Home » Modeling » M2T (model-to-text transformation) » MTL & GMF
MTL & GMF [message #54990] Fri, 09 January 2009 03:29 Go to next message
I am a newbie to MTL and GMF, so pls excuse me if I am off the
topic here.
From my understanding, it will be possible to use MTL to build
code generators (like C++, Java etc) that generate source code
from EMF based data models (such as UML2 that most Eclipse based
UML editors are based upon).
As far as I can understand, the code generator will then be
able to look at the data in EMF and adapt the generated code
dependent on the data settings inside the EMF datastructures
(UML2 in this case).
But what happens with UML products that add diagram specific
propery settings, such as the line color or font setting that
exist for many GUI objects in GMF generated diagram editors?
As far as I can understand, such GUI property settings are
purely part of the diagram editor, not the underlying EMF
datamodel (UML2).
Will an MTL based code generator be able to look at also these
(GMF/diagram specific) property settings and adapt the code
generation dependent on these GUI settings too?
Or do I need to create a UML profile to store custom specific
settings that can modify the behaviour in the code generator?
Or how do I otherwise add my own GUI property settings, that
can affect the code generator that is built using MTL (without
rewriting UML2)?
I.e, what I want to do is to use the EMF-based UML2 datastructures
together with a GMF generated diagram editor, and create a
code generator that modify its behaviour dependent on GUI settings
which does not exist in the origial EMF model (I don't want to
touch UML2 in this case).
Any information on this would be most helpful!
Kind regards,
Johan
Re: MTL & GMF [message #55017 is a reply to message #54990] Fri, 09 January 2009 04:48 Go to previous messageGo to next message
--------------060606020804070406030503
Hi Johan,
I didn't really understand if you're trying to
1) generate code from an UML model created by a GMF modeler for UML files
or
2) generate code from an UML meta-model for which you created a GMF modeler
In both cases, there is a way to access both the UML data and the GUI
information. For 1), you could create MTL generators on the GMF diagram
which allows you to navigate to the UML model while having your GUI
information at hand in the diagram.
For 2), you'd need to create your generators targetting the gmfgen so
that you can access all of : the UML meta-model, the gmfgraph, the
gmftool ... that might be a lot of work :).
If neither of those answer the question, feel free to correct my
interpretations.
Laurent
Johan a
Re: MTL & GMF [message #55044 is a reply to message #55017] Fri, 09 January 2009 05:51 Go to previous messageGo to next message
Originally posted by: johannes.nel.gmail.com
Johan,
my understanding:
you wants to create a (uml/ecore etc...) model from a gmf editor, and
that gmf editor would also store information affecting the main model.
This meta-model data you want to retrieve from the GMG gui.
if this is correct then i would consider a slight change in approach.
the information the gui stores (which affects the domain model) should
rather be stored in a seperate model, i would consider
(http://martinfowler.com/eaaDev/PresentationModel.html)
or some variation of it
there are a few listed at the bottom of this:
http://richnewman.wordpress.com/2008/02/26/model-view-presen ter-variations-on-the-basic-pattern-introduction-to-cabscsf- part-24/
then (from my limited jet based perspecitive), serializing that
meta-model to xml and loading it into your transformation as well
instead of getting it from the plugin.
laurent Goubet wrote:
> Hi Johan,
> or
> interpretations.
> Laurent
> Johan a écrit :
>> I am a newbie to MTL and GMF, so pls excuse me if I am off the topic
>> here.
>> propery settings, such as the line color or font setting that exist
>> datamodel (UML2).
>> (GMF/diagram specific) property settings and adapt the code generation
>> Or do I need to create a UML profile to store custom specific settings
>> rewriting UML2)?
>> together with a GMF generated diagram editor, and create a code
>> Kind regards,
>> Johan
Re: MTL & GMF [message #55071 is a reply to message #55044] Fri, 09 January 2009 08:25 Go to previous message
Thanks for the information! What I want to do is to create a code generator
for an UML product, there the code generator can adapt its behaviour based
on both the UML model stored in UML2 (which is EMF generated) as well as
some UML diagram editor (GMF generated, such as UML2Tools) specific GUI
settings which is not known to the UML2 but might be, say UML2Tools,
specific.
I will look into your suggestions. Thanks!
/Johan
Previous Topic:[bug?] problem with xsi:nil
Next Topic:append to an existing file using ws:file
Current Time: Wed May 07 21:45:34 EDT 2025
Powered by FUDForum. Page generated in 0.05128 seconds
