Home » Archived » Test and Performance Tools Platform (TPTP) » Attaching to weblogic 8.1 using IAC
Attaching to weblogic 8.1 using IAC [message #54675] |
Fri, 24 February 2006 11:17  |
Originally posted by: Harry.Arendt.us.ing.org
After carefully reviewing this conference I have not found an answer to my
question.
I am new to TPTP but am a long time eclipse user.
I followed the tutorial directions for profiling the Product Sample example
and it worked correctly.
I have some confusion over how to use the Integrated Agent Controller to
profile an application
running on my local machine outside of Eclipse.
I am now attempting to profile a J2EE application running on Weblogic 8.1.
The application is built using
ANT and is deployed as an EAR file.
I am attempting to follow one of the tutorials the deal with attaching to
remote/local processes.
My env.
Windows XP SP1
Eclipse 3.1.2
TPTP 4.1.0
Weblogic 8.1
JRE 1.4.2_04
Within eclipse I created a server:
Generic BEA Weblogic Server v8.1
localhost
To the java command to start weblogic I added this based on some of the
things I read here.
-XrunpiAgent:server=enabled
However weblogic would not start with this added.
If I start weblogic without this and I go to the Profile and Logging view
the Run->Profiles and select
Attach - Java Process - New
I get the configuration dialog. Selecting LocalDirect Connection -- Test
Connection works however
on the Agents tab there is an error indicator, there are no agents listed
and the at the top of the dialog
I see the error message;
IWAT0225E You must select at least one agent to attach to.
I had expected to see something from the weblogic service similar to what
the tutorial showed me, however
the tutorial was with Tomcat and not wweb logic. It showed a PID: 1208
Has anyone out there attempted to connect ot a running weblogic system?
Also does anyone know why I do not see any Agents?
Harry Arendt
Re: Attaching to weblogic 8.1 using IAC [message #55046 is a reply to message #54857] |
Mon, 27 February 2006 07:33   |
Yes, the "piAgent.dll" does depends on the following DLL's
- hcclco.dll
- hccldt.dll
- hccls.dll
- hcbnd.dll
- hcclsm.dll
Usually these DLL's are packaged under the same directory as
"piAgent.dll" and should also be in the PATH in order to allow the JVM
to load the profiling agent.
Samson
Harry Arendt wrote:
> Samson,
> Thanks for the reply and the suggestions.
> This highlights some of my confusion. Before I realized that 4.1 had the
> IAC I
> did install the old agent plug in so I have the directory you referenced.
> However a search of
> my system for the dll showed it in my eclipse 31 directory in the bin
> folder. I do have that folder in
> my path, and I wonder if there are other dlls in the path you referenced
> which are also needed.
> Harry
> "Samson Wai" <samwai@ca.ibm.com> wrote in message
> news:dtnd6o$53c$1@utils.eclipse.org...
>> Hello,
>> In order to profile any Java application such as a Weblogic server, you
>> will have to pass in the Java VM argument "-XrunpiAgent:server=enabled".
>> If the Java application fails to come up, it may due to the face that
>> the library "piAgent.dll" (on Win32) is missing from the PATH and thus
>> the JVM cannot load the profiling agent. The JVM is trying to load the
>> library "piAgent" which is specified in the "-Xrun" argument by looking
>> at the PATH. If no "-XrunpiAgent" arg is passed then there won't be any
>> profiling agent appearing on the Profiling configuration dialog.
>> You may need to add to the PATH this directory:
>> - <eclipse home>/plugins/org.eclipse.hyades.execution/os/win32/x86
>> in the same command prompt where Weblogic is to be started.
>> Note: the directory "org.eclipse.hyades.execution" may contain a version
>> and/or a build number. For example:
>> org.eclipse.hyades.execution_4.1.0.200602210100
>> The "os/win32/x86" directory contain
>> Regards,
>> Samson
> my
>>> question.
> example
> 8.1.
> to
>>> My env.
>>> Windows XP SP1
>>> Eclipse 3.1.2
>>> TPTP 4.1.0
>>> Weblogic 8.1
>>> JRE 1.4.2_04
>>> localhost
>>> things I read here.
> view
> Test
> listed
> what
>>> Harry Arendt
Re: Attaching to weblogic 8.1 using IAC [message #57536 is a reply to message #55046] |
Fri, 10 March 2006 18:29   |
Originally posted by: Paul_Andrews.capgroup.com
I'm trying to do the same thing but find it all very confusing. In
particular, I have set up the path as outlined below and run weblogic with
the -XrunpiAgent:server=enabled option but the weblogic server doesn't
start up - the java process is created and just sits there, no output is
sent to the console.
OK, thought I, maybe its waiting for me to attach the profiler to it, so I
followed the directions in the 'attach to java process' section of the
TPTP documentation and I selected 'Start monitoring' from the popup menu
in the profiling view. But no, still no sign of life from weblogic and
there are no execution statistics to be had.
So does anyone have any pointers?
BTW1 - where is -XrunpiAgent:server=enabled documented?
BTW2 - if I don't set the path up properly weblogic runs fine, but I
obviously can't attach to it.
Samson Wai wrote:
> - hcclco.dll
> - hccldt.dll
> - hccls.dll
> - hcbnd.dll
> - hcclsm.dll
> Samson
> Harry Arendt wrote:
>> Samson,
>> IAC I
>> However a search of
>> Harry
>>> Hello,
>>> Regards,
>>> Samson
>> my
>>>> question.
>> example
>> 8.1.
>> to
>>>> My env.
>>>> Windows XP SP1
>>>> Eclipse 3.1.2
>>>> TPTP 4.1.0
>>>> Weblogic 8.1
>>>> JRE 1.4.2_04
>>>> localhost
>>>> things I read here.
>> view
>> Test
>> listed
>> what
>>>> Harry Arendt
Re: Attaching to weblogic 8.1 using IAC [message #70424 is a reply to message #59015] |
Wed, 10 May 2006 17:02   |
Originally posted by: nmehrega.ca.ibm.com
This is a multipart message in MIME format.
--=_alternative 00739FD68525716A_=
Content-Type: text/plain; charset="US-ASCII"
Hi Harry,
Let me explain a few things that will hopefully help you in your
confusion. Integrated Agent Controller (IAC) is a replacement for the
Remote Agent Controller (RAC) in the local scenario. RAC allows the user
to profile locally as well as remotely via socket communication. However,
it doesn't make a lot of sense to be running a separate process and
communicating via sockets when you want to profile something locally.
That's where IAC comes in the picture. IAC allows the user to profile
locally without requiring the RAC. The IAC plugin is included in the TPTP
plugin (i.e. tptp.runtime-TPTP-4.1.0.zip). If you're planning to use IAC
for local profiling, then you don't need the RAC and you shouldn't bother
downloading it. The second zip you extracted is the RAC (i.e.
tptp.win_ia32-TPTP-4.1.0.zip).
Now as Samson mentioned, you'll need the IAC DLL files in your PATH before
you can attach to a profiling agent. These would be located in <eclipse
home>/plugins/org.eclipse.hyades.execution_<version>/os/win32/x86
Once you do this, you can start any Java process in 'enabled' mode and
attach to it in the workbench. And it seems like you've already figured
this out by doing (-XrunpiAgent:server=enabled). Now, I have no idea why
Weblogic halts when you add this new VM argument. It shouldn't and I've
never experienced this with any other Java application. This *could* be a
problem with Weblogic.
BTW, You can ignore the Agent Controller is not active: will wait in a
1000 ms loop. message when you're planning to attach to your agent with
IAC.
Now you can also try profiling with RAC instead of IAC to see if it solves
your problem. You shouldn't extract the RAC zip file (i.e.
tptp.win_ia32-TPTP-4.1.0.zip) in your eclipse directory. This isn't an
eclipse plugin. Extract it to some where else on your filesystem. Once
you do that, read the getting_started.html in it to figure out how you can
set it up and start it. You'll need to remove the <eclipse
directory from your PATH and add <RAC_HOME>/bin instead. Then start your
RAC, start weblogic in 'enabled' mode, and try to attach to it in the
workbench. Let me know what happens.
Navid Mehregani
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">Hi Harry,</font>
<br>
<br><font size=2 face="sans-serif">Let me explain a few things that will
hopefully help you in your confusion. Integrated Agent Controller
(IAC) is a replacement for the Remote Agent Controller (RAC) in the local
scenario. RAC allows the user to profile locally as well as remotely
via socket communication. However, it doesn't make a lot of sense
to be running a separate process and communicating via sockets when you
want to profile something locally. That's where IAC comes in the
picture. IAC allows the user to profile locally without requiring
the RAC. The IAC plugin is included in the TPTP plugin (i.e. </font><tt><font size=2>tptp.runtime-TPTP-4.1.0.zip</font></tt><font size=2 face="sans-serif">).
If you're planning to use IAC for local profiling, then you don't
need the RAC and you shouldn't bother downloading it. The second
zip you extracted is the RAC (i.e. </font><tt><font size=2>tptp.win_ia32-TPTP-4.1.0.zip</font></tt><font size=2 face="sans-serif">).</font>
<br>
<br><font size=2 face="sans-serif">Now as Samson mentioned, you'll need
the IAC DLL files in your PATH before you can attach to a profiling agent.
These would be located in </font><tt><font size=2> <eclipse
home>/plugins/org.eclipse.hyades.execution_<ve rsion>/os/win32/x86 </font></tt>
<br>
<br><font size=2 face="sans-serif">Once you do this, you can start any
Java process in 'enabled' mode and attach to it in the workbench. And
it seems like you've already figured this out by doing (-XrunpiAgent:server=enabled).
Now, I have no idea why Weblogic halts when you add this new VM argument.
It shouldn't and I've never experienced this with any other Java
application. This *could* be a problem with Weblogic. </font>
<br>
<br><font size=2 face="sans-serif">BTW, You can ignore the </font><tt><font size=2> Agent
Controller is not active: will wait in a 1000 ms loop. </font></tt><font size=2 face="sans-serif">message
when you're planning to attach to your agent with IAC. </font>
<br>
<br><font size=2 face="sans-serif">Now you can also try profiling with
RAC instead of IAC to see if it solves your problem. You shouldn't
extract the RAC zip file (i.e. </font><tt><font size=2>tptp.win_ia32-TPTP-4.1.0.zip</font></tt><font size=2 face="sans-serif">)
in your eclipse directory. This isn't an eclipse plugin. Extract
it to some where else on your filesystem. Once you do that, read
the getting_started.html in it to figure out how you can set it up and
start it. You'll need to remove the </font><tt><font size=2><eclipse
home>/plugins/org.eclipse.hyades.execution_<ve rsion>/os/win32/x86 </font></tt><font size=2 face="sans-serif">
start your RAC, start weblogic in 'enabled' mode, and try to attach to
it in the workbench. Let me know what happens.</font>
<br>
<br><font size=2 face="sans-serif">Navid Mehregani</font>
--=_alternative 00739FD68525716A_=--
Re: Attaching to weblogic 8.1 using IAC [message #76663 is a reply to message #68102] |
Fri, 07 July 2006 10:08  |
Originally posted by: keithritchie_ca.XXXXyahoo.ca
My weblogic was hanging, but it was because of the setup we had to allow
debugging. I commented out the following from our ant script and was able
to successfully profile weblogic 8.1.
<!-- Debug -- comment out to allow profiling
<jvmarg value="-Xdebug"/>
<jvmarg value="-Xnoagent"/>
<jvmarg
value="-Xrunjdwp:transport=dt_socket,server=y,suspend=n"/>
<sysproperty key="java.compiler" value="NONE" />
<!-- turn on TPTP profiling support -->
<jvmarg value="-XrunpiAgent:server=enabled" />
I am using the ACServer agent and connecting as documented in the TPTP
docs.
Current Time: Sat Aug 02 03:21:22 EDT 2025
Powered by FUDForum. Page generated in 0.06944 seconds
