Installing RAP, if you didn't follow the directions... [message #54731] |
Tue, 23 October 2007 11:03  |
Originally posted by: Jim.Cooper.sas.com
Long-time Eclipse user.
Whenever I see the 'Welcome' page, I just click it off.
However, I just installed RAP Release 1.0 plugins, and can't get them to
work.
So... I go look at the "Getting Started" page on the web, and find out
that I was supposed to click something on the 'Welcome' page to finish
the install of RAP.
I can't get the Welcome page back. The default Welcome page under
'Help' doesn't show anything about RAP.
How do I get RAP installed the rest of the way, now? Do I re-install it
(basically, remove my entire Eclipse install, and start over)?
Re: Installing RAP, if you didn't follow the directions... [message #54758 is a reply to message #54731] |
Tue, 23 October 2007 11:21   |
Hi Jim,
as RAP is delivered as a target platform you normally just need to
download the target, unzip it and load it as target platform.
As most Eclipse users are not familiar with Target Platforms we provided
the intro plugin. So it's not really needed, it's just a helper.
You don't need to reinstall eclipse. You should be able to rerun the
steps by opening the Overview Page of the Welcome page. There you'll
find an item "Rich Ajax Platform". Another way would be to hit Crtl+3
and type "Install RAP" (yes, it's a bug not a feature ;) )
Hope that helps!
Greets
Benny
> work.
> the install of RAP.
Re: Installing RAP, if you didn't follow the directions... [message #54785 is a reply to message #54758] |
Tue, 23 October 2007 12:33   |
Ah... the only problem with that is that I installed via the update
site, which should've installed the correct target platform code for me.
I thought.
The Ctrl+3 trick worked, though. Thanks.
Benjamin Muskalla wrote:
> Hi Jim,
> Hope that helps!
> Greets
> Benny
>> to work.
>> the install of RAP.
>> it (basically, remove my entire Eclipse install, and start over)?
Re: Installing RAP, if you didn't follow the directions... [message #54976 is a reply to message #54731] |
Wed, 24 October 2007 04:18  |
Hi Jim.
You can access the RAP part of the welcome page, if you click 'overview'
(the globe) on the main welcome page.
There, you get a topic named 'rich ajax platform (RAP)' where you can
find the needed link to install the target platform.
Greez
Alex
FUDForum. Page generated in 0.03280 seconds
