Home » Modeling » GMF (Graphical Modeling Framework) » Connection with Label to have enumerated values
Connection with Label to have enumerated values [message #54605] Mon, 25 September 2006 04:12 Go to next message
i want to have a label associated with a connection. This label can hold
enumerated values. How can I have this done?
In the xsd I have the element declared as follows:
<root>
<xsd:complexType name="connectorRelationType">
<xsd:attribute name="connectionLabel" type="xsd:string" />
</xsd:complexType>
</root>
In the map file when I create the link mappings How do I write the ocl
script which will enable the user input values between say "optional" and
mandatory".
I tried creating enumerated values for the connectionLabel but, I was
unable to set the string values to the label.
Please suggest..
Thanks & Regards
Balraj
Re: Connection with Label to have enumerated values [message #54927 is a reply to message #54605] Mon, 25 September 2006 06:56 Go to previous message
Originally posted by: 5d5.mail.ru
I suggest to modify the generated IParser for the label to accept only
appropriate values. There are pending requests to support this scenario:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=158116
https://bugs.eclipse.org/bugs/show_bug.cgi?id=146818
Balraj Kannan wrote:
> hold enumerated values. How can I have this done?
> <root>
> </xsd:complexType>
> </root>
> and mandatory".
> Please suggest..
> Thanks & Regards
> Balraj
Previous Topic:Two instances of same diagram type for one model file
Next Topic:Update site problems
Current Time: Fri Jul 18 08:48:25 EDT 2025
Powered by FUDForum. Page generated in 0.07087 seconds
