How do I repair eclipse (remove datatools)? [message #54596] |
Tue, 07 April 2009 15:10  |
Originally posted by: asd.asd.com
I have updated eclipse through the update manager for Vista 32 bit. But each
time I try to install something new I get:
An error occurred while collecting items to be installed
No repository found containing:
org.eclipse.datatools.enablement.ibm.feature/org.eclipse.upd ate.feature/1.6.0.v200804021-7D40EB7sQS9RWfUjJLb
org.eclipse.datatools.enablement.jdt.feature/org.eclipse.upd ate.feature/1.6.0.v200804021-1-07w311916263466
org.eclipse.datatools.enablement.mysql.feature/org.eclipse.u pdate.feature/1.6.0.v200804021-441_kE77c7QASCMPN
org.eclipse.datatools.enablement.sybase.ase/osgi.bundle/1.0. 1.v200807010411
org.eclipse.datatools.enablement.sybase.feature/org.eclipse. update.feature/1.6.1.v200809191145-7A-5E9IgKLhLGetRuu9
org.eclipse.datatools.enablement.sybase.ui/osgi.bundle/1.0.0 .v200808221518
org.eclipse.datatools.sqldevtools.data.feature/org.eclipse.u pdate.feature/1.6.1.v200809191145-30-9oA55S5SBG5ND5
org.eclipse.datatools.sqltools.data.core/osgi.bundle/1.0.0.v 200808260630
org.eclipse.datatools.sqltools.data.ui/osgi.bundle/1.1.0.v20 0808260630
org.eclipse.datatools.sqltools.tabledataeditor/osgi.bundle/1 .0.0.v200808300730
It also happens when I try to uninstall plugins. When I eg. try to uninstall
the C/C++ Development Platform I also get the above message. It seems that
dtp has corrupted
the eclipse update manager. Is there someway to fix this kind of problem
without reinstalling eclipse?
Re: How do I repair eclipse (remove datatools)? [message #54918 is a reply to message #54891] |
Thu, 09 April 2009 09:52   |
Originally posted by: brianf.sybase.com
WTP is dependent on DTP, but if you install WTP it should install the
correct version of DTP along with it.
I'm not a big fan of the update manager. I just grab zips for the most part
and install them directly as Mark mentioned.
--Fitz
"JS" <asd@asd.com> wrote in message news:grkh5i$c80$1@build.eclipse.org...
> Update: I have tried removing the check in "Web Tools (WTP) Update Site"
> under "Manage Sites" and now I can uninstall the C++ plugin. Are there any
> connection/dependency between WTP and DTP?
> "JS" <asd@asd.com> wrote in message news:grkgr3$a30$1@build.eclipse.org...
>> If I remove DTP from "Manage Sites" I cannot install or uninstall
>> anything anymore, it just hangs (for some reason it reads from the DTP
>> repositories before it can uninstall eg the C++ plugin). Seems a
>> reinstall of eclipse is the only solution, even though it could be nice
>> to know what is wrong with DTP.
>> "Mark Leone" <midnightjava@verizon.net> wrote in message
>> news:grjt68$p28$1@build.eclipse.org...
>>>I had a similar problem when I first installed DTP a month or so ago. I
>>>figured the repository I was pointing to with the update manager was
>>>temporarily unreachable for some reason. I downloaded the zip file with
>>>the DTP code and installed it from my file system.
>>> The errors stopped appearing, but I may have done something else as
>>> well, I'm not sure. Perhaps you should click "Manage Sites" in the
>>> Software Update window, and delete the DTP sites, then install DTP from
>>> your file system.
>>> -Mark
>>> JS wrote:
>>>> I am using eclipse:
>>>> Version: 3.4.2
>>>> Build id: M20090211-1700
>>>> As described earlier the error does not only appear when I try to
>>>> install dtp 1.6.1 but also when I try to uninstall some of the other
>>>> plugins.
>>>> When I look at "Installed software" I don't find any references to dtp,
>>>> so I don't know why its looking in those repositories.
>>>> "Brian Fitzpatrick" <brianf@sybase.com> wrote in message
>>>> news:grgllu$j1a$1@build.eclipse.org...
>>>>> Can anybody help out JS?
>>>>> JS, can you provide some additional details... What version of Eclipse
>>>>> are you using? What version of DTP are you trying to install? Etc...
>>>>> --Fitz
>>>>> news:grg8fu$8l2$1@build.eclipse.org...
>>>>>> But each time I try to install something new I get:
>>>>>> uninstall the C/C++ Development Platform I also get the above
>>>>>> message. It seems that dtp has corrupted
>>>>>> problem without reinstalling eclipse?
Re: How do I repair eclipse (remove datatools)? [message #56153 is a reply to message #54918] |
Fri, 01 May 2009 17:26  |
Hi again...
We're trying to narrow down a reproducible scenario to try and figure out
what's going on. We've started to collect details here:
http://wiki.eclipse.org/DTP_1.6.2_Update_Manager_Issues
Please let us know if you find out anything else and we'll continue to bang
on this.
Thanks.
--Fitz
news:grkuj7$ltp$1@build.eclipse.org...
> part and install them directly as Mark mentioned.
> --Fitz
>> any connection/dependency between WTP and DTP?
>>>> your file system.
>>>> -Mark
>>>> JS wrote:
>>>>> I am using eclipse:
>>>>> Version: 3.4.2
>>>>> plugins.
>>>>> dtp, so I don't know why its looking in those repositories.
>>>>>> Eclipse are you using? What version of DTP are you trying to install?
>>>>>> Etc...
>>>>>> --Fitz
Re: How do I repair eclipse (remove datatools)? [message #595157 is a reply to message #54596] |
Tue, 07 April 2009 18:55  |
JS, can you provide some additional details... What version of Eclipse are
--Fitz
"JS" <asd@asd.com> wrote in message news:grg8fu$8l2$1@build.eclipse.org...
> uninstall the C/C++ Development Platform I also get the above message. It
Re: How do I repair eclipse (remove datatools)? [message #595171 is a reply to message #54624] |
Wed, 08 April 2009 04:16  |
I am using eclipse:
Version: 3.4.2
As described earlier the error does not only appear when I try to install
dtp 1.6.1 but also when I try to uninstall some of the other plugins.
When I look at "Installed software" I don't find any references to dtp, so I
> --Fitz
Re: How do I repair eclipse (remove datatools)? [message #595243 is a reply to message #54676] |
Thu, 09 April 2009 00:22  |
your file system.
-Mark
JS wrote:
> I am using eclipse:
> Version: 3.4.2
> plugins.
>> --Fitz
Re: How do I repair eclipse (remove datatools)? [message #595253 is a reply to message #54836] |
Thu, 09 April 2009 05:57  |
If I remove DTP from "Manage Sites" I cannot install or uninstall anything
anymore, it just hangs (for some reason it reads from the DTP repositories
before it can uninstall eg the C++ plugin). Seems a reinstall of eclipse is
the only solution, even though it could be nice to know what is wrong with
DTP.
>temporarily unreachable for some reason. I downloaded the zip file with the
> The errors stopped appearing, but I may have done something else as well,
> I'm not sure. Perhaps you should click "Manage Sites" in the Software
> Update window, and delete the DTP sites, then install DTP from your file
> system.
> -Mark
> JS wrote:
>> I am using eclipse:
>> Version: 3.4.2
>>> --Fitz
Re: How do I repair eclipse (remove datatools)? [message #595260 is a reply to message #54863] |
Thu, 09 April 2009 06:03  |
> is the only solution, even though it could be nice to know what is wrong
> with DTP.
>> system.
>> -Mark
>> JS wrote:
>>> I am using eclipse:
>>> Version: 3.4.2
>>> plugins.
>>>> --Fitz
Re: How do I repair eclipse (remove datatools)? [message #595272 is a reply to message #54891] |
--Fitz
>>> your file system.
>>> -Mark
>>> JS wrote:
>>>> I am using eclipse:
>>>> Version: 3.4.2
>>>> plugins.
>>>>> --Fitz
Re: How do I repair eclipse (remove datatools)? [message #595684 is a reply to message #54918] |
Hi again...
on this.
Thanks.
--Fitz
> --Fitz
>>>> your file system.
>>>> -Mark
>>>> JS wrote:
>>>>> I am using eclipse:
>>>>> Version: 3.4.2
>>>>> plugins.
>>>>>> Etc...
>>>>>> --Fitz
FUDForum. Page generated in 0.06324 seconds
