Home » Archived » M2M (model-to-model transformation) » Load reference Problem
Load reference Problem [message #54796] |
Thu, 26 July 2007 03:53  |
Originally posted by: ali.akar.tni-software.com
I' working on a transformation from AADL to HRT-UML2 under ATL.
For HRT-UML2, I use the metamodel loaded in memory while for AADL, I use the
..ecore which consists of 7 packages.
The input file of the transformation have an aael extension. It is obtained,
by a conversion under OSATE, starting from the file with aaxl extension.
The problem, that ATL does not succeed in charging the references or to
solve them.
For example in the following expression: <processImpl name= " GesVol "
compType= " #//@processType.0 "/>
when I want to get the component type, which is the comType, ATL returns an
empty list!!
Any one can help me ??
A AKAR
[ATL]Re: Load reference Problem [message #55063 is a reply to message #54796] |
Fri, 27 July 2007 07:56   |
> solve them.
> empty list!!
> A AKAR
First, could you prefix you subject with [ATL], next time (I did it for
that post) ? Thanks.
Then I'm not sure, but the problem seems to be in your input model, from
the compType= " #//@processType.0 " expression. Generally those kind of
references needs to indicate a filename before the #. Perhaps the
problem comes from the OSATE conversion.
In order to ensure that, could you also post the atl fragment where you
try to get that reference ?
William Piers
MDA Consultant, Obeo (http://www.obeo.fr)
Re: [ATL]Re: [ATL]Re: Load reference Problem [message #55152 is a reply to message #55123] |
Fri, 27 July 2007 10:55   |
Ali a écrit :
> Hello,
> I thought that the problem is in the OSATE conversion, so I changed the file
> extension from aael to xmi, when I open the file, I can see the referenced
> objects in the Eclipse property sheet.so I estimate that the problem isn't
> in the reference, but in the way that ATL resolve them ??
> below is the ATL rule :
> rule ProcessImpl2RCMcomponent {
> from
> e : AADL!ProcessImpl
> to
> comp : RCM!RCMcomponent (
> name <- if e.name.oclIsUndefined() then 'myRCMcomponent' else
> e.name + '_AP' endif,
> providedTypes <- thisModule.resolveTemp(e.compType,'e')
> do {
> e.compType.debug('compType'); -- result is OCLundefined !!!
> A AKAR
> "William Piers" <william.piers@obeo.fr> a écrit dans le message de news:
> f8cmh4$74m$1@build.eclipse.org...
>>> the .ecore which consists of 7 packages.
>>> obtained, by a conversion under OSATE, starting from the file with aaxl
>>> extension.
>>> solve them.
>>> an empty list!!
>>> Thanks,
>>> A AKAR
>> Hello,
>> references needs to indicate a filename before the #. Perhaps the problem
>> Regards,
>> William Piers
Could you provide us the aael and aaxl files ? This will really help us
to understand the problem, and to check the conversion result.
Thanks in advance,
William Piers
[ATL]Re: Load reference Problem [message #55616 is a reply to message #54796] |
Wed, 01 August 2007 09:18   |
Originally posted by: lwrage.sei.cmu.edu
Ali,
you could try to use the metamodel uri (http:///AADL/core) as the AADL
metamodel and use the aaxl model files directly. For this to work you
need to have OSATE and ATL installed in the same eclipse instance.
- Lutz
Ali wrote, on 7/26/2007 3:53 AM:
> solve them.
> empty list!!
> A AKAR
Current Time: Wed Jul 30 16:13:34 EDT 2025
Powered by FUDForum. Page generated in 1.03789 seconds
