Home » Language IDEs » AspectJ » erratic behaviour re. obsolete project references
erratic behaviour re. obsolete project references [message #54652] Thu, 07 July 2005 19:07 Go to next message
I had the strange case here, that - whenever I rebuilt my project - AJDT
popped up an error telling me
AspectJ error:
Error creating marker
reason:
Reource /<other_project>/..../<SomeFile>.java does not exist.
I indeed previously had "imported" (i.e. referenced) that
<other_project> from my now aspectized current project, but - to improve
the behaviour of the aspect visualizer - in the meantime I now "linked"
the source of <other_project> into my current project (according to the
"Using linked source folders" chapter in the online help), so that
<other_project> should nowhere be referenced any more in the current
project.
But that error kept reappearing each time when I did a rebuild! In the
end I desperately deleted the <other_project> from eclipse (of course
without deleting its content...) and only after that the error popup had
finally gone.
So - apparently - AspectJ keeps around some old reference to a
previously referenced project, even after removing it from the
build-path and obviously that reference even survives (several!) "Build
clean"s.
Michael
Re: erratic behaviour re. obsolete project references [message #54923 is a reply to message #54652] Tue, 12 July 2005 05:46 Go to previous message
Originally posted by: mchapman.uk.ibm.com
Hi Macheal,
This is clearly a bug. Please can you raise this in bugzilla, with the
exact steps required to reproduce.
Matt.
> AspectJ error:
> reason:
> project.
> finally gone.
> clean"s.
> Michael
Matt Chapman
AJDT Development, http://www.eclipse.org/ajdt
Re: erratic behaviour re. obsolete project references [message #589403 is a reply to message #54652] Tue, 12 July 2005 05:46 Go to previous message
Hi Macheal,
Matt.
> AspectJ error:
> reason:
> project.
> finally gone.
> clean"s.
> Michael
Matt Chapman
Previous Topic:what does AJDT do to the JavaBuildPath-Edit function?
Next Topic:what does AJDT do to the JavaBuildPath-Edit function?
Current Time: Sun Aug 31 09:15:33 EDT 2025
Powered by FUDForum. Page generated in 0.02993 seconds
