Re: Need Mylyn 2.0.1.v20070920-1000 or later 2.0.x [message #54994 is a reply to message #54941] |
Wed, 30 July 2008 21:57  |
Originally posted by: yem_eclipse_news.filter.yve.net
Hello Steffen, and thank you very much for you help.
I will look at upgrading my Eclipse installation to 3.3 (I checked the
"Mylyn/Contributor Reference" document, and a manual build seems a bit
daunting).
Yves-Eric
Steffen Pingel wrote:
> The version mentioned on the bug report refers to an integration build.
> These builds are not retained in the archive. Unfortunately the latest
> Mylyn release supported on Eclipse 3.2 is version 2.0.0 which is not
> compatible with Trac 0.11.
> I can only recommend to either try a manual build of a CVS snapshot of the
> particular date of the integration build or an update to Eclipse 3.3 and
> Mylyn 3.0.0.
> Steffen
Re: Need Mylyn 2.0.1.v20070920-1000 or later 2.0.x [message #592038 is a reply to message #54713] |
Wed, 30 July 2008 21:08  |
Mylyn 3.0.0.
Steffen
Yves-Eric Martin wrote:
> Hi all,
> I am looking for Mylyn version 2.0.1.v20070920-1000 mentioned in this
> comment:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=175211#c21
> However, the builds page at http://www.eclipse.org/mylyn/builds/ only
> lists versions up to 2.0.0 in the 2.0.x branch...
> Where can I download 2.0.1.v20070920-1000 (or above 2.0.x I guess) ?
> Thank you very much.
> (Note: according to the bug report linked above, I need 2.0.1 to get
> things working with Trac 0.11 under Eclipse 3.2)
> Cheers,
Re: Need Mylyn 2.0.1.v20070920-1000 or later 2.0.x [message #592062 is a reply to message #54941] |
daunting).
Yves-Eric
> Mylyn 3.0.0.
> Steffen
FUDForum. Page generated in 0.27499 seconds
