Home » Archived » Test and Performance Tools Platform (TPTP) » External Profiling startup problems
External Profiling startup problems [message #54622] Fri, 24 February 2006 09:18 Go to next message
I have an existing Eclipse project that I am attmepting to profile. I have
successfully debugged classes within this project for some time. However,
when I attempt to profile classes externally within this project, I get
java.lang.NoClassDefFoundError exceptions for the main class. The
classpath was set to include all jars/directories that where necessary
where included in the configuration.
In respect to the configuration, all buttons on the Main tab of the
configuration for an external class are disabled. I am assuming that you
just type in the fully qualified class name for the Class name: and type
in a delimited list of jars/directories for the Class path:.
Re: External Profiling startup problems [message #54802 is a reply to message #54622] Fri, 24 February 2006 11:55 Go to previous message
So the class you want to profile is actually not part of your project
but somewhere on the filesystem? If that's the case you will need to
create a new "External Java Application" from the Profile configuration
dialog. This is different from the "Java Application" configuration
which refers to classes withing the Eclipse workspace.
Samson
> have successfully debugged classes within this project for some time.
> However, when I attempt to profile classes externally within this
> project, I get java.lang.NoClassDefFoundError exceptions for the main
> class. The classpath was set to include all jars/directories that where
> necessary where included in the configuration.
Previous Topic:Need help detecting agent
Next Topic:Why is it so slow?
Current Time: Wed Jul 30 15:23:45 EDT 2025
Powered by FUDForum. Page generated in 0.18413 seconds
