Home » Archived » IMP » Problems compiling .g file
Problems compiling .g file [message #4883] Fri, 31 August 2007 05:18 Go to next message
Hello
When making changes to my .g file the Parser.java file does not get
updated. I do get an error in the "errors" section of the "problems" tab:
" 3.2.1/eclipse/plugins/org.eclipse.imp.lpg.metatooling_1.0.62 /templates/;C:/tools/Eclipse3.2.1/eclipse/plugins/lpg.runtim e_2.0.6/templates/ "
is an invalid option org.sintef.MOF2Text/src/mof2text/safari/parser
MOF2TextLexer.gi line 1 1188551373520 137
It seems as if the path for my eclipse installation has been truncated,
or rather some of the first path elements have been removed.
Any suggestions
Tor
Re: Problems compiling .g file [message #4951 is a reply to message #4883] Tue, 04 September 2007 10:37 Go to previous message
Hi Tor,
Apologies for the slow response; we're just getting back from a four-day
weekend, during which our systems were shut down.
The particular option in question here is the "include path" option that
tells LPG where to look for template files that it uses in generating
all of the stuff that it generates.
I'm not sure where the specific message that you report is generated,
but I believe it must come out of the LPG executable, which is called in
the compile(..) method in the LPG builder. The LPG builder gets
information about the include path (and other preferences) from the IMP
preferences service and passes those values to the LPG executable in the
compile() method.
One place to start looking is in the LPG preferences, to see if a valid
value is stored for the "IncludePathToUse" preference. Is that value
truncated or complete? (You need to check the value that will be in
effect for the project in which your grammar file resides.)
Another thing to look at is the error log, to see if an exception is
thrown and, if so, whether it originates in the LPG compiler or
somewhere else. (Although I don't think this could be.)
Stan
Tor Neple wrote:
> Hello
> Any suggestions
> Regards
> Tor
Re: Problems compiling .g file [message #566344 is a reply to message #4883] Tue, 04 September 2007 10:37 Go to previous message
Hi Tor,
compile() method.
Stan
Tor Neple wrote:
> Hello
> Any suggestions
> Regards
> Tor
Previous Topic:Problems compiling .g file
Next Topic:Problems with LPG parser
Current Time: Sun Jul 27 06:15:28 EDT 2025
Powered by FUDForum. Page generated in 0.03548 seconds
