Home » Eclipse Projects » GEF » Marquee Selection Not Drawing
Marquee Selection Not Drawing [message #54609] Mon, 13 January 2003 23:29 Go to next message
The marquee selection tool for the logic example doesn't draw correctly on a
white background. The problem appers to be that the
org.eclipse.draw2d.FigureUtilities static method makeGhostShape is calling
setFillXOR(true), but not calling setOutlineXOR(true) when I add the call to
setOutlineXOR(true) the marquee selection draws correctly. Here is the
updated makeGhostShape method:
public static Shape makeGhostShape(Shape s){
s.setBackgroundColor(ghostFillColor);
s.setFillXOR(true);
s.setOutlineXOR(true);
return s;
Re: Marquee Selection Not Drawing [message #54636 is a reply to message #54609] Mon, 13 January 2003 23:41 Go to previous messageGo to next message
Which build are you using? This was fixed about a month and a half ago.
> s.setFillXOR(true);
> return s;
Re: Marquee Selection Not Drawing [message #54663 is a reply to message #54636] Mon, 13 January 2003 23:56 Go to previous message
I had downloaded from latest Build 2.0, not from the current Integration
builds. I checked the CVS repository right after I sent the original
message and you are right it was fixed and checked in on 12/19/02.
I'll give it a go with the latest Integration Builds. Have they been pretty
stable? I noticed that no build was available under Current Stable Builds?
"Eric Bordeau" <ebordeau@us.ibm.com> wrote in message
news:b003g6$i05$1@rogue.oti.com...
on a
calling
call to
> > s.setFillXOR(true);
> > return s;
Previous Topic:cvs repository location for GEF
Next Topic:Draw2D Enhancements
Current Time: Fri Jul 18 15:52:39 EDT 2025
Powered by FUDForum. Page generated in 0.03165 seconds
