Re: Help for new project [message #602034 is a reply to message #541137] |
Tue, 22 June 2010 09:57 |
hi,
To remove the palette at runtime, you can right click on the palette and select in the palette menu which palette you want to see or not. It is not possible yet to remove a palette using plugins. We are currently making specification about life cycle management for palettes in the following bug, where people could post their use case and the enhancement they would like to see for the palette. See http://bugs.eclipse.org/bugs/show_bug.cgi?id=317556
To register listeners on the model, you can use the following extension point: org.eclipse.papyrus.core.modelListener. There are 2 examples of this extension point in the plugin org.eclipse.papyrus.diagram.common, which react on stereotype and profile application.
Rémi
http://www.eclipse.org/papyrus
Remi Schnekenburger
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
FUDForum. Page generated in 0.04321 seconds
