Home » Archived » BIRT » Fetching report parameter value
Fetching report parameter value [message #544080] Thu, 01 July 2010 10:33 Go to next message
Is there any way to fetch report parameter value?
For example, I have default parameter value in dataset, and I would like to fetch that value and show in column.
I tried with this:
myValue = params["Name"];
but doesn't work...
Re: Fetching report parameter value [message #544087 is a reply to message #544080] Thu, 01 July 2010 10:38 Go to previous messageGo to next message
There's not going to be a simple way. The value you want isn't a direct attribute of the parameter, it's part of the report design. There's probably an API call that will fetch it - someone more experienced in that area can address this.
Re: Fetching report parameter value [message #544113 is a reply to message #544080] Thu, 01 July 2010 11:28 Go to previous messageGo to next message
Is this a dataset parmeter or a report parameter.
myValue= params["Name"].value should work to retrieve the current report
parameter value. If you want the default value you could call the RE
API from script like :
var rr = reportContext.getReportRunnable();
var engine = rr.getReportEngine();
var tsk = engine.createGetParameterDefinitionTask( rr );
aaa = tsk.getDefaultValue("Name");
tsk.close();
Jason
On 7/1/2010 10:33 AM, mkrivic wrote:
> I tried with this:
> but doesn't work...
Re: Fetching report parameter value [message #544380 is a reply to message #544113] Fri, 02 July 2010 09:57 Go to previous messageGo to next message
Jason and Richard, thanks for your reply.
I would like if you could tell me one more thing:
how could I fetch some value in row during creation?
for example,
i know how to catch row value:
some_var = row["Name"];
now, how can I do this in reverse way:
example
row["Name"] = some_var;
Is this correct or...?
Re: Fetching report parameter value [message #544382 is a reply to message #544080] Fri, 02 July 2010 10:00 Go to previous messageGo to next message
It sounds like you want to replace the field value in that row with a different value. I'm not sure where that would be necessary. Do you really just want to display a different value on the final report? If you can explain what your full goal is for this question, people can have a better idea how to answer.
Re: Fetching report parameter value [message #544384 is a reply to message #544382] Fri, 02 July 2010 10:06 Go to previous messageGo to next message
I have two datasets binded to two different tables:
dataset1 and
dataset2
When I show dataset1 on report in table, on tableCreate event, I am fetching some values.
Then, each of that values I want to bind in dataset2 to be default value in some dataset parameter.
Is that possible?
Re: Fetching report parameter value [message #544410 is a reply to message #544080] Fri, 02 July 2010 11:17 Go to previous messageGo to next message
I'm still confused when you say you want to set the default parameter on dataset 2 based on data already retrieved from dataset 1 and used in table 1. BIRT prompts for all parameters at the same time.
Re: Fetching report parameter value [message #544489 is a reply to message #544410] Fri, 02 July 2010 16:46 Go to previous messageGo to next message
Richard, sorry if my explanation is confusing...
I''ll simplify:
Can I onCreate event on table row change some row value?
for example:
onCreate event on table row I want to change my data value:
ex:
if (this.getRowData().getExpressionValue("row[WI_ID]") == 2851){
row["WI_ID"] = 2852;
so, on row create I want to change data value...
Re: Fetching report parameter value [message #544492 is a reply to message #544080] Fri, 02 July 2010 16:56 Go to previous message
I wouldn't do it there unless there's something else referencing that data valye. If you're just trying to change the amount that shows on the report, I would do that with the Map property.
Previous Topic:Can't Refresh Chart rather than Re-Build and Render
Next Topic:Plot location
Current Time: Wed Jul 02 08:55:10 EDT 2025
Powered by FUDForum. Page generated in 0.11023 seconds
