Home » Language IDEs » PHP Development Tools (PDT) » Zend Debugger and breakpoints
Zend Debugger and breakpoints [message #54978] Wed, 26 September 2007 04:22 Go to next message
--------------090408070206060100000301
I use pdt 1.0,XP,php5.0.5/apache2.0.59,
and I have problems with Zend debugger...
I use zenddebugger.dll from
http://downloads.zend.com/pdt/server-debugger/ZendDebugger-5 .2.10-cygwin_nt-i386.tar.gz
When I debug,debug session starts, but debugger doesn't stop at breakpoints.
Here is php.ini:
zend_extension_ts=C:/php/ZendDebugger.dll
zend_debugger.allow_hosts=127.0.0.1
zend_debugger.expose_remotely=always
In phpinfo() everything is regular. I have zend debugger section.
I attached my .log file.
It seems that i have some errors for debugger.
name=".log"
Content-Disposition: inline;
filename=".log"
!ENTRY org.eclipse.php.debug.core 4 10001 2007-09-26 09:51:41.734
!MESSAGE PHPDebug plugin internal error
!STACK 0
java.lang.StringIndexOutOfBoundsException: String index out of range: -21
at java.lang.String.substring(Unknown Source)
at org.eclipse.php.internal.debug.core.zend.model.ServerDebugHa ndler.parsingErrorOccured(Unknown Source)
at org.eclipse.php.internal.debug.core.zend.debugger.RemoteDebu gger.handleNotification(Unknown Source)
at org.eclipse.php.internal.debug.core.zend.communication.Debug ConnectionThread$InputMessageHandler.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
!STACK 0
!ENTRY org.eclipse.php.debug.core 4 10001 2007-09-26 10:06:37.906
!STACK 0
!STACK 0
!ENTRY org.eclipse.php.debug.core 4 10001 2007-09-26 10:07:10.203
!STACK 0
!ENTRY org.eclipse.php.debug.core 4 10001 2007-09-26 10:07:10.312
!STACK 0
!ENTRY org.eclipse.php.debug.core 4 10001 2007-09-26 10:08:38.453
!STACK 0
!STACK 0
--------------090408070206060100000301--
Re: Zend Debugger and breakpoints [message #55006 is a reply to message #54978] Wed, 26 September 2007 04:39 Go to previous messageGo to next message
korso3@gmail.com wrote:
> breakpoints.
> Here is php.ini:
Some addition to my prev post ...
When I "uncheck" in debugger tab option "Break at first line"
debugger doesn't stop at all.
Re: Zend Debugger and breakpoints [message #56506 is a reply to message #54978] Tue, 02 October 2007 13:32 Go to previous messageGo to next message
Originally posted by: at465.msn.com
Not sure if this helps, but I ran into the same problem myself. I found
out that it was that the plugin expects the project root to be the http
root.
My project structure had the http root as a subfolder of the project root.
If the http root isn't the same point as the project root, then the
plugin can't correctly inform the debugger which file the breakpoint is in.
I ended up hacking the source to make the plugin work at a subfolder level.
Re: Zend Debugger and breakpoints [message #56797 is a reply to message #56506] Thu, 04 October 2007 03:14 Go to previous message
> root.
"I found
root.
is in."
Same thing :-). I completely agree with you.
My http root is different than project root.
httproot = projectroot/webroot
I just try a little hack.
I made new php file which include my actual index.php, and new file is
in projectroot. But this also didn't work.
Can you tell me, please, how you solved this problem?
Previous Topic:Identical files when debugging with xdebug in PDT 1.0
Next Topic:incorrect xdebug launch url
Current Time: Sun Jul 27 02:06:03 EDT 2025
Powered by FUDForum. Page generated in 0.04132 seconds
