XDebug problems on OS X, had this working in earlier RC [message #54487] |
Mon, 24 September 2007 14:27  |
Originally posted by: mseritan.de-dash-co-de.com
I had XDebug run previously in one of the July/August PDT release
candidates. I've been trying for 3 days to get it running in the
pdt-all-in-one-1.0-R20070917-macosx-carbon.tar.gz. I am trying to get
going a PHP Script Debugging configuration.
1. I downloaded the complete archive above and configured XDebug as per
the instructions
2. I have XDebug 2.0.0 installed in php 5.2.1 and properly reported in
php -i
3. The command line client provided with XDebug properly stops the
execution of the script.
4. I check that port 9000 is not opened before Eclipse starts and it is
opened after Eclipse is up
5. Debugging does not stop at the breakpoints.
6. When I am debugging from the XDebug client I get output in
/tmp/xdebug.log (see below for my php.ini) but there is no output at all
when debugging in Eclipse.
--- php.ini ---
[xdebug]
xdebug.remote_enable=1
xdebug.remote_handler="dbgp"
xdebug.remote_port=9000
xdebug.remote_host=127.0.0.1
xdebug.remote_log=/tmp/xdebug.log
zend_extension=/usr/local/php5/lib/xdebug.so
What can I try next?
Marius
Re: XDebug problems on OS X, had this working in earlier RC [message #54732 is a reply to message #54655] |
Tue, 25 September 2007 04:53  |
It looks like you are using php from a web server, but when trying to look at
the contents of php.ini you where using the command line version. These are
2 different ways in which php gets invoked and as such they have different ways
in which the locate the php.ini file. The Command Line version is an instance
of a SAPI module and the web server integration is another (different) instance
of a SAPI module. Each SAPI module defines it's own way of locating the php.ini
file
for details on the rules to how php.ini files are located can be found at
http://www.php.net/manual/en/configuration.php (and possibly in other places)
Hope this helps.
Dave Kelsey
Marius Seritan wrote:
> Dave,
> Creating a link of the php.ini file into the bin directory fixed my
> problem!!
> mmac:/usr/local/php5/bin mseritan$ sudo ln -s ../lib/php.ini .
> I can now debug. Pfiuuuuuu.
> This sounds like a bug or at least a behavior that needs to be
> documented :)
> Thanks for the great work you did on XDebug and the Eclipse integration.
> Marius
>> Dave,
>> This was a very good tip!
>> I added a phpinfo() to the debugged php code. When running the php
>> file directly from the command line I do see xdebug configs. The same
>> thing for php -i. However when running from Eclipse I don't see the
>> same xdebug entries even though the php.ini file is the right one
>> Configuration File (php.ini) Path => /usr/local/php5/lib
>> Also I do see the magical debug variables in the Eclipse output
>> _SERVER["XDEBUG_CONFIG"] => remote_enable=1 idekey=ECLIPSE_DBGP
>> _SERVER["DBGP_IDEKEY"] => ECLIPSE_DBGP
>> I tried deleting the PHP Executable and re-adding it but it did not
>> make any difference.
>> Can you help me progress one more step on this puzzle?
>> Thanks a lot,
>> Marius
>> Dave wrote:
>>> Might also be worth executing a simple script of phpinfo through
>>> debug to show that xdebug is loaded as the launcher creates a copy of
>>> the ini file from the one with your php executable.
>>> Dave Kelsey
>>>> get going a PHP Script Debugging configuration.
>>>> per the instructions
>>>> in php -i
>>>> is opened after Eclipse is up
>>>> all when debugging in Eclipse.
>>>> --- php.ini ---
>>>> [xdebug]
>>>> Thanks,
>>>> Marius
FUDForum. Page generated in 0.04051 seconds
