Home » Eclipse Projects » Eclipse Platform » ANT and memory issue?
ANT and memory issue? [message #54781] Thu, 29 May 2003 15:09 Go to next message
Originally posted by: john.collard.aquila.com
I run Eclipse on a win2k box. The first time I compile my project using
ANT, the memory usage jumps about 40 meg. (and doesn't get released after
the compile is finished.) Each time I compile after that, memory usage
goes up between 2 meg and 5 meg., until eventually I get an out of memory
error and the application crashes.
Is there something I need to be doing to force garbage collection?
configuration changes? or is there a memory leak?
All help is appreciated.
John
Re: ANT and memory issue? [message #54862 is a reply to message #54781] Thu, 29 May 2003 16:07 Go to previous message
Please see https://bugs.eclipse.org/bugs/show_bug.cgi?id=24448
In the latest integration builds you can specify to run Ant in a separate
VM.
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=24129 for more details
HTH
Darins
"John Collard" <john.collard@aquila.com> wrote in message
news:bb5n5k$g9t$1@rogue.oti.com...
> John
Previous Topic:Ant, Eclipse Config and JRE
Next Topic:text editor for plugin.xml
Current Time: Sat Jul 26 01:44:06 EDT 2025
Powered by FUDForum. Page generated in 0.03629 seconds
