4
>> eclipse : 3.3.0
>> while showing:
>> Cheers,
>> Alex
Re: "waiting for XDebug session" problem [message #55147 is a reply to message #55121] Wed, 26 September 2007 11:50 Go to previous messageGo to next message
try running a script via the web launch that does a phpinfo() and check
that xdebug loaded ok. the php engine invoked by apache uses a different
ini file to the one used by the command line so check to see which ini
file is used by that output as well.
Cheers
Dave Kelsey
Alex wrote:
> Thank you Dave,
> Any other ideas?
>> Dave Kelsey
>>> Apache : 2.2.4
>>> PHP : 5.2.4
>>> eclipse : 3.3.0
>>> while showing:
>>> Cheers,
>>> Alex
Re: "waiting for XDebug session" problem [message #55312 is a reply to message #55147] Thu, 27 September 2007 03:13 Go to previous messageGo to next message
Yes i tried it already and xdebug is running:
http://www.imagehosting.com/show.php/1186148_screen.jpg.html
> Cheers
> Dave Kelsey
> Alex wrote:
>> Thank you Dave,
>> Any other ideas?
>>> Dave Kelsey
>>>> Apache : 2.2.4
>>>> PHP : 5.2.4
>>>> eclipse : 3.3.0
>>>> progress-view while showing:
>>>> Cheers,
>>>> Alex
Re: "waiting for XDebug session" problem [message #55366 is a reply to message #55312] Thu, 27 September 2007 05:28 Go to previous messageGo to next message
Hi Alex, would it be possible to post a complete text version of the phpinfo() output ?
Cheers
Dave Kelsey
>> Cheers
>> Dave Kelsey
>> Alex wrote:
>>> Thank you Dave,
>>> Any other ideas?
>>>> Dave Kelsey
>>>>> Apache : 2.2.4
>>>>> PHP : 5.2.4
>>>>> eclipse : 3.3.0
>>>>> Cheers,
>>>>> Alex
Re: "waiting for XDebug session" problem [message #55393 is a reply to message #55312] Thu, 27 September 2007 05:34 Go to previous messageGo to next message
Just to be sure, you don't have the old xdebug plug-ins installed ? You should
only have the launches "PHP Script" and "PHP Web Page", there shouldn't be any
ones which specifically say XDebug now (eg PHP Script with XDebug) ?
Dave Kelsey
>> Cheers
>> Dave Kelsey
>> Alex wrote:
>>> Thank you Dave,
>>> Any other ideas?
>>>> Dave Kelsey
>>>>> Apache : 2.2.4
>>>>> PHP : 5.2.4
>>>>> eclipse : 3.3.0
>>>>> Cheers,
>>>>> Alex
Re: "waiting for XDebug session" problem [message #55428 is a reply to message #55366] Thu, 27 September 2007 05:43 Go to previous messageGo to next message
--------------000103010608010705040804
Sure, see phpinfo.html in the attachment.
> phpinfo() output ?
> Cheers
> Dave Kelsey
>>> Cheers
>>> Dave Kelsey
>>> Alex wrote:
>>>> Thank you Dave,
>>>> Any other ideas?
>>>>> Dave Kelsey
>>>>>> is:
>>>>>> Apache : 2.2.4
>>>>>> PHP : 5.2.4
>>>>>> eclipse : 3.3.0
>>>>>> wrong?
>>>>>> Cheers,
>>>>>> Alex
Content-Type: text/html;
name="phpinfo.html"
Content-Disposition: inline;
filename="phpinfo.html"
PCFET0NUWVBFIGh0bWwgUFVCTElDICItLy9XM0MvL0RURCBYSFRNTCAxLjAg VHJhbnNpdGlv
bmFsLy9FTiIgIkRURC94aHRtbDEtdHJhbnNpdGlvbmFsLmR0ZCI+CjxodG1s PjxoZWFkPgo8
c3R5bGUgdHlwZT0idGV4dC9jc3MiPgpib2R5IHtiYWNrZ3JvdW5kLWNvbG9y OiAjZmZmZmZm
OyBjb2xvcjogIzAwMDAwMDt9CmJvZHksIHRkLCB0aCwgaDEsIGgyIHtmb250 LWZhbWlseTog
c2Fucy1zZXJpZjt9CnByZSB7bWFyZ2luOiAwcHg7IGZvbnQtZmFtaWx5OiBt b25vc3BhY2U7
fQphOmxpbmsge2NvbG9yOiAjMDAwMDk5OyB0ZXh0LWRlY29yYXRpb246IG5v bmU7IGJhY2tn
cm91bmQtY29sb3I6ICNmZmZmZmY7fQphOmhvdmVyIHt0ZXh0LWRlY29yYXRp b246IHVuZGVy
bGluZTt9CnRhYmxlIHtib3JkZXItY29sbGFwc2U6IGNvbGxhcHNlO30KLmNl bnRlciB7dGV4
dC1hbGlnbjogY2VudGVyO30KLmNlbnRlciB0YWJsZSB7IG1hcmdpbi1sZWZ0 OiBhdXRvOyBt
YXJnaW4tcmlnaHQ6IGF1dG87IHRleHQtYWxpZ246IGxlZnQ7fQouY2VudGVy IHRoIHsgdGV4
dC1hbGlnbjogY2VudGVyICFpbXBvcnRhbnQ7IH0KdGQsIHRoIHsgYm9yZGVy OiAxcHggc29s
aWQgIzAwMDAwMDsgZm9udC1zaXplOiA3NSU7IHZlcnRpY2FsLWFsaWduOiBi YXNlbGluZTt9
CmgxIHtmb250LXNpemU6IDE1MCU7fQpoMiB7Zm9udC1zaXplOiAxMjUlO30K LnAge3RleHQt
YWxpZ246IGxlZnQ7fQouZSB7YmFja2dyb3VuZC1jb2xvcjogI2NjY2NmZjsg Zm9udC13ZWln
aHQ6IGJvbGQ7IGNvbG9yOiAjMDAwMDAwO30KLmgge2JhY2tncm91bmQtY29s b3I6ICM5OTk5
Y2M7IGZvbnQtd2VpZ2h0OiBib2xkOyBjb2xvcjogIzAwMDAwMDt9Ci52IHti YWNrZ3JvdW5k
LWNvbG9yOiAjY2NjY2NjOyBjb2xvcjogIzAwMDAwMDt9Ci52ciB7YmFja2dy b3VuZC1jb2xv
cjogI2NjY2NjYzsgdGV4dC1hbGlnbjogcmlnaHQ7IGNvbG9yOiAjMDAwMDAw O30KaW1nIHtm
bG9hdDogcmlnaHQ7IGJvcmRlcjogMHB4O30KaHIge3dpZHRoOiA2MDBweDsg YmFja2dyb3Vu
ZC1jb2xvcjogI2NjY2NjYzsgYm9yZGVyOiAwcHg7IGhlaWdodDogMXB4OyBj b2xvcjogIzAw
MDAwMDt9Cjwvc3R5bGU+Cjx0aXRsZT5waHBpbmZvKCk8L3RpdGxlPjxtZXRh IG5hbWU9IlJP
Qk9UUyIgY29udGVudD0iTk9JTkRFWCxOT0ZPTExPVyxOT0FSQ0hJVkUiIC8+ PC9oZWFkPgo8
Ym9keT48ZGl2IGNsYXNzPSJjZW50ZXIiPgo8dGFibGUgYm9yZGVyPSIwIiBj ZWxscGFkZGlu
Zz0iMyIgd2lkdGg9IjYwMCI+Cjx0ciBjbGFzcz0iaCI+PHRkPgo8YSBocmVm PSJodHRwOi8v
d3d3LnBocC5uZXQvIj48aW1nIGJvcmRlcj0iMCIgc3JjPSIvcGhwaW5mby5w aHA/PVBIUEU5
NTY4RjM0LUQ0MjgtMTFkMi1BNzY5LTAwQUEwMDFBQ0Y0MiIgYWx0PSJQSFAg TG9nbyIgLz48
L2E+PGgxIGNsYXNzPSJwIj5QSFAgVmVyc2lvbiA1LjIuNDwvaDE+CjwvdGQ+ PC90cj4KPC90
YWJsZT48YnIgLz4KPHRhYmxlIGJvcmRlcj0iMCIgY2VsbHBhZGRpbmc9IjMi IHdpZHRoPSI2
MDAiPgo8dHI+PHRkIGNsYXNzPSJlIj5TeXN0ZW0gPC90ZD48dGQgY2xhc3M9 InYiPldpbmRv
d3MgTlQgTUFEQk9PSyA2LjAgYnVpbGQgNjAwMCA8L3RkPjwvdHI+Cjx0cj48 dGQgY2xhc3M9
ImUiPkJ1aWxkIERhdGUgPC90ZD48dGQgY2xhc3M9InYiPkF1ZyAzMCAyMDA3 IDA3OjA1OjQ4
IDwvdGQ+PC90cj4KPHRyPjx0ZCBjbGFzcz0iZSI+Q29uZmlndXJlIENvbW1h bmQgPC90ZD48
dGQgY2xhc3M9InYiPmNzY3JpcHQgL25vbG9nbyBjb25maWd1cmUuanMgICZx dW90Oy0tZW5h
YmxlLXNuYXBzaG90LWJ1aWxkJnF1b3Q7ICZxdW90Oy0td2l0aC1nZD1zaGFy ZWQmcXVvdDsg
PC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj5TZXJ2ZXIgQVBJIDwvdGQ+ PHRkIGNsYXNz
PSJ2Ij5BcGFjaGUgMi4wIEhhbmRsZXIgPC90ZD48L3RyPgo8dHI+PHRkIGNs YXNzPSJlIj5W
aXJ0dWFsIERpcmVjdG9yeSBTdXBwb3J0IDwvdGQ+PHRkIGNsYXNzPSJ2Ij5l bmFibGVkIDwv
dGQ+PC90cj4KPHRyPjx0ZCBjbGFzcz0iZSI+Q29uZmlndXJhdGlvbiBGaWxl IChwaHAuaW5p
KSBQYXRoIDwvdGQ+PHRkIGNsYXNzPSJ2Ij5DOlxXaW5kb3dzIDwvdGQ+PC90 cj4KPHRyPjx0
ZCBjbGFzcz0iZSI+TG9hZGVkIENvbmZpZ3VyYXRpb24gRmlsZSA8L3RkPjx0 ZCBjbGFzcz0i
diI+QzpcYXBhY2hlXHBocFxwaHAuaW5pIDwvdGQ+PC90cj4KPHRyPjx0ZCBj bGFzcz0iZSI+
UEhQIEFQSSA8L3RkPjx0ZCBjbGFzcz0idiI+MjAwNDEyMjUgPC90ZD48L3Ry Pgo8dHI+PHRk
IGNsYXNzPSJlIj5QSFAgRXh0ZW5zaW9uIDwvdGQ+PHRkIGNsYXNzPSJ2Ij4y MDA2MDYxMyA8
L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPlplbmQgRXh0ZW5zaW9uIDwv dGQ+PHRkIGNs
YXNzPSJ2Ij4yMjAwNjA1MTkgPC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJl Ij5EZWJ1ZyBC
dWlsZCA8L3RkPjx0ZCBjbGFzcz0idiI+bm8gPC90ZD48L3RyPgo8dHI+PHRk IGNsYXNzPSJl
Ij5UaHJlYWQgU2FmZXR5IDwvdGQ+PHRkIGNsYXNzPSJ2Ij5lbmFibGVkIDwv dGQ+PC90cj4K
PHRyPjx0ZCBjbGFzcz0iZSI+WmVuZCBNZW1vcnkgTWFuYWdlciA8L3RkPjx0 ZCBjbGFzcz0i
diI+ZW5hYmxlZCA8L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPklQdjYg U3VwcG9ydCA8
L3RkPjx0ZCBjbGFzcz0idiI+ZW5hYmxlZCA8L3RkPjwvdHI+Cjx0cj48dGQg Y2xhc3M9ImUi
PlJlZ2lzdGVyZWQgUEhQIFN0cmVhbXMgPC90ZD48dGQgY2xhc3M9InYiPnBo cCwgZmlsZSwg
ZGF0YSwgaHR0cCwgZnRwLCBjb21wcmVzcy56bGliICAgPC90ZD48L3RyPgo8 dHI+PHRkIGNs
YXNzPSJlIj5SZWdpc3RlcmVkIFN0cmVhbSBTb2NrZXQgVHJhbnNwb3J0cyA8 L3RkPjx0ZCBj
bGFzcz0idiI+dGNwLCB1ZHAgPC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJl Ij5SZWdpc3Rl
cmVkIFN0cmVhbSBGaWx0ZXJzIDwvdGQ+PHRkIGNsYXNzPSJ2Ij5jb252ZXJ0 Lmljb252Lios
IHN0cmluZy5yb3QxMywgc3RyaW5nLnRvdXBwZXIsIHN0cmluZy50b2xvd2Vy LCBzdHJpbmcu
c3RyaXBfdGFncywgY29udmVydC4qLCBjb25zdW1lZCwgemxpYi4qIDwvdGQ+ PC90cj4KPC90
MDAiPgo8dHIgY2xhc3M9InYiPjx0ZD4KPGEgaHJlZj0iaHR0cDovL3d3dy56 ZW5kLmNvbS8i
PjxpbWcgYm9yZGVyPSIwIiBzcmM9Ii9waHBpbmZvLnBocD89UEhQRTk1NjhG MzUtRDQyOC0x
MWQyLUE3NjktMDBBQTAwMUFDRjQyIiBhbHQ9IlplbmQgbG9nbyIgLz48L2E+ ClRoaXMgcHJv
Z3JhbSBtYWtlcyB1c2Ugb2YgdGhlIFplbmQgU2NyaXB0aW5nIExhbmd1YWdl IEVuZ2luZTo8
YnIgLz5aZW5kJm5ic3A7RW5naW5lJm5ic3A7djIuMi4wLCZuYnNwO0NvcHly aWdodCZuYnNw
OyhjKSZuYnNwOzE5OTgtMjAwNyZuYnNwO1plbmQmbmJzcDtUZWNobm9sb2dp ZXM8YnIgLz4m
bmJzcDsmbmJzcDsmbmJzcDsmbmJzcDt3aXRoJm5ic3A7WGRlYnVnJm5ic3A7 djIuMC4wLCZu
YnNwO0NvcHlyaWdodCZuYnNwOyhjKSZuYnNwOzIwMDIsJm5ic3A7MjAwMywm bmJzcDsyMDA0
LCZuYnNwOzIwMDUsJm5ic3A7MjAwNiwmbmJzcDsyMDA3LCZuYnNwO2J5Jm5i c3A7RGVyaWNr
Jm5ic3A7UmV0aGFuczxiciAvPjwvdGQ+PC90cj4KPC90YWJsZT48YnIgLz4K PGhyIC8+Cjxo
MT48YSBocmVmPSIvcGhwaW5mby5waHA/PVBIUEI4QjVGMkEwLTNDOTItMTFk My1BM0E5LTRD
N0IwOEMxMDAwMCI+UEhQIENyZWRpdHM8L2E+PC9oMT4KPGhyIC8+CjxoMT5D b25maWd1cmF0
aW9uPC9oMT4KPGgyPlBIUCBDb3JlPC9oMj4KPHRhYmxlIGJvcmRlcj0iMCIg Y2VsbHBhZGRp
bmc9IjMiIHdpZHRoPSI2MDAiPgo8dHIgY2xhc3M9ImgiPjx0aD5EaXJlY3Rp dmU8L3RoPjx0
aD5Mb2NhbCBWYWx1ZTwvdGg+PHRoPk1hc3RlciBWYWx1ZTwvdGg+PC90cj4K PHRyPjx0ZCBj
bGFzcz0iZSI+YWxsb3dfY2FsbF90aW1lX3Bhc3NfcmVmZXJlbmNlPC90ZD48 dGQgY2xhc3M9
InYiPk9mZjwvdGQ+PHRkIGNsYXNzPSJ2Ij5PZmY8L3RkPjwvdHI+Cjx0cj48 dGQgY2xhc3M9
ImUiPmFsbG93X3VybF9mb3BlbjwvdGQ+PHRkIGNsYXNzPSJ2Ij5PbjwvdGQ+ PHRkIGNsYXNz
PSJ2Ij5PbjwvdGQ+PC90cj4KPHRyPjx0ZCBjbGFzcz0iZSI+YWxsb3dfdXJs X2luY2x1ZGU8
L3RkPjx0ZCBjbGFzcz0idiI+T2ZmPC90ZD48dGQgY2xhc3M9InYiPk9mZjwv dGQ+PC90cj4K
PHRyPjx0ZCBjbGFzcz0iZSI+YWx3YXlzX3BvcHVsYXRlX3Jhd19wb3N0X2Rh dGE8L3RkPjx0
ZCBjbGFzcz0idiI+T2ZmPC90ZD48dGQgY2xhc3M9InYiPk9mZjwvdGQ+PC90 cj4KPHRyPjx0
ZCBjbGFzcz0iZSI+YXJnX3NlcGFyYXRvci5pbnB1dDwvdGQ+PHRkIGNsYXNz PSJ2Ij4mYW1w
OzwvdGQ+PHRkIGNsYXNzPSJ2Ij4mYW1wOzwvdGQ+PC90cj4KPHRyPjx0ZCBj bGFzcz0iZSI+
YXJnX3NlcGFyYXRvci5vdXRwdXQ8L3RkPjx0ZCBjbGFzcz0idiI+JmFtcDs8 L3RkPjx0ZCBj
bGFzcz0idiI+JmFtcDs8L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPmFz cF90YWdzPC90
ZD48dGQgY2xhc3M9InYiPk9mZjwvdGQ+PHRkIGNsYXNzPSJ2Ij5PZmY8L3Rk PjwvdHI+Cjx0
cj48dGQgY2xhc3M9ImUiPmF1dG9fYXBwZW5kX2ZpbGU8L3RkPjx0ZCBjbGFz cz0idiI+PGk+
bm8gdmFsdWU8L2k+PC90ZD48dGQgY2xhc3M9InYiPjxpPm5vIHZhbHVlPC9p PjwvdGQ+PC90
cj4KPHRyPjx0ZCBjbGFzcz0iZSI+YXV0b19nbG9iYWxzX2ppdDwvdGQ+PHRk IGNsYXNzPSJ2
Ij5PbjwvdGQ+PHRkIGNsYXNzPSJ2Ij5PbjwvdGQ+PC90cj4KPHRyPjx0ZCBj bGFzcz0iZSI+
YXV0b19wcmVwZW5kX2ZpbGU8L3RkPjx0ZCBjbGFzcz0idiI+PGk+bm8gdmFs dWU8L2k+PC90
ZD48dGQgY2xhc3M9InYiPjxpPm5vIHZhbHVlPC9pPjwvdGQ+PC90cj4KPHRy Pjx0ZCBjbGFz
cz0iZSI+YnJvd3NjYXA8L3RkPjx0ZCBjbGFzcz0idiI+PGk+bm8gdmFsdWU8 L2k+PC90ZD48
dGQgY2xhc3M9InYiPjxpPm5vIHZhbHVlPC9pPjwvdGQ+PC90cj4KPHRyPjx0 ZCBjbGFzcz0i
ZSI+ZGVmYXVsdF9jaGFyc2V0PC90ZD48dGQgY2xhc3M9InYiPjxpPm5vIHZh bHVlPC9pPjwv
dGQ+PHRkIGNsYXNzPSJ2Ij48aT5ubyB2YWx1ZTwvaT48L3RkPjwvdHI+Cjx0 cj48dGQgY2xh
c3M9ImUiPmRlZmF1bHRfbWltZXR5cGU8L3RkPjx0ZCBjbGFzcz0idiI+dGV4 dC9odG1sPC90
ZD48dGQgY2xhc3M9InYiPnRleHQvaHRtbDwvdGQ+PC90cj4KPHRyPjx0ZCBj bGFzcz0iZSI+
ZGVmaW5lX3N5c2xvZ192YXJpYWJsZXM8L3RkPjx0ZCBjbGFzcz0idiI+T2Zm PC90ZD48dGQg
Y2xhc3M9InYiPk9mZjwvdGQ+PC90cj4KPHRyPjx0ZCBjbGFzcz0iZSI+ZGlz YWJsZV9jbGFz
c2VzPC90ZD48dGQgY2xhc3M9InYiPjxpPm5vIHZhbHVlPC9pPjwvdGQ+PHRk IGNsYXNzPSJ2
Ij48aT5ubyB2YWx1ZTwvaT48L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUi PmRpc2FibGVf
ZnVuY3Rpb25zPC90ZD48dGQgY2xhc3M9InYiPjxpPm5vIHZhbHVlPC9pPjwv dGQ+PHRkIGNs
YXNzPSJ2Ij48aT5ubyB2YWx1ZTwvaT48L3RkPjwvdHI+Cjx0cj48dGQgY2xh c3M9ImUiPmRp
c3BsYXlfZXJyb3JzPC90ZD48dGQgY2xhc3M9InYiPk9mZjwvdGQ+PHRkIGNs YXNzPSJ2Ij5P
ZmY8L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPmRpc3BsYXlfc3RhcnR1 cF9lcnJvcnM8
PHRyPjx0ZCBjbGFzcz0iZSI+ZG9jX3Jvb3Q8L3RkPjx0ZCBjbGFzcz0idiI+ PGk+bm8gdmFs
dWU8L2k+PC90ZD48dGQgY2xhc3M9InYiPjxpPm5vIHZhbHVlPC9pPjwvdGQ+ PC90cj4KPHRy
Pjx0ZCBjbGFzcz0iZSI+ZG9jcmVmX2V4dDwvdGQ+PHRkIGNsYXNzPSJ2Ij48 aT5ubyB2YWx1
ZTwvaT48L3RkPjx0ZCBjbGFzcz0idiI+PGk+bm8gdmFsdWU8L2k+PC90ZD48 L3RyPgo8dHI+
PHRkIGNsYXNzPSJlIj5kb2NyZWZfcm9vdDwvdGQ+PHRkIGNsYXNzPSJ2Ij48 aT5ubyB2YWx1
PHRkIGNsYXNzPSJlIj5lbmFibGVfZGw8L3RkPjx0ZCBjbGFzcz0idiI+T248 L3RkPjx0ZCBj
bGFzcz0idiI+T248L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPmVycm9y X2FwcGVuZF9z
dHJpbmc8L3RkPjx0ZCBjbGFzcz0idiI+PGk+bm8gdmFsdWU8L2k+PC90ZD48 dGQgY2xhc3M9
InYiPjxpPm5vIHZhbHVlPC9pPjwvdGQ+PC90cj4KPHRyPjx0ZCBjbGFzcz0i ZSI+ZXJyb3Jf
bG9nPC90ZD48dGQgY2xhc3M9InYiPi4uXGxvZ3NccGhwLmxvZzwvdGQ+PHRk IGNsYXNzPSJ2
Ij4uLlxsb2dzXHBocC5sb2c8L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUi PmVycm9yX3By
ZXBlbmRfc3RyaW5nPC90ZD48dGQgY2xhc3M9InYiPjxpPm5vIHZhbHVlPC9p PjwvdGQ+PHRk
IGNsYXNzPSJ2Ij48aT5ubyB2YWx1ZTwvaT48L3RkPjwvdHI+Cjx0cj48dGQg Y2xhc3M9ImUi
PmVycm9yX3JlcG9ydGluZzwvdGQ+PHRkIGNsYXNzPSJ2Ij42MTQzPC90ZD48 dGQgY2xhc3M9
InYiPjYxNDM8L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPmV4cG9zZV9w aHA8L3RkPjx0
ZCBjbGFzcz0idiI+T248L3RkPjx0ZCBjbGFzcz0idiI+T248L3RkPjwvdHI+ Cjx0cj48dGQg
Y2xhc3M9ImUiPmV4dGVuc2lvbl9kaXI8L3RkPjx0ZCBjbGFzcz0idiI+Yzpc YXBhY2hlXHBo
cFxleHRcPC90ZD48dGQgY2xhc3M9InYiPmM6XGFwYWNoZVxwaHBcZXh0XDwv dGQ+PC90cj4K
PHRyPjx0ZCBjbGFzcz0iZSI+ZmlsZV91cGxvYWRzPC90ZD48dGQgY2xhc3M9 InYiPk9uPC90
ZD48dGQgY2xhc3M9InYiPk9uPC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJl Ij5oaWdobGln
aHQuYmc8L3RkPjx0ZCBjbGFzcz0idiI+PGZvbnQgc3R5bGU9ImNvbG9yOiAj RkZGRkZGIj4j
RkZGRkZGPC9mb250PjwvdGQ+PHRkIGNsYXNzPSJ2Ij48Zm9udCBzdHlsZT0i Y29sb3I6ICNG
RkZGRkYiPiNGRkZGRkY8L2ZvbnQ+PC90ZD48L3RyPgo8dHI+PHRkIGNsYXNz PSJlIj5oaWdo
bGlnaHQuY29tbWVudDwvdGQ+PHRkIGNsYXNzPSJ2Ij48Zm9udCBzdHlsZT0i Y29sb3I6ICNG
RjgwMDAiPiNGRjgwMDA8L2ZvbnQ+PC90ZD48dGQgY2xhc3M9InYiPjxmb250 IHN0eWxlPSJj
b2xvcjogI0ZGODAwMCI+I0ZGODAwMDwvZm9udD48L3RkPjwvdHI+Cjx0cj48 dGQgY2xhc3M9
ImUiPmhpZ2hsaWdodC5kZWZhdWx0PC90ZD48dGQgY2xhc3M9InYiPjxmb250 IHN0eWxlPSJj
b2xvcjogIzAwMDBCQiI+IzAwMDBCQjwvZm9udD48L3RkPjx0ZCBjbGFzcz0i diI+PGZvbnQg
c3R5bGU9ImNvbG9yOiAjMDAwMEJCIj4jMDAwMEJCPC9mb250PjwvdGQ+PC90 cj4KPHRyPjx0
ZCBjbGFzcz0iZSI+aGlnaGxpZ2h0Lmh0bWw8L3RkPjx0ZCBjbGFzcz0idiI+ PGZvbnQgc3R5
bGU9ImNvbG9yOiAjMDAwMDAwIj4jMDAwMDAwPC9mb250PjwvdGQ+PHRkIGNs YXNzPSJ2Ij48
Zm9udCBzdHlsZT0iY29sb3I6ICMwMDAwMDAiPiMwMDAwMDA8L2ZvbnQ+PC90 ZD48L3RyPgo8
dHI+PHRkIGNsYXNzPSJlIj5oaWdobGlnaHQua2V5d29yZDwvdGQ+PHRkIGNs YXNzPSJ2Ij48
Zm9udCBzdHlsZT0iY29sb3I6ICMwMDc3MDAiPiMwMDc3MDA8L2ZvbnQ+PC90 ZD48dGQgY2xh
c3M9InYiPjxmb250IHN0eWxlPSJjb2xvcjogIzAwNzcwMCI+IzAwNzcwMDwv Zm9udD48L3Rk
PjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPmhpZ2hsaWdodC5zdHJpbmc8L3Rk Pjx0ZCBjbGFz
cz0idiI+PGZvbnQgc3R5bGU9ImNvbG9yOiAjREQwMDAwIj4jREQwMDAwPC9m b250PjwvdGQ+
PHRkIGNsYXNzPSJ2Ij48Zm9udCBzdHlsZT0iY29sb3I6ICNERDAwMDAiPiNE RDAwMDA8L2Zv
bnQ+PC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj5odG1sX2Vycm9yczwv dGQ+PHRkIGNs
YXNzPSJ2Ij5PbjwvdGQ+PHRkIGNsYXNzPSJ2Ij5PbjwvdGQ+PC90cj4KPHRy Pjx0ZCBjbGFz
cz0iZSI+aWdub3JlX3JlcGVhdGVkX2Vycm9yczwvdGQ+PHRkIGNsYXNzPSJ2 Ij5PZmY8L3Rk
Pjx0ZCBjbGFzcz0idiI+T2ZmPC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJl Ij5pZ25vcmVf
cmVwZWF0ZWRfc291cmNlPC90ZD48dGQgY2xhc3M9InYiPk9mZjwvdGQ+PHRk IGNsYXNzPSJ2
Ij5PZmY8L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPmlnbm9yZV91c2Vy X2Fib3J0PC90
cj48dGQgY2xhc3M9ImUiPmltcGxpY2l0X2ZsdXNoPC90ZD48dGQgY2xhc3M9 InYiPk9mZjwv
dGQ+PHRkIGNsYXNzPSJ2Ij5PZmY8L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9 ImUiPmluY2x1
ZGVfcGF0aDwvdGQ+PHRkIGNsYXNzPSJ2Ij4uO0M6XHBocDVccGVhcjwvdGQ+ PHRkIGNsYXNz
PSJ2Ij4uO0M6XHBocDVccGVhcjwvdGQ+PC90cj4KPHRyPjx0ZCBjbGFzcz0i ZSI+bG9nX2Vy
cm9yczwvdGQ+PHRkIGNsYXNzPSJ2Ij5PbjwvdGQ+PHRkIGNsYXNzPSJ2Ij5P bjwvdGQ+PC90
cj4KPHRyPjx0ZCBjbGFzcz0iZSI+bG9nX2Vycm9yc19tYXhfbGVuPC90ZD48 dGQgY2xhc3M9
InYiPjEwMjQ8L3RkPjx0ZCBjbGFzcz0idiI+MTAyNDwvdGQ+PC90cj4KPHRy Pjx0ZCBjbGFz
cz0iZSI+bWFnaWNfcXVvdGVzX2dwYzwvdGQ+PHRkIGNsYXNzPSJ2Ij5PZmY8 L3RkPjx0ZCBj
bGFzcz0idiI+T2ZmPC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj5tYWdp Y19xdW90ZXNf
cnVudGltZTwvdGQ+PHRkIGNsYXNzPSJ2Ij5PZmY8L3RkPjx0ZCBjbGFzcz0i diI+T2ZmPC90
ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj5tYWdpY19xdW90ZXNfc3liYXNl PC90ZD48dGQg
Y2xhc3M9InYiPk9mZjwvdGQ+PHRkIGNsYXNzPSJ2Ij5PZmY8L3RkPjwvdHI+ Cjx0cj48dGQg
Y2xhc3M9ImUiPm1haWwuZm9yY2VfZXh0cmFfcGFyYW1ldGVyczwvdGQ+PHRk IGNsYXNzPSJ2
Ij48aT5ubyB2YWx1ZTwvaT48L3RkPjx0ZCBjbGFzcz0idiI+PGk+bm8gdmFs dWU8L2k+PC90
ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj5tYXhfZXhlY3V0aW9uX3RpbWU8 L3RkPjx0ZCBj
bGFzcz0idiI+MzA8L3RkPjx0ZCBjbGFzcz0idiI+MzA8L3RkPjwvdHI+Cjx0 cj48dGQgY2xh
c3M9ImUiPm1heF9pbnB1dF9uZXN0aW5nX2xldmVsPC90ZD48dGQgY2xhc3M9 InYiPjY0PC90
ZD48dGQgY2xhc3M9InYiPjY0PC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJl Ij5tYXhfaW5w
dXRfdGltZTwvdGQ+PHRkIGNsYXNzPSJ2Ij42MDwvdGQ+PHRkIGNsYXNzPSJ2 Ij42MDwvdGQ+
PC90cj4KPHRyPjx0ZCBjbGFzcz0iZSI+bWVtb3J5X2xpbWl0PC90ZD48dGQg Y2xhc3M9InYi
PjEyOE08L3RkPjx0ZCBjbGFzcz0idiI+MTI4TTwvdGQ+PC90cj4KPHRyPjx0 ZCBjbGFzcz0i
ZSI+b3Blbl9iYXNlZGlyPC90ZD48dGQgY2xhc3M9InYiPjxpPm5vIHZhbHVl PC9pPjwvdGQ+
PHRkIGNsYXNzPSJ2Ij48aT5ubyB2YWx1ZTwvaT48L3RkPjwvdHI+Cjx0cj48 dGQgY2xhc3M9
ImUiPm91dHB1dF9idWZmZXJpbmc8L3RkPjx0ZCBjbGFzcz0idiI+MDwvdGQ+ PHRkIGNsYXNz
PSJ2Ij4wPC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj5vdXRwdXRfaGFu ZGxlcjwvdGQ+
PHRkIGNsYXNzPSJ2Ij48aT5ubyB2YWx1ZTwvaT48L3RkPjx0ZCBjbGFzcz0i diI+PGk+bm8g
dmFsdWU8L2k+PC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj5wb3N0X21h eF9zaXplPC90
ZD48dGQgY2xhc3M9InYiPjhNPC90ZD48dGQgY2xhc3M9InYiPjhNPC90ZD48 L3RyPgo8dHI+
PHRkIGNsYXNzPSJlIj5wcmVjaXNpb248L3RkPjx0ZCBjbGFzcz0idiI+MTQ8 L3RkPjx0ZCBj
bGFzcz0idiI+MTQ8L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPnJlYWxw YXRoX2NhY2hl
X3NpemU8L3RkPjx0ZCBjbGFzcz0idiI+MTZLPC90ZD48dGQgY2xhc3M9InYi PjE2SzwvdGQ+
PC90cj4KPHRyPjx0ZCBjbGFzcz0iZSI+cmVhbHBhdGhfY2FjaGVfdHRsPC90 ZD48dGQgY2xh
c3M9InYiPjEyMDwvdGQ+PHRkIGNsYXNzPSJ2Ij4xMjA8L3RkPjwvdHI+Cjx0 cj48dGQgY2xh
c3M9ImUiPnJlZ2lzdGVyX2FyZ2NfYXJndjwvdGQ+PHRkIGNsYXNzPSJ2Ij5P ZmY8L3RkPjx0
ZCBjbGFzcz0idiI+T2ZmPC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj5y ZWdpc3Rlcl9n
bG9iYWxzPC90ZD48dGQgY2xhc3M9InYiPk9uPC90ZD48dGQgY2xhc3M9InYi Pk9uPC90ZD48
L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj5yZWdpc3Rlcl9sb25nX2FycmF5czwv dGQ+PHRkIGNs
YXNzPSJ2Ij5PZmY8L3RkPjx0ZCBjbGFzcz0idiI+T2ZmPC90ZD48L3RyPgo8 dHI+PHRkIGNs
YXNzPSJlIj5yZXBvcnRfbWVtbGVha3M8L3RkPjx0ZCBjbGFzcz0idiI+T248 L3RkPjx0ZCBj
bGFzcz0idiI+T248L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPnJlcG9y dF96ZW5kX2Rl
YnVnPC90ZD48dGQgY2xhc3M9InYiPk9uPC90ZD48dGQgY2xhc3M9InYiPk9u PC90ZD48L3Ry
Pgo8dHI+PHRkIGNsYXNzPSJlIj5zYWZlX21vZGU8L3RkPjx0ZCBjbGFzcz0i diI+T2ZmPC90
ZD48dGQgY2xhc3M9InYiPk9mZjwvdGQ+PC90cj4KPHRyPjx0ZCBjbGFzcz0i ZSI+c2FmZV9t
b2RlX2V4ZWNfZGlyPC90ZD48dGQgY2xhc3M9InYiPjxpPm5vIHZhbHVlPC9p PjwvdGQ+PHRk
PnNhZmVfbW9kZV9naWQ8L3RkPjx0ZCBjbGFzcz0idiI+T2ZmPC90ZD48dGQg Y2xhc3M9InYi
Pk9mZjwvdGQ+PC90cj4KPHRyPjx0ZCBjbGFzcz0iZSI+c2FmZV9tb2RlX2lu Y2x1ZGVfZGly
PC90ZD48dGQgY2xhc3M9InYiPjxpPm5vIHZhbHVlPC9pPjwvdGQ+PHRkIGNs YXNzPSJ2Ij48
aT5ubyB2YWx1ZTwvaT48L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPnNl bmRtYWlsX2Zy
b208L3RkPjx0ZCBjbGFzcz0idiI+PGk+bm8gdmFsdWU8L2k+PC90ZD48dGQg Y2xhc3M9InYi
PjxpPm5vIHZhbHVlPC9pPjwvdGQ+PC90cj4KPHRyPjx0ZCBjbGFzcz0iZSI+ c2VuZG1haWxf
cGF0aDwvdGQ+PHRkIGNsYXNzPSJ2Ij48aT5ubyB2YWx1ZTwvaT48L3RkPjx0 ZCBjbGFzcz0i
diI+PGk+bm8gdmFsdWU8L2k+PC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJl Ij5zZXJpYWxp
emVfcHJlY2lzaW9uPC90ZD48dGQgY2xhc3M9InYiPjEwMDwvdGQ+PHRkIGNs YXNzPSJ2Ij4x
MDA8L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPnNob3J0X29wZW5fdGFn PC90ZD48dGQg
Y2xhc3M9ImUiPlNNVFA8L3RkPjx0ZCBjbGFzcz0idiI+bG9jYWxob3N0PC90 ZD48dGQgY2xh
c3M9InYiPmxvY2FsaG9zdDwvdGQ+PC90cj4KPHRyPjx0ZCBjbGFzcz0iZSI+ c210cF9wb3J0
PC90ZD48dGQgY2xhc3M9InYiPjI1PC90ZD48dGQgY2xhc3M9InYiPjI1PC90 ZD48L3RyPgo8
dHI+PHRkIGNsYXNzPSJlIj5zcWwuc2FmZV9tb2RlPC90ZD48dGQgY2xhc3M9 InYiPk9mZjwv
dGQ+PHRkIGNsYXNzPSJ2Ij5PZmY8L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9 ImUiPnRyYWNr
X2Vycm9yczwvdGQ+PHRkIGNsYXNzPSJ2Ij5PZmY8L3RkPjx0ZCBjbGFzcz0i diI+T2ZmPC90
ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj51bnNlcmlhbGl6ZV9jYWxsYmFj a19mdW5jPC90
ZD48dGQgY2xhc3M9InYiPjxpPm5vIHZhbHVlPC9pPjwvdGQ+PHRkIGNsYXNz PSJ2Ij48aT5u
byB2YWx1ZTwvaT48L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPnVwbG9h ZF9tYXhfZmls
ZXNpemU8L3RkPjx0ZCBjbGFzcz0idiI+Mk08L3RkPjx0ZCBjbGFzcz0idiI+ Mk08L3RkPjwv
dHI+Cjx0cj48dGQgY2xhc3M9ImUiPnVwbG9hZF90bXBfZGlyPC90ZD48dGQg Y2xhc3M9InYi
PmM6XGFwYWNoZVxwaHBcdGVtcFx1cGxvYWRcPC90ZD48dGQgY2xhc3M9InYi PmM6XGFwYWNo
ZVxwaHBcdGVtcFx1cGxvYWRcPC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJl Ij51c2VyX2Rp
cjwvdGQ+PHRkIGNsYXNzPSJ2Ij48aT5ubyB2YWx1ZTwvaT48L3RkPjx0ZCBj bGFzcz0idiI+
PGk+bm8gdmFsdWU8L2k+PC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj52 YXJpYWJsZXNf
b3JkZXI8L3RkPjx0ZCBjbGFzcz0idiI+R1BDUzwvdGQ+PHRkIGNsYXNzPSJ2 Ij5HUENTPC90
ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj54bWxycGNfZXJyb3JfbnVtYmVy PC90ZD48dGQg
Y2xhc3M9InYiPjA8L3RkPjx0ZCBjbGFzcz0idiI+MDwvdGQ+PC90cj4KPHRy Pjx0ZCBjbGFz
cz0iZSI+eG1scnBjX2Vycm9yczwvdGQ+PHRkIGNsYXNzPSJ2Ij5PZmY8L3Rk Pjx0ZCBjbGFz
cz0idiI+T2ZmPC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj55MmtfY29t cGxpYW5jZTwv
dGQ+PHRkIGNsYXNzPSJ2Ij5PbjwvdGQ+PHRkIGNsYXNzPSJ2Ij5PbjwvdGQ+ PC90cj4KPHRy
Pjx0ZCBjbGFzcz0iZSI+emVuZC56ZTFfY29tcGF0aWJpbGl0eV9tb2RlPC90 ZD48dGQgY2xh
c3M9InYiPk9mZjwvdGQ+PHRkIGNsYXNzPSJ2Ij5PZmY8L3RkPjwvdHI+Cjwv dGFibGU+PGJy
IC8+CjxoMj48YSBuYW1lPSJtb2R1bGVfYXBhY2hlMmhhbmRsZXIiPmFwYWNo ZTJoYW5kbGVy
PC9hPjwvaDI+Cjx0YWJsZSBib3JkZXI9IjAiIGNlbGxwYWRkaW5nPSIzIiB3 aWR0aD0iNjAw
Ij4KPHRyPjx0ZCBjbGFzcz0iZSI+QXBhY2hlIFZlcnNpb24gPC90ZD48dGQg Y2xhc3M9InYi
PkFwYWNoZS8yLjIuNCAoV2luMzIpIFBIUC81LjIuNCA8L3RkPjwvdHI+Cjx0 cj48dGQgY2xh
c3M9ImUiPkFwYWNoZSBBUEkgVmVyc2lvbiA8L3RkPjx0ZCBjbGFzcz0idiI+ MjAwNTExMTUg
PC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj5TZXJ2ZXIgQWRtaW5pc3Ry YXRvciA8L3Rk
Pjx0ZCBjbGFzcz0idiI+YWRAdGlzLW5ldC5kZSA8L3RkPjwvdHI+Cjx0cj48 dGQgY2xhc3M9
ImUiPkhvc3RuYW1lOlBvcnQgPC90ZD48dGQgY2xhc3M9InYiPmxvY2FsYXBh Y2hlOjgwIDwv
dGQ+PC90cj4KPHRyPjx0ZCBjbGFzcz0iZSI+TWF4IFJlcXVlc3RzIDwvdGQ+ PHRkIGNsYXNz
PSJ2Ij5QZXIgQ2hpbGQ6IDAgLSBLZWVwIEFsaXZlOiBvbiAtIE1heCBQZXIg Q29ubmVjdGlv
bjogMTAwIDwvdGQ+PC90cj4KPHRyPjx0ZCBjbGFzcz0iZSI+VGltZW91dHMg PC90ZD48dGQg
Y2xhc3M9InYiPkNvbm5lY3Rpb246IDMwMCAtIEtlZXAtQWxpdmU6IDUgPC90 ZD48L3RyPgo8
dHI+PHRkIGNsYXNzPSJlIj5WaXJ0dWFsIFNlcnZlciA8L3RkPjx0ZCBjbGFz cz0idiI+Tm8g
PC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj5TZXJ2ZXIgUm9vdCA8L3Rk Pjx0ZCBjbGFz
cz0idiI+QzovYXBhY2hlIDwvdGQ+PC90cj4KPHRyPjx0ZCBjbGFzcz0iZSI+ TG9hZGVkIE1v
ZHVsZXMgPC90ZD48dGQgY2xhc3M9InYiPmNvcmUgbW9kX3dpbjMyIG1wbV93 aW5udCBodHRw
X2NvcmUgbW9kX3NvIG1vZF9hY3Rpb25zIG1vZF9hbGlhcyBtb2RfYXNpcyBt b2RfYXV0aF9i
YXNpYyBtb2RfYXV0aG5fZGVmYXVsdCBtb2RfYXV0aG5fZmlsZSBtb2RfYXV0 aHpfZGVmYXVs
dCBtb2RfYXV0aHpfZ3JvdXBmaWxlIG1vZF9hdXRoel9ob3N0IG1vZF9hdXRo el91c2VyIG1v
ZF9hdXRvaW5kZXggbW9kX2NnaSBtb2RfZGlyIG1vZF9lbnYgbW9kX2ltYWdl bWFwIG1vZF9p
bmNsdWRlIG1vZF9pc2FwaSBtb2RfbG9nX2NvbmZpZyBtb2RfbWltZSBtb2Rf bmVnb3RpYXRp
b24gbW9kX3NldGVudmlmIG1vZF91c2VyZGlyIG1vZF9waHA1IDwvdGQ+PC90 cj4KPC90YWJs
ZT48YnIgLz4KPHRhYmxlIGJvcmRlcj0iMCIgY2VsbHBhZGRpbmc9IjMiIHdp ZHRoPSI2MDAi
Pgo8dHIgY2xhc3M9ImgiPjx0aD5EaXJlY3RpdmU8L3RoPjx0aD5Mb2NhbCBW YWx1ZTwvdGg+
PHRoPk1hc3RlciBWYWx1ZTwvdGg+PC90cj4KPHRyPjx0ZCBjbGFzcz0iZSI+ ZW5naW5lPC90
ZD48dGQgY2xhc3M9InYiPjE8L3RkPjx0ZCBjbGFzcz0idiI+MTwvdGQ+PC90 cj4KPHRyPjx0
ZCBjbGFzcz0iZSI+bGFzdF9tb2RpZmllZDwvdGQ+PHRkIGNsYXNzPSJ2Ij4w PC90ZD48dGQg
Y2xhc3M9InYiPjA8L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPnhiaXRo YWNrPC90ZD48
dGQgY2xhc3M9InYiPjA8L3RkPjx0ZCBjbGFzcz0idiI+MDwvdGQ+PC90cj4K PC90YWJsZT48
YnIgLz4KPGgyPkFwYWNoZSBFbnZpcm9ubWVudDwvaDI+Cjx0YWJsZSBib3Jk ZXI9IjAiIGNl
bGxwYWRkaW5nPSIzIiB3aWR0aD0iNjAwIj4KPHRyIGNsYXNzPSJoIj48dGg+ VmFyaWFibGU8
L3RoPjx0aD5WYWx1ZTwvdGg+PC90cj4KPHRyPjx0ZCBjbGFzcz0iZSI+SFRU UF9IT1NUIDwv
dGQ+PHRkIGNsYXNzPSJ2Ij4xMjcuMC4wLjEgPC90ZD48L3RyPgo8dHI+PHRk IGNsYXNzPSJl
Ij5IVFRQX1VTRVJfQUdFTlQgPC90ZD48dGQgY2xhc3M9InYiPk1vemlsbGEv NS4wIChXaW5k
b3dzOyBVOyBXaW5kb3dzIE5UIDYuMDsgZGU7IHJ2OjEuOC4xLjcpIEdlY2tv LzIwMDcwOTE0
IEZpcmVmb3gvMi4wLjAuNyA8L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUi PkhUVFBfQUND
RVBUIDwvdGQ+PHRkIGNsYXNzPSJ2Ij50ZXh0L3htbCxhcHBsaWNhdGlvbi94 bWwsYXBwbGlj
YXRpb24veGh0bWwreG1sLHRleHQvaHRtbDtxPTAuOSx0ZXh0L3BsYWluO3E9 MC44LGltYWdl
L3BuZywqLyo7cT0wLjUgPC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj5I VFRQX0FDQ0VQ
VF9MQU5HVUFHRSA8L3RkPjx0ZCBjbGFzcz0idiI+ZGUtZGUsZGU7cT0wLjgs ZW4tdXM7cT0w
LjUsZW47cT0wLjMgPC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj5IVFRQ X0FDQ0VQVF9F
TkNPRElORyA8L3RkPjx0ZCBjbGFzcz0idiI+Z3ppcCxkZWZsYXRlIDwvdGQ+ PC90cj4KPHRy
Pjx0ZCBjbGFzcz0iZSI+SFRUUF9BQ0NFUFRfQ0hBUlNFVCA8L3RkPjx0ZCBj bGFzcz0idiI+
SVNPLTg4NTktMSx1dGYtODtxPTAuNywqO3E9MC43IDwvdGQ+PC90cj4KPHRy Pjx0ZCBjbGFz
cz0iZSI+SFRUUF9LRUVQX0FMSVZFIDwvdGQ+PHRkIGNsYXNzPSJ2Ij4zMDAg PC90ZD48L3Ry
Pgo8dHI+PHRkIGNsYXNzPSJlIj5IVFRQX0NPTk5FQ1RJT04gPC90ZD48dGQg Y2xhc3M9InYi
PmtlZXAtYWxpdmUgPC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj5IVFRQ X1JFRkVSRVIg
PC90ZD48dGQgY2xhc3M9InYiPmh0dHA6Ly8xMjcuMC4wLjEvIDwvdGQ+PC90 cj4KPHRyPjx0
ZCBjbGFzcz0iZSI+SFRUUF9DT09LSUUgPC90ZD48dGQgY2xhc3M9InYiPlBI UFNFU1NJRD1r
NzVsM2xvMmZrNGJmNDdqamFldWY3aHAyMCA8L3RkPjwvdHI+Cjx0cj48dGQg Y2xhc3M9ImUi
PlBBVEggPC90ZD48dGQgY2xhc3M9InYiPkM6XFdpbmRvd3Ncc3lzdGVtMzI7 QzpcV2luZG93
cztDOlxXaW5kb3dzXFN5c3RlbTMyXFdiZW07QzpcUHJvZ3JhbSBGaWxlc1xJ bnRlbFxETUlY
O0M6XFByb2dyYW0gRmlsZXNcQVNVUyBTZWN1cml0eSBDZW50ZXJcQVNVUyBT ZWN1cml0eSBQ
cm90ZWN0IE1hbmFnZXJcYmluO0M6XFByb2dyYW0gRmlsZXNcUXVpY2tUaW1l XFFUU3lzdGVt
XCA8L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPlN5c3RlbVJvb3QgPC90 ZD48dGQgY2xh
c3M9InYiPkM6XFdpbmRvd3MgPC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJl Ij5DT01TUEVD
IDwvdGQ+PHRkIGNsYXNzPSJ2Ij5DOlxXaW5kb3dzXHN5c3RlbTMyXGNtZC5l eGUgPC90ZD48
L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj5QQVRIRVhUIDwvdGQ+PHRkIGNsYXNz PSJ2Ij4uQ09N
Oy5FWEU7LkJBVDsuQ01EOy5WQlM7LlZCRTsuSlM7LkpTRTsuV1NGOy5XU0g7 Lk1TQyA8L3Rk
PjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPldJTkRJUiA8L3RkPjx0ZCBjbGFz cz0idiI+Qzpc
V2luZG93cyA8L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPlNFUlZFUl9T SUdOQVRVUkUg
PC90ZD48dGQgY2xhc3M9InYiPjxpPm5vIHZhbHVlPC9pPiA8L3RkPjwvdHI+ Cjx0cj48dGQg
Y2xhc3M9ImUiPlNFUlZFUl9TT0ZUV0FSRSA8L3RkPjx0ZCBjbGFzcz0idiI+ QXBhY2hlLzIu
Mi40IChXaW4zMikgUEhQLzUuMi40IDwvdGQ+PC90cj4KPHRyPjx0ZCBjbGFz cz0iZSI+U0VS
VkVSX05BTUUgPC90ZD48dGQgY2xhc3M9InYiPjEyNy4wLjAuMSA8L3RkPjwv dHI+Cjx0cj48
dGQgY2xhc3M9ImUiPlNFUlZFUl9BRERSIDwvdGQ+PHRkIGNsYXNzPSJ2Ij4x MjcuMC4wLjEg
PC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj5TRVJWRVJfUE9SVCA8L3Rk Pjx0ZCBjbGFz
cz0idiI+ODAgPC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj5SRU1PVEVf QUREUiA8L3Rk
Pjx0ZCBjbGFzcz0idiI+MTI3LjAuMC4xIDwvdGQ+PC90cj4KPHRyPjx0ZCBj bGFzcz0iZSI+
RE9DVU1FTlRfUk9PVCA8L3RkPjx0ZCBjbGFzcz0idiI+QzovYXBhY2hlL2h0 ZG9jcyA8L3Rk
PjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPlNFUlZFUl9BRE1JTiA8L3RkPjx0 ZCBjbGFzcz0i
diI+YWRAdGlzLW5ldC5kZSA8L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUi PlNDUklQVF9G
SUxFTkFNRSA8L3RkPjx0ZCBjbGFzcz0idiI+QzovYXBhY2hlL2h0ZG9jcy9w aHBpbmZvLnBo
cCA8L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPlJFTU9URV9QT1JUIDwv dGQ+PHRkIGNs
YXNzPSJ2Ij41MzQxOCA8L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPkdB VEVXQVlfSU5U
RVJGQUNFIDwvdGQ+PHRkIGNsYXNzPSJ2Ij5DR0kvMS4xIDwvdGQ+PC90cj4K PHRyPjx0ZCBj
bGFzcz0iZSI+U0VSVkVSX1BST1RPQ09MIDwvdGQ+PHRkIGNsYXNzPSJ2Ij5I VFRQLzEuMSA8
L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPlJFUVVFU1RfTUVUSE9EIDwv dGQ+PHRkIGNs
YXNzPSJ2Ij5HRVQgPC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj5RVUVS WV9TVFJJTkcg
Y2xhc3M9ImUiPlJFUVVFU1RfVVJJIDwvdGQ+PHRkIGNsYXNzPSJ2Ij4vcGhw aW5mby5waHAg
PC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj5TQ1JJUFRfTkFNRSA8L3Rk Pjx0ZCBjbGFz
cz0idiI+L3BocGluZm8ucGhwIDwvdGQ+PC90cj4KPC90YWJsZT48YnIgLz4K PGgyPkhUVFAg
SGVhZGVycyBJbmZvcm1hdGlvbjwvaDI+Cjx0YWJsZSBib3JkZXI9IjAiIGNl bGxwYWRkaW5n
PSIzIiB3aWR0aD0iNjAwIj4KPHRyIGNsYXNzPSJoIj48dGggY29sc3Bhbj0i MiI+SFRUUCBS
ZXF1ZXN0IEhlYWRlcnM8L3RoPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPkhU VFAgUmVxdWVz
dCA8L3RkPjx0ZCBjbGFzcz0idiI+R0VUIC9waHBpbmZvLnBocCBIVFRQLzEu MSA8L3RkPjwv
dHI+Cjx0cj48dGQgY2xhc3M9ImUiPkhvc3QgPC90ZD48dGQgY2xhc3M9InYi PjEyNy4wLjAu
MSA8L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPlVzZXItQWdlbnQgPC90 ZD48dGQgY2xh
c3M9InYiPk1vemlsbGEvNS4wIChXaW5kb3dzOyBVOyBXaW5kb3dzIE5UIDYu MDsgZGU7IHJ2
OjEuOC4xLjcpIEdlY2tvLzIwMDcwOTE0IEZpcmVmb3gvMi4wLjAuNyA8L3Rk PjwvdHI+Cjx0
cj48dGQgY2xhc3M9ImUiPkFjY2VwdCA8L3RkPjx0ZCBjbGFzcz0idiI+dGV4 dC94bWwsYXBw
bGljYXRpb24veG1sLGFwcGxpY2F0aW9uL3hodG1sK3htbCx0ZXh0L2h0bWw7 cT0wLjksdGV4
dC9wbGFpbjtxPTAuOCxpbWFnZS9wbmcsKi8qO3E9MC41IDwvdGQ+PC90cj4K PHRyPjx0ZCBj
bGFzcz0iZSI+QWNjZXB0LUxhbmd1YWdlIDwvdGQ+PHRkIGNsYXNzPSJ2Ij5k ZS1kZSxkZTtx
PTAuOCxlbi11cztxPTAuNSxlbjtxPTAuMyA8L3RkPjwvdHI+Cjx0cj48dGQg Y2xhc3M9ImUi
PkFjY2VwdC1FbmNvZGluZyA8L3RkPjx0ZCBjbGFzcz0idiI+Z3ppcCxkZWZs YXRlIDwvdGQ+
PC90cj4KPHRyPjx0ZCBjbGFzcz0iZSI+QWNjZXB0LUNoYXJzZXQgPC90ZD48 dGQgY2xhc3M9
InYiPklTTy04ODU5LTEsdXRmLTg7cT0wLjcsKjtxPTAuNyA8L3RkPjwvdHI+ Cjx0cj48dGQg
Y2xhc3M9ImUiPktlZXAtQWxpdmUgPC90ZD48dGQgY2xhc3M9InYiPjMwMCA8 L3RkPjwvdHI+
Cjx0cj48dGQgY2xhc3M9ImUiPkNvbm5lY3Rpb24gPC90ZD48dGQgY2xhc3M9 InYiPmtlZXAt
YWxpdmUgPC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj5SZWZlcmVyIDwv dGQ+PHRkIGNs
YXNzPSJ2Ij5odHRwOi8vMTI3LjAuMC4xLyA8L3RkPjwvdHI+Cjx0cj48dGQg Y2xhc3M9ImUi
PkNvb2tpZSA8L3RkPjx0ZCBjbGFzcz0idiI+UEhQU0VTU0lEPWs3NWwzbG8y Zms0YmY0N2pq
YWV1ZjdocDIwIDwvdGQ+PC90cj4KPHRyIGNsYXNzPSJoIj48dGggY29sc3Bh bj0iMiI+SFRU
UCBSZXNwb25zZSBIZWFkZXJzPC90aD48L3RyPgo8dHI+PHRkIGNsYXNzPSJl Ij5YLVBvd2Vy
ZWQtQnkgPC90ZD48dGQgY2xhc3M9InYiPlBIUC81LjIuNCA8L3RkPjwvdHI+ Cjx0cj48dGQg
Y2xhc3M9ImUiPktlZXAtQWxpdmUgPC90ZD48dGQgY2xhc3M9InYiPnRpbWVv dXQ9NSwgbWF4
PTk5IDwvdGQ+PC90cj4KPHRyPjx0ZCBjbGFzcz0iZSI+Q29ubmVjdGlvbiA8 L3RkPjx0ZCBj
bGFzcz0idiI+S2VlcC1BbGl2ZSA8L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9 ImUiPlRyYW5z
ZmVyLUVuY29kaW5nIDwvdGQ+PHRkIGNsYXNzPSJ2Ij5jaHVua2VkIDwvdGQ+ PC90cj4KPHRy
Pjx0ZCBjbGFzcz0iZSI+Q29udGVudC1UeXBlIDwvdGQ+PHRkIGNsYXNzPSJ2 Ij50ZXh0L2h0
bWwgPC90ZD48L3RyPgo8L3RhYmxlPjxiciAvPgo8aDI+PGEgbmFtZT0ibW9k dWxlX2JjbWF0
aCI+YmNtYXRoPC9hPjwvaDI+Cjx0YWJsZSBib3JkZXI9IjAiIGNlbGxwYWRk aW5nPSIzIiB3
aWR0aD0iNjAwIj4KPHRyPjx0ZCBjbGFzcz0iZSI+QkNNYXRoIHN1cHBvcnQg PC90ZD48dGQg
Y2xhc3M9InYiPmVuYWJsZWQgPC90ZD48L3RyPgo8L3RhYmxlPjxiciAvPgo8 aDI+PGEgbmFt
ZT0ibW9kdWxlX2NhbGVuZGFyIj5jYWxlbmRhcjwvYT48L2gyPgo8dGFibGUg Ym9yZGVyPSIw
IiBjZWxscGFkZGluZz0iMyIgd2lkdGg9IjYwMCI+Cjx0cj48dGQgY2xhc3M9 ImUiPkNhbGVu
ZGFyIHN1cHBvcnQgPC90ZD48dGQgY2xhc3M9InYiPmVuYWJsZWQgPC90ZD48 L3RyPgo8L3Rh
YmxlPjxiciAvPgo8aDI+PGEgbmFtZT0ibW9kdWxlX2NvbV9kb3RuZXQiPmNv bV9kb3RuZXQ8
L2E+PC9oMj4KPHRhYmxlIGJvcmRlcj0iMCIgY2VsbHBhZGRpbmc9IjMiIHdp ZHRoPSI2MDAi
Pgo8dHIgY2xhc3M9ImgiPjx0aD5DT00gc3VwcG9ydDwvdGg+PHRoPmVuYWJs ZWQ8L3RoPjwv
dHI+Cjx0ciBjbGFzcz0iaCI+PHRoPkRDT00gc3VwcG9ydDwvdGg+PHRoPmRp c2FibGVkPC90
aD48L3RyPgo8dHIgY2xhc3M9ImgiPjx0aD4uTmV0IHN1cHBvcnQ8L3RoPjx0 aD5lbmFibGVk
PC90aD48L3RyPgo8L3RhYmxlPjxiciAvPgo8dGFibGUgYm9yZGVyPSIwIiBj ZWxscGFkZGlu
Zz0iMyIgd2lkdGg9IjYwMCI+Cjx0ciBjbGFzcz0iaCI+PHRoPkRpcmVjdGl2 ZTwvdGg+PHRo
PkxvY2FsIFZhbHVlPC90aD48dGg+TWFzdGVyIFZhbHVlPC90aD48L3RyPgo8 dHI+PHRkIGNs
YXNzPSJlIj5jb20uYWxsb3dfZGNvbTwvdGQ+PHRkIGNsYXNzPSJ2Ij4wPC90 ZD48dGQgY2xh
c3M9InYiPjA8L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPmNvbS5hdXRv cmVnaXN0ZXJf
Y2FzZXNlbnNpdGl2ZTwvdGQ+PHRkIGNsYXNzPSJ2Ij4xPC90ZD48dGQgY2xh c3M9InYiPjE8
L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPmNvbS5hdXRvcmVnaXN0ZXJf dHlwZWxpYjwv
dGQ+PHRkIGNsYXNzPSJ2Ij4wPC90ZD48dGQgY2xhc3M9InYiPjA8L3RkPjwv dHI+Cjx0cj48
dGQgY2xhc3M9ImUiPmNvbS5hdXRvcmVnaXN0ZXJfdmVyYm9zZTwvdGQ+PHRk IGNsYXNzPSJ2
Ij4wPC90ZD48dGQgY2xhc3M9InYiPjA8L3RkPjwvdHI+Cjx0cj48dGQgY2xh c3M9ImUiPmNv
bS5jb2RlX3BhZ2U8L3RkPjx0ZCBjbGFzcz0idiI+PGk+bm8gdmFsdWU8L2k+ PC90ZD48dGQg
Y2xhc3M9InYiPjxpPm5vIHZhbHVlPC9pPjwvdGQ+PC90cj4KPHRyPjx0ZCBj bGFzcz0iZSI+
Y29tLnR5cGVsaWJfZmlsZTwvdGQ+PHRkIGNsYXNzPSJ2Ij48aT5ubyB2YWx1 ZTwvaT48L3Rk
Pjx0ZCBjbGFzcz0idiI+PGk+bm8gdmFsdWU8L2k+PC90ZD48L3RyPgo8L3Rh YmxlPjxiciAv
Pgo8aDI+PGEgbmFtZT0ibW9kdWxlX2N0eXBlIj5jdHlwZTwvYT48L2gyPgo8 dGFibGUgYm9y
ZGVyPSIwIiBjZWxscGFkZGluZz0iMyIgd2lkdGg9IjYwMCI+Cjx0cj48dGQg Y2xhc3M9ImUi
PmN0eXBlIGZ1bmN0aW9ucyA8L3RkPjx0ZCBjbGFzcz0idiI+ZW5hYmxlZCA8 L3RkPjwvdHI+
CjwvdGFibGU+PGJyIC8+CjxoMj48YSBuYW1lPSJtb2R1bGVfZGF0ZSI+ZGF0 ZTwvYT48L2gy
Pgo8dGFibGUgYm9yZGVyPSIwIiBjZWxscGFkZGluZz0iMyIgd2lkdGg9IjYw MCI+Cjx0cj48
dGQgY2xhc3M9ImUiPmRhdGUvdGltZSBzdXBwb3J0IDwvdGQ+PHRkIGNsYXNz PSJ2Ij5lbmFi
bGVkIDwvdGQ+PC90cj4KPHRyPjx0ZCBjbGFzcz0iZSI+JnF1b3Q7T2xzb24m cXVvdDsgVGlt
ZXpvbmUgRGF0YWJhc2UgVmVyc2lvbiA8L3RkPjx0ZCBjbGFzcz0idiI+MjAw Ny42IDwvdGQ+
PC90cj4KPHRyPjx0ZCBjbGFzcz0iZSI+VGltZXpvbmUgRGF0YWJhc2UgPC90 ZD48dGQgY2xh
c3M9InYiPmludGVybmFsIDwvdGQ+PC90cj4KPHRyPjx0ZCBjbGFzcz0iZSI+ RGVmYXVsdCB0
aW1lem9uZSA8L3RkPjx0ZCBjbGFzcz0idiI+RXVyb3BlL1BhcmlzIDwvdGQ+ PC90cj4KPC90
MDAiPgo8dHIgY2xhc3M9ImgiPjx0aD5EaXJlY3RpdmU8L3RoPjx0aD5Mb2Nh bCBWYWx1ZTwv
dGg+PHRoPk1hc3RlciBWYWx1ZTwvdGg+PC90cj4KPHRyPjx0ZCBjbGFzcz0i ZSI+ZGF0ZS5k
ZWZhdWx0X2xhdGl0dWRlPC90ZD48dGQgY2xhc3M9InYiPjMxLjc2Njc8L3Rk Pjx0ZCBjbGFz
cz0idiI+MzEuNzY2NzwvdGQ+PC90cj4KPHRyPjx0ZCBjbGFzcz0iZSI+ZGF0 ZS5kZWZhdWx0
X2xvbmdpdHVkZTwvdGQ+PHRkIGNsYXNzPSJ2Ij4zNS4yMzMzPC90ZD48dGQg Y2xhc3M9InYi
PjM1LjIzMzM8L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPmRhdGUuc3Vu cmlzZV96ZW5p
dGg8L3RkPjx0ZCBjbGFzcz0idiI+OTAuNTgzMzMzPC90ZD48dGQgY2xhc3M9 InYiPjkwLjU4
MzMzMzwvdGQ+PC90cj4KPHRyPjx0ZCBjbGFzcz0iZSI+ZGF0ZS5zdW5zZXRf emVuaXRoPC90
ZD48dGQgY2xhc3M9InYiPjkwLjU4MzMzMzwvdGQ+PHRkIGNsYXNzPSJ2Ij45 MC41ODMzMzM8
L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPmRhdGUudGltZXpvbmU8L3Rk Pjx0ZCBjbGFz
cz0idiI+PGk+bm8gdmFsdWU8L2k+PC90ZD48dGQgY2xhc3M9InYiPjxpPm5v IHZhbHVlPC9p
PjwvdGQ+PC90cj4KPC90YWJsZT48YnIgLz4KPGgyPjxhIG5hbWU9Im1vZHVs ZV9kb20iPmRv
bTwvYT48L2gyPgo8dGFibGUgYm9yZGVyPSIwIiBjZWxscGFkZGluZz0iMyIg d2lkdGg9IjYw
MCI+Cjx0cj48dGQgY2xhc3M9ImUiPkRPTS9YTUwgPC90ZD48dGQgY2xhc3M9 InYiPmVuYWJs
ZWQgPC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj5ET00vWE1MIEFQSSBW ZXJzaW9uIDwv
dGQ+PHRkIGNsYXNzPSJ2Ij4yMDAzMTEyOSA8L3RkPjwvdHI+Cjx0cj48dGQg Y2xhc3M9ImUi
PmxpYnhtbCBWZXJzaW9uIDwvdGQ+PHRkIGNsYXNzPSJ2Ij4yLjYuMjYgPC90 ZD48L3RyPgo8
dHI+PHRkIGNsYXNzPSJlIj5IVE1MIFN1cHBvcnQgPC90ZD48dGQgY2xhc3M9 InYiPmVuYWJs
ZWQgPC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj5YUGF0aCBTdXBwb3J0 IDwvdGQ+PHRk
IGNsYXNzPSJ2Ij5lbmFibGVkIDwvdGQ+PC90cj4KPHRyPjx0ZCBjbGFzcz0i ZSI+WFBvaW50
ZXIgU3VwcG9ydCA8L3RkPjx0ZCBjbGFzcz0idiI+ZW5hYmxlZCA8L3RkPjwv dHI+Cjx0cj48
dGQgY2xhc3M9ImUiPlNjaGVtYSBTdXBwb3J0IDwvdGQ+PHRkIGNsYXNzPSJ2 Ij5lbmFibGVk
IDwvdGQ+PC90cj4KPHRyPjx0ZCBjbGFzcz0iZSI+UmVsYXhORyBTdXBwb3J0 IDwvdGQ+PHRk
IGNsYXNzPSJ2Ij5lbmFibGVkIDwvdGQ+PC90cj4KPC90YWJsZT48YnIgLz4K PGgyPjxhIG5h
bWU9Im1vZHVsZV9maWx0ZXIiPmZpbHRlcjwvYT48L2gyPgo8dGFibGUgYm9y ZGVyPSIwIiBj
ZWxscGFkZGluZz0iMyIgd2lkdGg9IjYwMCI+Cjx0cj48dGQgY2xhc3M9ImUi PklucHV0IFZh
bGlkYXRpb24gYW5kIEZpbHRlcmluZyA8L3RkPjx0ZCBjbGFzcz0idiI+ZW5h YmxlZCA8L3Rk
PjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPlJldmlzaW9uIDwvdGQ+PHRkIGNs YXNzPSJ2Ij4k
UmV2aXNpb246IDEuNTIuMi4zOSAkIDwvdGQ+PC90cj4KPC90YWJsZT48YnIg Lz4KPHRhYmxl
IGJvcmRlcj0iMCIgY2VsbHBhZGRpbmc9IjMiIHdpZHRoPSI2MDAiPgo8dHIg Y2xhc3M9Imgi
Pjx0aD5EaXJlY3RpdmU8L3RoPjx0aD5Mb2NhbCBWYWx1ZTwvdGg+PHRoPk1h c3RlciBWYWx1
ZTwvdGg+PC90cj4KPHRyPjx0ZCBjbGFzcz0iZSI+ZmlsdGVyLmRlZmF1bHQ8 L3RkPjx0ZCBj
bGFzcz0idiI+dW5zYWZlX3JhdzwvdGQ+PHRkIGNsYXNzPSJ2Ij51bnNhZmVf cmF3PC90ZD48
L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj5maWx0ZXIuZGVmYXVsdF9mbGFnczwv dGQ+PHRkIGNs
YXNzPSJ2Ij48aT5ubyB2YWx1ZTwvaT48L3RkPjx0ZCBjbGFzcz0idiI+PGk+ bm8gdmFsdWU8
L2k+PC90ZD48L3RyPgo8L3RhYmxlPjxiciAvPgo8aDI+PGEgbmFtZT0ibW9k dWxlX2Z0cCI+
ZnRwPC9hPjwvaDI+Cjx0YWJsZSBib3JkZXI9IjAiIGNlbGxwYWRkaW5nPSIz IiB3aWR0aD0i
NjAwIj4KPHRyPjx0ZCBjbGFzcz0iZSI+RlRQIHN1cHBvcnQgPC90ZD48dGQg Y2xhc3M9InYi
PmVuYWJsZWQgPC90ZD48L3RyPgo8L3RhYmxlPjxiciAvPgo8aDI+PGEgbmFt ZT0ibW9kdWxl
X2dkIj5nZDwvYT48L2gyPgo8dGFibGUgYm9yZGVyPSIwIiBjZWxscGFkZGlu Zz0iMyIgd2lk
dGg9IjYwMCI+Cjx0cj48dGQgY2xhc3M9ImUiPkdEIFN1cHBvcnQgPC90ZD48 dGQgY2xhc3M9
InYiPmVuYWJsZWQgPC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj5HRCBW ZXJzaW9uIDwv
dGQ+PHRkIGNsYXNzPSJ2Ij5idW5kbGVkICgyLjAuMzQgY29tcGF0aWJsZSkg PC90ZD48L3Ry
Pgo8dHI+PHRkIGNsYXNzPSJlIj5GcmVlVHlwZSBTdXBwb3J0IDwvdGQ+PHRk IGNsYXNzPSJ2
Ij5lbmFibGVkIDwvdGQ+PC90cj4KPHRyPjx0ZCBjbGFzcz0iZSI+RnJlZVR5 cGUgTGlua2Fn
ZSA8L3RkPjx0ZCBjbGFzcz0idiI+d2l0aCBmcmVldHlwZSA8L3RkPjwvdHI+ Cjx0cj48dGQg
Y2xhc3M9ImUiPkZyZWVUeXBlIFZlcnNpb24gPC90ZD48dGQgY2xhc3M9InYi PjIuMS45IDwv
dGQ+PC90cj4KPHRyPjx0ZCBjbGFzcz0iZSI+VDFMaWIgU3VwcG9ydCA8L3Rk Pjx0ZCBjbGFz
cz0idiI+ZW5hYmxlZCA8L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPkdJ RiBSZWFkIFN1
cHBvcnQgPC90ZD48dGQgY2xhc3M9InYiPmVuYWJsZWQgPC90ZD48L3RyPgo8 dHI+PHRkIGNs
YXNzPSJlIj5HSUYgQ3JlYXRlIFN1cHBvcnQgPC90ZD48dGQgY2xhc3M9InYi PmVuYWJsZWQg
PC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj5KUEcgU3VwcG9ydCA8L3Rk Pjx0ZCBjbGFz
cz0idiI+ZW5hYmxlZCA8L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPlBO RyBTdXBwb3J0
IDwvdGQ+PHRkIGNsYXNzPSJ2Ij5lbmFibGVkIDwvdGQ+PC90cj4KPHRyPjx0 ZCBjbGFzcz0i
ZSI+V0JNUCBTdXBwb3J0IDwvdGQ+PHRkIGNsYXNzPSJ2Ij5lbmFibGVkIDwv dGQ+PC90cj4K
PHRyPjx0ZCBjbGFzcz0iZSI+WEJNIFN1cHBvcnQgPC90ZD48dGQgY2xhc3M9 InYiPmVuYWJs
ZWQgPC90ZD48L3RyPgo8L3RhYmxlPjxiciAvPgo8aDI+PGEgbmFtZT0ibW9k dWxlX2hhc2gi
Pmhhc2g8L2E+PC9oMj4KPHRhYmxlIGJvcmRlcj0iMCIgY2VsbHBhZGRpbmc9 IjMiIHdpZHRo
PSI2MDAiPgo8dHI+PHRkIGNsYXNzPSJlIj5oYXNoIHN1cHBvcnQgPC90ZD48 dGQgY2xhc3M9
InYiPmVuYWJsZWQgPC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj5IYXNo aW5nIEVuZ2lu
ZXMgPC90ZD48dGQgY2xhc3M9InYiPm1kMiBtZDQgbWQ1IHNoYTEgc2hhMjU2 IHNoYTM4NCBz
aGE1MTIgcmlwZW1kMTI4IHJpcGVtZDE2MCByaXBlbWQyNTYgcmlwZW1kMzIw IHdoaXJscG9v
bCB0aWdlcjEyOCwzIHRpZ2VyMTYwLDMgdGlnZXIxOTIsMyB0aWdlcjEyOCw0 IHRpZ2VyMTYw
LDQgdGlnZXIxOTIsNCBzbmVmcnUgZ29zdCBhZGxlcjMyIGNyYzMyIGNyYzMy YiBoYXZhbDEy
OCwzIGhhdmFsMTYwLDMgaGF2YWwxOTIsMyBoYXZhbDIyNCwzIGhhdmFsMjU2 LDMgaGF2YWwx
MjgsNCBoYXZhbDE2MCw0IGhhdmFsMTkyLDQgaGF2YWwyMjQsNCBoYXZhbDI1 Niw0IGhhdmFs
MTI4LDUgaGF2YWwxNjAsNSBoYXZhbDE5Miw1IGhhdmFsMjI0LDUgaGF2YWwy NTYsNSAgPC90
ZD48L3RyPgo8L3RhYmxlPjxiciAvPgo8aDI+PGEgbmFtZT0ibW9kdWxlX2lj b252Ij5pY29u
djwvYT48L2gyPgo8dGFibGUgYm9yZGVyPSIwIiBjZWxscGFkZGluZz0iMyIg d2lkdGg9IjYw
MCI+Cjx0cj48dGQgY2xhc3M9ImUiPmljb252IHN1cHBvcnQgPC90ZD48dGQg Y2xhc3M9InYi
PmVuYWJsZWQgPC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj5pY29udiBp bXBsZW1lbnRh
dGlvbiA8L3RkPjx0ZCBjbGFzcz0idiI+JnF1b3Q7bGliaWNvbnYmcXVvdDsg PC90ZD48L3Ry
Pgo8dHI+PHRkIGNsYXNzPSJlIj5pY29udiBsaWJyYXJ5IHZlcnNpb24gPC90 ZD48dGQgY2xh
c3M9InYiPjEuOSA8L3RkPjwvdHI+CjwvdGFibGU+PGJyIC8+Cjx0YWJsZSBi b3JkZXI9IjAi
IGNlbGxwYWRkaW5nPSIzIiB3aWR0aD0iNjAwIj4KPHRyIGNsYXNzPSJoIj48 dGg+RGlyZWN0
aXZlPC90aD48dGg+TG9jYWwgVmFsdWU8L3RoPjx0aD5NYXN0ZXIgVmFsdWU8 L3RoPjwvdHI+
Cjx0cj48dGQgY2xhc3M9ImUiPmljb252LmlucHV0X2VuY29kaW5nPC90ZD48 dGQgY2xhc3M9
InYiPklTTy04ODU5LTE8L3RkPjx0ZCBjbGFzcz0idiI+SVNPLTg4NTktMTwv dGQ+PC90cj4K
PHRyPjx0ZCBjbGFzcz0iZSI+aWNvbnYuaW50ZXJuYWxfZW5jb2Rpbmc8L3Rk Pjx0ZCBjbGFz
cz0idiI+SVNPLTg4NTktMTwvdGQ+PHRkIGNsYXNzPSJ2Ij5JU08tODg1OS0x PC90ZD48L3Ry
Pgo8dHI+PHRkIGNsYXNzPSJlIj5pY29udi5vdXRwdXRfZW5jb2Rpbmc8L3Rk Pjx0ZCBjbGFz
Pgo8L3RhYmxlPjxiciAvPgo8aDI+PGEgbmFtZT0ibW9kdWxlX2pzb24iPmpz b248L2E+PC9o
Mj4KPHRhYmxlIGJvcmRlcj0iMCIgY2VsbHBhZGRpbmc9IjMiIHdpZHRoPSI2 MDAiPgo8dHI+
PHRkIGNsYXNzPSJlIj5qc29uIHN1cHBvcnQgPC90ZD48dGQgY2xhc3M9InYi PmVuYWJsZWQg
PC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj5qc29uIHZlcnNpb24gPC90 ZD48dGQgY2xh
c3M9InYiPjEuMi4xIDwvdGQ+PC90cj4KPC90YWJsZT48YnIgLz4KPGgyPjxh IG5hbWU9Im1v
ZHVsZV9saWJ4bWwiPmxpYnhtbDwvYT48L2gyPgo8dGFibGUgYm9yZGVyPSIw IiBjZWxscGFk
ZGluZz0iMyIgd2lkdGg9IjYwMCI+Cjx0cj48dGQgY2xhc3M9ImUiPmxpYlhN TCBzdXBwb3J0
IDwvdGQ+PHRkIGNsYXNzPSJ2Ij5hY3RpdmUgPC90ZD48L3RyPgo8dHI+PHRk IGNsYXNzPSJl
Ij5saWJYTUwgVmVyc2lvbiA8L3RkPjx0ZCBjbGFzcz0idiI+Mi42LjI2IDwv dGQ+PC90cj4K
PHRyPjx0ZCBjbGFzcz0iZSI+bGliWE1MIHN0cmVhbXMgPC90ZD48dGQgY2xh c3M9InYiPmVu
YWJsZWQgPC90ZD48L3RyPgo8L3RhYmxlPjxiciAvPgo8aDI+PGEgbmFtZT0i bW9kdWxlX29k
YmMiPm9kYmM8L2E+PC9oMj4KPHRhYmxlIGJvcmRlcj0iMCIgY2VsbHBhZGRp bmc9IjMiIHdp
ZHRoPSI2MDAiPgo8dHIgY2xhc3M9ImgiPjx0aD5PREJDIFN1cHBvcnQ8L3Ro Pjx0aD5lbmFi
bGVkPC90aD48L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj5BY3RpdmUgUGVyc2lz dGVudCBMaW5r
cyA8L3RkPjx0ZCBjbGFzcz0idiI+MCA8L3RkPjwvdHI+Cjx0cj48dGQgY2xh c3M9ImUiPkFj
dGl2ZSBMaW5rcyA8L3RkPjx0ZCBjbGFzcz0idiI+MCA8L3RkPjwvdHI+Cjx0 cj48dGQgY2xh
c3M9ImUiPk9EQkMgbGlicmFyeSA8L3RkPjx0ZCBjbGFzcz0idiI+V2luMzIg PC90ZD48L3Ry
Pgo8L3RhYmxlPjxiciAvPgo8dGFibGUgYm9yZGVyPSIwIiBjZWxscGFkZGlu Zz0iMyIgd2lk
dGg9IjYwMCI+Cjx0ciBjbGFzcz0iaCI+PHRoPkRpcmVjdGl2ZTwvdGg+PHRo PkxvY2FsIFZh
bHVlPC90aD48dGg+TWFzdGVyIFZhbHVlPC90aD48L3RyPgo8dHI+PHRkIGNs YXNzPSJlIj5v
ZGJjLmFsbG93X3BlcnNpc3RlbnQ8L3RkPjx0ZCBjbGFzcz0idiI+T248L3Rk Pjx0ZCBjbGFz
cz0idiI+T248L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPm9kYmMuY2hl Y2tfcGVyc2lz
dGVudDwvdGQ+PHRkIGNsYXNzPSJ2Ij5PbjwvdGQ+PHRkIGNsYXNzPSJ2Ij5P bjwvdGQ+PC90
cj4KPHRyPjx0ZCBjbGFzcz0iZSI+b2RiYy5kZWZhdWx0X2RiPC90ZD48dGQg Y2xhc3M9InYi
PjxpPm5vIHZhbHVlPC9pPjwvdGQ+PHRkIGNsYXNzPSJ2Ij48aT5ubyB2YWx1 ZTwvaT48L3Rk
PjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPm9kYmMuZGVmYXVsdF9wdzwvdGQ+ PHRkIGNsYXNz
PSJ2Ij48aT5ubyB2YWx1ZTwvaT48L3RkPjx0ZCBjbGFzcz0idiI+PGk+bm8g dmFsdWU8L2k+
PC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj5vZGJjLmRlZmF1bHRfdXNl cjwvdGQ+PHRk
IGNsYXNzPSJ2Ij48aT5ubyB2YWx1ZTwvaT48L3RkPjx0ZCBjbGFzcz0idiI+ PGk+bm8gdmFs
dWU8L2k+PC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj5vZGJjLmRlZmF1 bHRiaW5tb2Rl
PC90ZD48dGQgY2xhc3M9InYiPnJldHVybiBhcyBpczwvdGQ+PHRkIGNsYXNz PSJ2Ij5yZXR1
cm4gYXMgaXM8L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPm9kYmMuZGVm YXVsdGxybDwv
dGQ+PHRkIGNsYXNzPSJ2Ij5yZXR1cm4gdXAgdG8gNDA5NiBieXRlczwvdGQ+ PHRkIGNsYXNz
PSJ2Ij5yZXR1cm4gdXAgdG8gNDA5NiBieXRlczwvdGQ+PC90cj4KPHRyPjx0 ZCBjbGFzcz0i
ZSI+b2RiYy5tYXhfbGlua3M8L3RkPjx0ZCBjbGFzcz0idiI+VW5saW1pdGVk PC90ZD48dGQg
Y2xhc3M9InYiPlVubGltaXRlZDwvdGQ+PC90cj4KPHRyPjx0ZCBjbGFzcz0i ZSI+b2RiYy5t
YXhfcGVyc2lzdGVudDwvdGQ+PHRkIGNsYXNzPSJ2Ij5VbmxpbWl0ZWQ8L3Rk Pjx0ZCBjbGFz
cz0idiI+VW5saW1pdGVkPC90ZD48L3RyPgo8L3RhYmxlPjxiciAvPgo8aDI+ PGEgbmFtZT0i
bW9kdWxlX3BjcmUiPnBjcmU8L2E+PC9oMj4KPHRhYmxlIGJvcmRlcj0iMCIg Y2VsbHBhZGRp
bmc9IjMiIHdpZHRoPSI2MDAiPgo8dHI+PHRkIGNsYXNzPSJlIj5QQ1JFIChQ ZXJsIENvbXBh
dGlibGUgUmVndWxhciBFeHByZXNzaW9ucykgU3VwcG9ydCA8L3RkPjx0ZCBj bGFzcz0idiI+
ZW5hYmxlZCA8L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPlBDUkUgTGli cmFyeSBWZXJz
aW9uIDwvdGQ+PHRkIGNsYXNzPSJ2Ij43LjIgMjAwNy0wNi0xOSA8L3RkPjwv dHI+CjwvdGFi
bGU+PGJyIC8+Cjx0YWJsZSBib3JkZXI9IjAiIGNlbGxwYWRkaW5nPSIzIiB3 aWR0aD0iNjAw
Ij4KPHRyIGNsYXNzPSJoIj48dGg+RGlyZWN0aXZlPC90aD48dGg+TG9jYWwg VmFsdWU8L3Ro
Pjx0aD5NYXN0ZXIgVmFsdWU8L3RoPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUi PnBjcmUuYmFj
a3RyYWNrX2xpbWl0PC90ZD48dGQgY2xhc3M9InYiPjEwMDAwMDwvdGQ+PHRk IGNsYXNzPSJ2
Ij4xMDAwMDA8L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPnBjcmUucmVj dXJzaW9uX2xp
bWl0PC90ZD48dGQgY2xhc3M9InYiPjEwMDAwMDwvdGQ+PHRkIGNsYXNzPSJ2 Ij4xMDAwMDA8
L3RkPjwvdHI+CjwvdGFibGU+PGJyIC8+CjxoMj48YSBuYW1lPSJtb2R1bGVf UERPIj5QRE88
Pgo8dHIgY2xhc3M9ImgiPjx0aD5QRE8gc3VwcG9ydDwvdGg+PHRoPmVuYWJs ZWQ8L3RoPjwv
dHI+Cjx0cj48dGQgY2xhc3M9ImUiPlBETyBkcml2ZXJzIDwvdGQ+PHRkIGNs YXNzPSJ2Ij5w
Z3NxbCA8L3RkPjwvdHI+CjwvdGFibGU+PGJyIC8+CjxoMj48YSBuYW1lPSJt b2R1bGVfcGRv
X3Bnc3FsIj5wZG9fcGdzcWw8L2E+PC9oMj4KPHRhYmxlIGJvcmRlcj0iMCIg Y2VsbHBhZGRp
bmc9IjMiIHdpZHRoPSI2MDAiPgo8dHIgY2xhc3M9ImgiPjx0aD5QRE8gRHJp dmVyIGZvciBQ
b3N0Z3JlU1FMPC90aD48dGg+ZW5hYmxlZDwvdGg+PC90cj4KPHRyPjx0ZCBj bGFzcz0iZSI+
UG9zdGdyZVNRTChsaWJwcSkgVmVyc2lvbiA8L3RkPjx0ZCBjbGFzcz0idiI+ OC4yLjMgPC90
ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj5Nb2R1bGUgdmVyc2lvbiA8L3Rk Pjx0ZCBjbGFz
cz0idiI+MS4wLjIgPC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj5SZXZp c2lvbiA8L3Rk
Pjx0ZCBjbGFzcz0idiI+ICRJZDogcGRvX3Bnc3FsLmMsdiAxLjcuMi4xMS4y LjEgMjAwNy8w
MS8wMSAwOTozNjowNSBzZWJhc3RpYW4gRXhwICQgIDwvdGQ+PC90cj4KPC90 YWJsZT48YnIg
Lz4KPGgyPjxhIG5hbWU9Im1vZHVsZV9wZ3NxbCI+cGdzcWw8L2E+PC9oMj4K PHRhYmxlIGJv
cmRlcj0iMCIgY2VsbHBhZGRpbmc9IjMiIHdpZHRoPSI2MDAiPgo8dHIgY2xh c3M9ImgiPjx0
aD5Qb3N0Z3JlU1FMIFN1cHBvcnQ8L3RoPjx0aD5lbmFibGVkPC90aD48L3Ry Pgo8dHI+PHRk
IGNsYXNzPSJlIj5Qb3N0Z3JlU1FMKGxpYnBxKSBWZXJzaW9uIDwvdGQ+PHRk IGNsYXNzPSJ2
Ij44LjIuMyA8L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPk11bHRpYnl0 ZSBjaGFyYWN0
ZXIgc3VwcG9ydCA8L3RkPjx0ZCBjbGFzcz0idiI+ZW5hYmxlZCA8L3RkPjwv dHI+Cjx0cj48
dGQgY2xhc3M9ImUiPlNTTCBzdXBwb3J0IDwvdGQ+PHRkIGNsYXNzPSJ2Ij5k aXNhYmxlZCA8
L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPkFjdGl2ZSBQZXJzaXN0ZW50 IExpbmtzIDwv
dGQ+PHRkIGNsYXNzPSJ2Ij4wIDwvdGQ+PC90cj4KPHRyPjx0ZCBjbGFzcz0i ZSI+QWN0aXZl
IExpbmtzIDwvdGQ+PHRkIGNsYXNzPSJ2Ij4wIDwvdGQ+PC90cj4KPC90YWJs ZT48YnIgLz4K
PHRhYmxlIGJvcmRlcj0iMCIgY2VsbHBhZGRpbmc9IjMiIHdpZHRoPSI2MDAi Pgo8dHIgY2xh
c3M9ImgiPjx0aD5EaXJlY3RpdmU8L3RoPjx0aD5Mb2NhbCBWYWx1ZTwvdGg+ PHRoPk1hc3Rl
ciBWYWx1ZTwvdGg+PC90cj4KPHRyPjx0ZCBjbGFzcz0iZSI+cGdzcWwuYWxs b3dfcGVyc2lz
cj4KPHRyPjx0ZCBjbGFzcz0iZSI+cGdzcWwuYXV0b19yZXNldF9wZXJzaXN0 ZW50PC90ZD48
dGQgY2xhc3M9InYiPk9mZjwvdGQ+PHRkIGNsYXNzPSJ2Ij5PZmY8L3RkPjwv dHI+Cjx0cj48
dGQgY2xhc3M9ImUiPnBnc3FsLmlnbm9yZV9ub3RpY2U8L3RkPjx0ZCBjbGFz cz0idiI+T2Zm
PC90ZD48dGQgY2xhc3M9InYiPk9mZjwvdGQ+PC90cj4KPHRyPjx0ZCBjbGFz cz0iZSI+cGdz
cWwubG9nX25vdGljZTwvdGQ+PHRkIGNsYXNzPSJ2Ij5PZmY8L3RkPjx0ZCBj bGFzcz0idiI+
T2ZmPC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj5wZ3NxbC5tYXhfbGlu a3M8L3RkPjx0
ZCBjbGFzcz0idiI+VW5saW1pdGVkPC90ZD48dGQgY2xhc3M9InYiPlVubGlt aXRlZDwvdGQ+
PC90cj4KPHRyPjx0ZCBjbGFzcz0iZSI+cGdzcWwubWF4X3BlcnNpc3RlbnQ8 L3RkPjx0ZCBj
bGFzcz0idiI+VW5saW1pdGVkPC90ZD48dGQgY2xhc3M9InYiPlVubGltaXRl ZDwvdGQ+PC90
cj4KPC90YWJsZT48YnIgLz4KPGgyPjxhIG5hbWU9Im1vZHVsZV9SZWZsZWN0 aW9uIj5SZWZs
ZWN0aW9uPC9hPjwvaDI+Cjx0YWJsZSBib3JkZXI9IjAiIGNlbGxwYWRkaW5n PSIzIiB3aWR0
aD0iNjAwIj4KPHRyIGNsYXNzPSJoIj48dGg+UmVmbGVjdGlvbjwvdGg+PHRo PmVuYWJsZWQ8
L3RoPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPlZlcnNpb24gPC90ZD48dGQg Y2xhc3M9InYi
PiRJZDogcGhwX3JlZmxlY3Rpb24uYyx2IDEuMTY0LjIuMzMuMi40NSAyMDA3 LzA4LzIwIDE3
OjAxOjIyIHNlYmFzdGlhbiBFeHAgJCA8L3RkPjwvdHI+CjwvdGFibGU+PGJy IC8+CjxoMj48
YSBuYW1lPSJtb2R1bGVfc2Vzc2lvbiI+c2Vzc2lvbjwvYT48L2gyPgo8dGFi bGUgYm9yZGVy
PSIwIiBjZWxscGFkZGluZz0iMyIgd2lkdGg9IjYwMCI+Cjx0cj48dGQgY2xh c3M9ImUiPlNl
c3Npb24gU3VwcG9ydCA8L3RkPjx0ZCBjbGFzcz0idiI+ZW5hYmxlZCA8L3Rk PjwvdHI+Cjx0
cj48dGQgY2xhc3M9ImUiPlJlZ2lzdGVyZWQgc2F2ZSBoYW5kbGVycyA8L3Rk Pjx0ZCBjbGFz
cz0idiI+ZmlsZXMgdXNlciAgPC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJl Ij5SZWdpc3Rl
cmVkIHNlcmlhbGl6ZXIgaGFuZGxlcnMgPC90ZD48dGQgY2xhc3M9InYiPnBo cCBwaHBfYmlu
YXJ5IHdkZHggIDwvdGQ+PC90cj4KPC90YWJsZT48YnIgLz4KPHRhYmxlIGJv cmRlcj0iMCIg
Y2VsbHBhZGRpbmc9IjMiIHdpZHRoPSI2MDAiPgo8dHIgY2xhc3M9ImgiPjx0 aD5EaXJlY3Rp
dmU8L3RoPjx0aD5Mb2NhbCBWYWx1ZTwvdGg+PHRoPk1hc3RlciBWYWx1ZTwv dGg+PC90cj4K
PHRyPjx0ZCBjbGFzcz0iZSI+c2Vzc2lvbi5hdXRvX3N0YXJ0PC90ZD48dGQg Y2xhc3M9InYi
Pk9mZjwvdGQ+PHRkIGNsYXNzPSJ2Ij5PZmY8L3RkPjwvdHI+Cjx0cj48dGQg Y2xhc3M9ImUi
PnNlc3Npb24uYnVnX2NvbXBhdF80MjwvdGQ+PHRkIGNsYXNzPSJ2Ij5PZmY8 L3RkPjx0ZCBj
bGFzcz0idiI+T2ZmPC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj5zZXNz aW9uLmJ1Z19j
b21wYXRfd2FybjwvdGQ+PHRkIGNsYXNzPSJ2Ij5PbjwvdGQ+PHRkIGNsYXNz PSJ2Ij5Pbjwv
dGQ+PC90cj4KPHRyPjx0ZCBjbGFzcz0iZSI+c2Vzc2lvbi5jYWNoZV9leHBp cmU8L3RkPjx0
ZCBjbGFzcz0idiI+MTgwPC90ZD48dGQgY2xhc3M9InYiPjE4MDwvdGQ+PC90 cj4KPHRyPjx0
ZCBjbGFzcz0iZSI+c2Vzc2lvbi5jYWNoZV9saW1pdGVyPC90ZD48dGQgY2xh c3M9InYiPm5v
Y2FjaGU8L3RkPjx0ZCBjbGFzcz0idiI+bm9jYWNoZTwvdGQ+PC90cj4KPHRy Pjx0ZCBjbGFz
cz0iZSI+c2Vzc2lvbi5jb29raWVfZG9tYWluPC90ZD48dGQgY2xhc3M9InYi PjxpPm5vIHZh
bHVlPC9pPjwvdGQ+PHRkIGNsYXNzPSJ2Ij48aT5ubyB2YWx1ZTwvaT48L3Rk PjwvdHI+Cjx0
cj48dGQgY2xhc3M9ImUiPnNlc3Npb24uY29va2llX2h0dHBvbmx5PC90ZD48 dGQgY2xhc3M9
ImUiPnNlc3Npb24uY29va2llX2xpZmV0aW1lPC90ZD48dGQgY2xhc3M9InYi PjA8L3RkPjx0
ZCBjbGFzcz0idiI+MDwvdGQ+PC90cj4KPHRyPjx0ZCBjbGFzcz0iZSI+c2Vz c2lvbi5jb29r
aWVfcGF0aDwvdGQ+PHRkIGNsYXNzPSJ2Ij4vPC90ZD48dGQgY2xhc3M9InYi Pi88L3RkPjwv
dHI+Cjx0cj48dGQgY2xhc3M9ImUiPnNlc3Npb24uY29va2llX3NlY3VyZTwv dGQ+PHRkIGNs
YXNzPSJlIj5zZXNzaW9uLmVudHJvcHlfZmlsZTwvdGQ+PHRkIGNsYXNzPSJ2 Ij48aT5ubyB2
YWx1ZTwvaT48L3RkPjx0ZCBjbGFzcz0idiI+PGk+bm8gdmFsdWU8L2k+PC90 ZD48L3RyPgo8
dHI+PHRkIGNsYXNzPSJlIj5zZXNzaW9uLmVudHJvcHlfbGVuZ3RoPC90ZD48 dGQgY2xhc3M9
InYiPjA8L3RkPjx0ZCBjbGFzcz0idiI+MDwvdGQ+PC90cj4KPHRyPjx0ZCBj bGFzcz0iZSI+
c2Vzc2lvbi5nY19kaXZpc29yPC90ZD48dGQgY2xhc3M9InYiPjEwMDA8L3Rk Pjx0ZCBjbGFz
cz0idiI+MTAwMDwvdGQ+PC90cj4KPHRyPjx0ZCBjbGFzcz0iZSI+c2Vzc2lv bi5nY19tYXhs
aWZldGltZTwvdGQ+PHRkIGNsYXNzPSJ2Ij4xNDQwPC90ZD48dGQgY2xhc3M9 InYiPjE0NDA8
L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPnNlc3Npb24uZ2NfcHJvYmFi aWxpdHk8L3Rk
Pjx0ZCBjbGFzcz0idiI+MTwvdGQ+PHRkIGNsYXNzPSJ2Ij4xPC90ZD48L3Ry Pgo8dHI+PHRk
IGNsYXNzPSJlIj5zZXNzaW9uLmhhc2hfYml0c19wZXJfY2hhcmFjdGVyPC90 ZD48dGQgY2xh
c3M9InYiPjU8L3RkPjx0ZCBjbGFzcz0idiI+NTwvdGQ+PC90cj4KPHRyPjx0 ZCBjbGFzcz0i
ZSI+c2Vzc2lvbi5oYXNoX2Z1bmN0aW9uPC90ZD48dGQgY2xhc3M9InYiPjA8 L3RkPjx0ZCBj
bGFzcz0idiI+MDwvdGQ+PC90cj4KPHRyPjx0ZCBjbGFzcz0iZSI+c2Vzc2lv bi5uYW1lPC90
ZD48dGQgY2xhc3M9InYiPlBIUFNFU1NJRDwvdGQ+PHRkIGNsYXNzPSJ2Ij5Q SFBTRVNTSUQ8
L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPnNlc3Npb24ucmVmZXJlcl9j aGVjazwvdGQ+
dmFsdWU8L2k+PC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj5zZXNzaW9u LnNhdmVfaGFu
ZGxlcjwvdGQ+PHRkIGNsYXNzPSJ2Ij5maWxlczwvdGQ+PHRkIGNsYXNzPSJ2 Ij5maWxlczwv
dGQ+PC90cj4KPHRyPjx0ZCBjbGFzcz0iZSI+c2Vzc2lvbi5zYXZlX3BhdGg8 L3RkPjx0ZCBj
bGFzcz0idiI+YzpcYXBhY2hlXHBocFx0ZW1wXHNlc3Npb248L3RkPjx0ZCBj bGFzcz0idiI+
YzpcYXBhY2hlXHBocFx0ZW1wXHNlc3Npb248L3RkPjwvdHI+Cjx0cj48dGQg Y2xhc3M9ImUi
PnNlc3Npb24uc2VyaWFsaXplX2hhbmRsZXI8L3RkPjx0ZCBjbGFzcz0idiI+ cGhwPC90ZD48
dGQgY2xhc3M9InYiPnBocDwvdGQ+PC90cj4KPHRyPjx0ZCBjbGFzcz0iZSI+ c2Vzc2lvbi51
c2VfY29va2llczwvdGQ+PHRkIGNsYXNzPSJ2Ij5PbjwvdGQ+PHRkIGNsYXNz PSJ2Ij5Pbjwv
dGQ+PC90cj4KPHRyPjx0ZCBjbGFzcz0iZSI+c2Vzc2lvbi51c2Vfb25seV9j b29raWVzPC90
cj48dGQgY2xhc3M9ImUiPnNlc3Npb24udXNlX3RyYW5zX3NpZDwvdGQ+PHRk IGNsYXNzPSJ2
Ij4wPC90ZD48dGQgY2xhc3M9InYiPjA8L3RkPjwvdHI+CjwvdGFibGU+PGJy IC8+CjxoMj48
YSBuYW1lPSJtb2R1bGVfU2ltcGxlWE1MIj5TaW1wbGVYTUw8L2E+PC9oMj4K PHRhYmxlIGJv
aD5TaW1wbGV4bWwgc3VwcG9ydDwvdGg+PHRoPmVuYWJsZWQ8L3RoPjwvdHI+ Cjx0cj48dGQg
Y2xhc3M9ImUiPlJldmlzaW9uIDwvdGQ+PHRkIGNsYXNzPSJ2Ij4kUmV2aXNp b246IDEuMTUx
LjIuMjIuMi4zNSAkIDwvdGQ+PC90cj4KPHRyPjx0ZCBjbGFzcz0iZSI+U2No ZW1hIHN1cHBv
cnQgPC90ZD48dGQgY2xhc3M9InYiPmVuYWJsZWQgPC90ZD48L3RyPgo8L3Rh YmxlPjxiciAv
Pgo8aDI+PGEgbmFtZT0ibW9kdWxlX1NQTCI+U1BMPC9hPjwvaDI+Cjx0YWJs ZSBib3JkZXI9
IjAiIGNlbGxwYWRkaW5nPSIzIiB3aWR0aD0iNjAwIj4KPHRyIGNsYXNzPSJo Ij48dGg+U1BM
IHN1cHBvcnQ8L3RoPjx0aD5lbmFibGVkPC90aD48L3RyPgo8dHI+PHRkIGNs YXNzPSJlIj5J
bnRlcmZhY2VzIDwvdGQ+PHRkIGNsYXNzPSJ2Ij5Db3VudGFibGUsIE91dGVy SXRlcmF0b3Is
IFJlY3Vyc2l2ZUl0ZXJhdG9yLCBTZWVrYWJsZUl0ZXJhdG9yLCBTcGxPYnNl cnZlciwgU3Bs
U3ViamVjdCA8L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPkNsYXNzZXMg PC90ZD48dGQg
Y2xhc3M9InYiPkFwcGVuZEl0ZXJhdG9yLCBBcnJheUl0ZXJhdG9yLCBBcnJh eU9iamVjdCwg
QmFkRnVuY3Rpb25DYWxsRXhjZXB0aW9uLCBCYWRNZXRob2RDYWxsRXhjZXB0 aW9uLCBDYWNo
aW5nSXRlcmF0b3IsIERpcmVjdG9yeUl0ZXJhdG9yLCBEb21haW5FeGNlcHRp b24sIEVtcHR5
SXRlcmF0b3IsIEZpbHRlckl0ZXJhdG9yLCBJbmZpbml0ZUl0ZXJhdG9yLCBJ bnZhbGlkQXJn
dW1lbnRFeGNlcHRpb24sIEl0ZXJhdG9ySXRlcmF0b3IsIExlbmd0aEV4Y2Vw dGlvbiwgTGlt
aXRJdGVyYXRvciwgTG9naWNFeGNlcHRpb24sIE5vUmV3aW5kSXRlcmF0b3Is IE91dE9mQm91
bmRzRXhjZXB0aW9uLCBPdXRPZlJhbmdlRXhjZXB0aW9uLCBPdmVyZmxvd0V4 Y2VwdGlvbiwg
UGFyZW50SXRlcmF0b3IsIFJhbmdlRXhjZXB0aW9uLCBSZWN1cnNpdmVBcnJh eUl0ZXJhdG9y
LCBSZWN1cnNpdmVDYWNoaW5nSXRlcmF0b3IsIFJlY3Vyc2l2ZURpcmVjdG9y eUl0ZXJhdG9y
LCBSZWN1cnNpdmVGaWx0ZXJJdGVyYXRvciwgUmVjdXJzaXZlSXRlcmF0b3JJ dGVyYXRvciwg
UmVjdXJzaXZlUmVnZXhJdGVyYXRvciwgUmVnZXhJdGVyYXRvciwgUnVudGlt ZUV4Y2VwdGlv
biwgU2ltcGxlWE1MSXRlcmF0b3IsIFNwbEZpbGVJbmZvLCBTcGxGaWxlT2Jq ZWN0LCBTcGxP
YmplY3RTdG9yYWdlLCBTcGxUZW1wRmlsZU9iamVjdCwgVW5kZXJmbG93RXhj ZXB0aW9uLCBV
bmV4cGVjdGVkVmFsdWVFeGNlcHRpb24gPC90ZD48L3RyPgo8L3RhYmxlPjxi ciAvPgo8aDI+
PGEgbmFtZT0ibW9kdWxlX3N0YW5kYXJkIj5zdGFuZGFyZDwvYT48L2gyPgo8 dGFibGUgYm9y
PlJlZ2V4IExpYnJhcnkgPC90ZD48dGQgY2xhc3M9InYiPkJ1bmRsZWQgbGli cmFyeSBlbmFi
bGVkIDwvdGQ+PC90cj4KPHRyPjx0ZCBjbGFzcz0iZSI+RHluYW1pYyBMaWJy YXJ5IFN1cHBv
cnQgPC90ZD48dGQgY2xhc3M9InYiPmVuYWJsZWQgPC90ZD48L3RyPgo8dHI+ PHRkIGNsYXNz
PSJlIj5JbnRlcm5hbCBTZW5kbWFpbCBTdXBwb3J0IGZvciBXaW5kb3dzIDwv dGQ+PHRkIGNs
YXNzPSJ2Ij5lbmFibGVkIDwvdGQ+PC90cj4KPC90YWJsZT48YnIgLz4KPHRh YmxlIGJvcmRl
cj0iMCIgY2VsbHBhZGRpbmc9IjMiIHdpZHRoPSI2MDAiPgo8dHIgY2xhc3M9 ImgiPjx0aD5E
aXJlY3RpdmU8L3RoPjx0aD5Mb2NhbCBWYWx1ZTwvdGg+PHRoPk1hc3RlciBW YWx1ZTwvdGg+
PC90cj4KPHRyPjx0ZCBjbGFzcz0iZSI+YXNzZXJ0LmFjdGl2ZTwvdGQ+PHRk IGNsYXNzPSJ2
Ij4xPC90ZD48dGQgY2xhc3M9InYiPjE8L3RkPjwvdHI+Cjx0cj48dGQgY2xh c3M9ImUiPmFz
c2VydC5iYWlsPC90ZD48dGQgY2xhc3M9InYiPjA8L3RkPjx0ZCBjbGFzcz0i diI+MDwvdGQ+
PC90cj4KPHRyPjx0ZCBjbGFzcz0iZSI+YXNzZXJ0LmNhbGxiYWNrPC90ZD48 dGQgY2xhc3M9
InYiPjxpPm5vIHZhbHVlPC9pPjwvdGQ+PHRkIGNsYXNzPSJ2Ij48aT5ubyB2 YWx1ZTwvaT48
L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPmFzc2VydC5xdWlldF9ldmFs PC90ZD48dGQg
cz0iZSI+YXNzZXJ0Lndhcm5pbmc8L3RkPjx0ZCBjbGFzcz0idiI+MTwvdGQ+ PHRkIGNsYXNz
PSJ2Ij4xPC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj5hdXRvX2RldGVj dF9saW5lX2Vu
ZGluZ3M8L3RkPjx0ZCBjbGFzcz0idiI+MDwvdGQ+PHRkIGNsYXNzPSJ2Ij4w PC90ZD48L3Ry
Pgo8dHI+PHRkIGNsYXNzPSJlIj5kZWZhdWx0X3NvY2tldF90aW1lb3V0PC90 ZD48dGQgY2xh
c3M9InYiPjYwPC90ZD48dGQgY2xhc3M9InYiPjYwPC90ZD48L3RyPgo8dHI+ PHRkIGNsYXNz
PSJlIj5zYWZlX21vZGVfYWxsb3dlZF9lbnZfdmFyczwvdGQ+PHRkIGNsYXNz PSJ2Ij5QSFBf
PC90ZD48dGQgY2xhc3M9InYiPlBIUF88L3RkPjwvdHI+Cjx0cj48dGQgY2xh c3M9ImUiPnNh
ZmVfbW9kZV9wcm90ZWN0ZWRfZW52X3ZhcnM8L3RkPjx0ZCBjbGFzcz0idiI+ TERfTElCUkFS
WV9QQVRIPC90ZD48dGQgY2xhc3M9InYiPkxEX0xJQlJBUllfUEFUSDwvdGQ+ PC90cj4KPHRy
Pjx0ZCBjbGFzcz0iZSI+dXJsX3Jld3JpdGVyLnRhZ3M8L3RkPjx0ZCBjbGFz cz0idiI+YT1o
cmVmLGFyZWE9aHJlZixmcmFtZT1zcmMsaW5wdXQ9c3JjLGZvcm09ZmFrZWVu dHJ5PC90ZD48
dGQgY2xhc3M9InYiPmE9aHJlZixhcmVhPWhyZWYsZnJhbWU9c3JjLGlucHV0 PXNyYyxmb3Jt
PWZha2VlbnRyeTwvdGQ+PC90cj4KPHRyPjx0ZCBjbGFzcz0iZSI+dXNlcl9h Z2VudDwvdGQ+
dmFsdWU8L2k+PC90ZD48L3RyPgo8L3RhYmxlPjxiciAvPgo8aDI+PGEgbmFt ZT0ibW9kdWxl
X3Rva2VuaXplciI+dG9rZW5pemVyPC9hPjwvaDI+Cjx0YWJsZSBib3JkZXI9 IjAiIGNlbGxw
YWRkaW5nPSIzIiB3aWR0aD0iNjAwIj4KPHRyPjx0ZCBjbGFzcz0iZSI+VG9r ZW5pemVyIFN1
cHBvcnQgPC90ZD48dGQgY2xhc3M9InYiPmVuYWJsZWQgPC90ZD48L3RyPgo8 L3RhYmxlPjxi
ciAvPgo8aDI+PGEgbmFtZT0ibW9kdWxlX3dkZHgiPndkZHg8L2E+PC9oMj4K PHRhYmxlIGJv
aD5XRERYIFN1cHBvcnQ8L3RoPjx0aD5lbmFibGVkPC90aD48L3RyPgo8dHI+ PHRkIGNsYXNz
PSJlIj5XRERYIFNlc3Npb24gU2VyaWFsaXplciA8L3RkPjx0ZCBjbGFzcz0i diI+ZW5hYmxl
ZCA8L3RkPjwvdHI+CjwvdGFibGU+PGJyIC8+CjxoMj48YSBuYW1lPSJtb2R1 bGVfeGRlYnVn
Ij54ZGVidWc8L2E+PC9oMj4KPHRhYmxlIGJvcmRlcj0iMCIgY2VsbHBhZGRp bmc9IjMiIHdp
ZHRoPSI2MDAiPgo8dHIgY2xhc3M9ImgiPjx0aD54ZGVidWcgc3VwcG9ydDwv dGg+PHRoPmVu
YWJsZWQ8L3RoPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPlZlcnNpb24gPC90 ZD48dGQgY2xh
c3M9InYiPjIuMC4wIDwvdGQ+PC90cj4KPC90YWJsZT48YnIgLz4KPHRhYmxl IGJvcmRlcj0i
MCIgY2VsbHBhZGRpbmc9IjMiIHdpZHRoPSI2MDAiPgo8dHIgY2xhc3M9Imgi Pjx0aD5TdXBw
b3J0ZWQgcHJvdG9jb2xzPC90aD48dGg+UmV2aXNpb248L3RoPjwvdHI+Cjx0 cj48dGQgY2xh
c3M9ImUiPkRCR3AgLSBDb21tb24gRGVCdUdnZXIgUHJvdG9jb2wgPC90ZD48 dGQgY2xhc3M9
InYiPiRSZXZpc2lvbjogMS4xMjUgJCA8L3RkPjwvdHI+Cjx0cj48dGQgY2xh c3M9ImUiPkdE
QiAtIEdOVSBEZWJ1Z2dlciBwcm90b2NvbCA8L3RkPjx0ZCBjbGFzcz0idiI+ JFJldmlzaW9u
OiAxLjg3ICQgPC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj5QSFAzIC0g UEhQIDMgRGVi
dWdnZXIgcHJvdG9jb2wgPC90ZD48dGQgY2xhc3M9InYiPiRSZXZpc2lvbjog MS4yMiAkIDwv
dGQ+PC90cj4KPC90YWJsZT48YnIgLz4KPHRhYmxlIGJvcmRlcj0iMCIgY2Vs bHBhZGRpbmc9
IjMiIHdpZHRoPSI2MDAiPgo8dHIgY2xhc3M9ImgiPjx0aD5EaXJlY3RpdmU8 L3RoPjx0aD5M
b2NhbCBWYWx1ZTwvdGg+PHRoPk1hc3RlciBWYWx1ZTwvdGg+PC90cj4KPHRy Pjx0ZCBjbGFz
cz0iZSI+eGRlYnVnLmF1dG9fdHJhY2U8L3RkPjx0ZCBjbGFzcz0idiI+T2Zm PC90ZD48dGQg
Y2xhc3M9InYiPk9mZjwvdGQ+PC90cj4KPHRyPjx0ZCBjbGFzcz0iZSI+eGRl YnVnLmNvbGxl
Y3RfaW5jbHVkZXM8L3RkPjx0ZCBjbGFzcz0idiI+T248L3RkPjx0ZCBjbGFz cz0idiI+T248
L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPnhkZWJ1Zy5jb2xsZWN0X3Bh cmFtczwvdGQ+
PHRkIGNsYXNzPSJ2Ij4wPC90ZD48dGQgY2xhc3M9InYiPjA8L3RkPjwvdHI+ Cjx0cj48dGQg
Y2xhc3M9ImUiPnhkZWJ1Zy5jb2xsZWN0X3JldHVybjwvdGQ+PHRkIGNsYXNz PSJ2Ij5PZmY8
L3RkPjx0ZCBjbGFzcz0idiI+T2ZmPC90ZD48L3RyPgo8dHI+PHRkIGNsYXNz PSJlIj54ZGVi
dWcuY29sbGVjdF92YXJzPC90ZD48dGQgY2xhc3M9InYiPk9mZjwvdGQ+PHRk IGNsYXNzPSJ2
Ij5PZmY8L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPnhkZWJ1Zy5kZWZh dWx0X2VuYWJs
ZTwvdGQ+PHRkIGNsYXNzPSJ2Ij5PbjwvdGQ+PHRkIGNsYXNzPSJ2Ij5Pbjwv dGQ+PC90cj4K
PHRyPjx0ZCBjbGFzcz0iZSI+eGRlYnVnLmR1bXAuQ09PS0lFPC90ZD48dGQg Y2xhc3M9InYi
PjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPnhkZWJ1Zy5kdW1wLkVOVjwvdGQ+ PHRkIGNsYXNz
PC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj54ZGVidWcuZHVtcC5GSUxF UzwvdGQ+PHRk
dWU8L2k+PC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj54ZGVidWcuZHVt cC5HRVQ8L3Rk
Pjx0ZCBjbGFzcz0idiI+PGk+bm8gdmFsdWU8L2k+PC90ZD48dGQgY2xhc3M9 InYiPjxpPm5v
IHZhbHVlPC9pPjwvdGQ+PC90cj4KPHRyPjx0ZCBjbGFzcz0iZSI+eGRlYnVn LmR1bXAuUE9T
VDwvdGQ+PHRkIGNsYXNzPSJ2Ij48aT5ubyB2YWx1ZTwvaT48L3RkPjx0ZCBj bGFzcz0idiI+
PGk+bm8gdmFsdWU8L2k+PC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj54 ZGVidWcuZHVt
cC5SRVFVRVNUPC90ZD48dGQgY2xhc3M9InYiPjxpPm5vIHZhbHVlPC9pPjwv dGQ+PHRkIGNs
YXNzPSJ2Ij48aT5ubyB2YWx1ZTwvaT48L3RkPjwvdHI+Cjx0cj48dGQgY2xh c3M9ImUiPnhk
ZWJ1Zy5kdW1wLlNFUlZFUjwvdGQ+PHRkIGNsYXNzPSJ2Ij48aT5ubyB2YWx1 ZTwvaT48L3Rk
Pjx0ZCBjbGFzcz0idiI+PGk+bm8gdmFsdWU8L2k+PC90ZD48L3RyPgo8dHI+ PHRkIGNsYXNz
PSJlIj54ZGVidWcuZHVtcC5TRVNTSU9OPC90ZD48dGQgY2xhc3M9InYiPjxp Pm5vIHZhbHVl
PC9pPjwvdGQ+PHRkIGNsYXNzPSJ2Ij48aT5ubyB2YWx1ZTwvaT48L3RkPjwv dHI+Cjx0cj48
dGQgY2xhc3M9ImUiPnhkZWJ1Zy5kdW1wX2dsb2JhbHM8L3RkPjx0ZCBjbGFz cz0idiI+T248
L3RkPjx0ZCBjbGFzcz0idiI+T248L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9 ImUiPnhkZWJ1
Zy5kdW1wX29uY2U8L3RkPjx0ZCBjbGFzcz0idiI+T248L3RkPjx0ZCBjbGFz cz0idiI+T248
L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPnhkZWJ1Zy5kdW1wX3VuZGVm aW5lZDwvdGQ+
PHRkIGNsYXNzPSJ2Ij5PZmY8L3RkPjx0ZCBjbGFzcz0idiI+T2ZmPC90ZD48 L3RyPgo8dHI+
PHRkIGNsYXNzPSJlIj54ZGVidWcuZXh0ZW5kZWRfaW5mbzwvdGQ+PHRkIGNs YXNzPSJ2Ij5P
bjwvdGQ+PHRkIGNsYXNzPSJ2Ij5PbjwvdGQ+PC90cj4KPHRyPjx0ZCBjbGFz cz0iZSI+eGRl
YnVnLmlkZWtleTwvdGQ+PHRkIGNsYXNzPSJ2Ij5NQURCT09LJDwvdGQ+PHRk IGNsYXNzPSJ2
Ij48aT5ubyB2YWx1ZTwvaT48L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUi PnhkZWJ1Zy5t
YW51YWxfdXJsPC90ZD48dGQgY2xhc3M9InYiPmh0dHA6Ly93d3cucGhwLm5l dDwvdGQ+PHRk
IGNsYXNzPSJ2Ij5odHRwOi8vd3d3LnBocC5uZXQ8L3RkPjwvdHI+Cjx0cj48 dGQgY2xhc3M9
ImUiPnhkZWJ1Zy5tYXhfbmVzdGluZ19sZXZlbDwvdGQ+PHRkIGNsYXNzPSJ2 Ij4xMDA8L3Rk
Pjx0ZCBjbGFzcz0idiI+MTAwPC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJl Ij54ZGVidWcu
cHJvZmlsZXJfYWdncmVnYXRlPC90ZD48dGQgY2xhc3M9InYiPk9mZjwvdGQ+ PHRkIGNsYXNz
PSJ2Ij5PZmY8L3RkPjwvdHI+Cjx0cj48dGQgY2xhc3M9ImUiPnhkZWJ1Zy5w cm9maWxlcl9h
cHBlbmQ8L3RkPjx0ZCBjbGFzcz0idiI+T2ZmPC90ZD48dGQgY2xhc3M9InYi Pk9mZjwvdGQ+
PC90cj4KPHRyPjx0ZCBjbGFzcz0iZSI+eGRlYnVnLnByb2ZpbGVyX2VuYWJs ZTwvdGQ+PHRk
IGNsYXNzPSJ2Ij5PZmY8L3RkPjx0ZCBjbGFzcz0idiI+T2ZmPC90ZD48L3Ry Pgo8dHI+PHRk
IGNsYXNzPSJlIj54ZGVidWcucHJvZmlsZXJfZW5hYmxlX3RyaWdnZXI8L3Rk Pjx0ZCBjbGFz
cz0idiI+T2ZmPC90ZD48dGQgY2xhc3M9InYiPk9mZjwvdGQ+PC90cj4KPHRy Pjx0ZCBjbGFz
cz0iZSI+eGRlYnVnLnByb2ZpbGVyX291dHB1dF9kaXI8L3RkPjx0ZCBjbGFz cz0idiI+L3Rt
cDwvdGQ+PHRkIGNsYXNzPSJ2Ij4vdG1wPC90ZD48L3RyPgo8dHI+PHRkIGNs YXNzPSJlIj54
ZGVidWcucHJvZmlsZXJfb3V0cHV0X25hbWU8L3RkPjx0ZCBjbGFzcz0idiI+ Y2FjaGVncmlu
ZC5vdXQuJXA8L3RkPjx0ZCBjbGFzcz0idiI+Y2FjaGVncmluZC5vdXQuJXA8 L3RkPjwvdHI+
Cjx0cj48dGQgY2xhc3M9ImUiPnhkZWJ1Zy5yZW1vdGVfYXV0b3N0YXJ0PC90 ZD48dGQgY2xh
c3M9InYiPk9mZjwvdGQ+PHRkIGNsYXNzPSJ2Ij5PZmY8L3RkPjwvdHI+Cjx0 cj48dGQgY2xh
c3M9ImUiPnhkZWJ1Zy5yZW1vdGVfZW5hYmxlPC90ZD48dGQgY2xhc3M9InYi Pk9uPC90ZD48
dGQgY2xhc3M9InYiPk9uPC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj54 ZGVidWcucmVt
b3RlX2hhbmRsZXI8L3RkPjx0ZCBjbGFzcz0idiI+ZGJncDwvdGQ+PHRkIGNs YXNzPSJ2Ij5k
YmdwPC90ZD48L3RyPgo8dHI+PHRkIGNsYXNzPSJlIj54ZGVidWcucmVtb3Rl X2hvc3Q8L3Rk
Pjx0ZCBjbGFzcz0idiI+MTI3LjAuMC4xPC90ZD48dGQgY2xhc3M9InYiPjEy Ny4wLjAuMTwv<
Re: "waiting for XDebug session" problem [message #55458 is a reply to message #55393] Thu, 27 September 2007 05:52 Go to previous messageGo to next message
Actually, i'm not sure if i understand what you mean. That's how my
"PHP Web Page" properties look like:
http://www.imagehosting.com/show.php/1186572_screen.jpg.html
> should
> be any
> Dave Kelsey
>>> Cheers
>>> Dave Kelsey
>>> Alex wrote:
>>>> Thank you Dave,
>>>> Any other ideas?
>>>>> Dave Kelsey
>>>>>> is:
>>>>>> Apache : 2.2.4
>>>>>> PHP : 5.2.4
>>>>>> eclipse : 3.3.0
>>>>>> wrong?
>>>>>> Cheers,
>>>>>> Alex
Re: "waiting for XDebug session" problem [message #55486 is a reply to message #55428] Thu, 27 September 2007 06:44 Go to previous messageGo to next message
ok, I see you have xdebug logging turned on is anything being output to
c:\apache\logs\xdebug.log ?
Also try executing the command "netstat -a -b" and reporting which ports
eclipse.exe is listening on (the defaults would be 9000, 10000).
The problem is that PDT is waiting for a socket connection from the web server. XDebug
initiates that socket connection, so so long as
1. PDT is listening on the same port as XDebug wants to connect to (netstat -a -b)
2. XDebug loads ok and attempts to establish a connection (xdebug log)
3. nothing stops the connection from occuring (eg a firewall).
Then the session should be established.
Dave Kelsey
>> phpinfo() output ?
etc...
Re: "waiting for XDebug session" problem [message #55541 is a reply to message #55486] Thu, 27 September 2007 07:56 Go to previous messageGo to next message
1. PDT is listening. Here is netstat output:
TCP 0.0.0.0:9000 pc:0 LISTENING
[eclipse.exe]
TCP 0.0.0.0:10000 pc:0 LISTENING
[eclipse.exe]
2. File xdebug.log does not exist - i don't really know why - probably
it doesn't come so far?
3. Firewall is off.
> server. XDebug
> (netstat -a -b)
> Dave Kelsey
>>> phpinfo() output ?
> etc...
Re: "waiting for XDebug session" problem [message #55594 is a reply to message #55541] Thu, 27 September 2007 08:23 Go to previous messageGo to next message
Hi Alex, ok from this it would seem that for some reason xdebug is never trying to connect
to PDT.
When you do a web launch, a web browser (either firefox, IE or Eclipse internal)
should be launched and your URL issued with the following appended
?XDEBUG_SESSION_START=ECLIPSE_DBGP&KEY=(some number)
If a web browser isn't launching then look in the preferences to see what it is selected to
and try changing to a different browser.
If it is launching but the URL doesn't have the extra XDEBUG_SESSION_START then let me know.
If that is ok and the request definitely is going to the web server, then for some
reason xdebug is not seeing the XDEBUG_SESSION_START in the URL and is never initiating the
debug session.
Dave Kelsey
> [eclipse.exe]
> [eclipse.exe]
> 3. Firewall is off.
>> web server. XDebug
>> (netstat -a -b)
>> Dave Kelsey
>>>> phpinfo() output ?
>> etc...
Re: "waiting for XDebug session" problem [message #55647 is a reply to message #55594] Thu, 27 September 2007 08:41 Go to previous message
Originally posted by: ad.tis-net.de
That's it!
Thank you Dave! The Problem was the wrong path to Firefox browser in
eclipse preferences(i copied eclipse from my old system and "Program
Files" folder was called "Programm" there. And i've totally forgotten that.
One more time thx for your help.
Alex
> trying to connect
> to PDT.
> internal)
> then for some
> debug session.
> Dave Kelsey
>> [eclipse.exe]
>> [eclipse.exe]
>> 3. Firewall is off.
>>> web server. XDebug
>>> (netstat -a -b)
>>> Dave Kelsey
>>> etc...
Previous Topic:Bugs: auto-formatting and auto-completion
Next Topic:PDT All-in-one build - what am I missing?
Current Time: Mon Jul 14 23:27:39 EDT 2025
Powered by FUDForum. Page generated in 0.15008 seconds
