Home » Eclipse Projects » Eclipse Platform » Custom Java Project Wizard
Custom Java Project Wizard [message #438] Sat, 19 April 2003 23:48 Go to next message
Originally posted by: ewoojava.hotmail.com
I am trying to create a project wizard for creating Custom Java Project
Wizard that will automatically include serveral build paths. What is the
class should I be used to extend from?
Re: Custom Java Project Wizard [message #628 is a reply to message #438] Mon, 21 April 2003 11:17 Go to previous messageGo to next message
You have to create your own wizard but you can reuse the
'WizardNewProjectCreationPage'.
In org.eclipse.jdt.ui.tests (in the eclipse CVS repository) look for the
example class 'MyProjectCreationWizard'.
In 'updatePage' you would modify
'fJavaPage.init(jproject, null, null, false);'
to define the build path you want by default.
Martin
Note that this discussion should go to eclipse.tools.jdt
Re: Custom Java Project Wizard [message #5001 is a reply to message #628] Tue, 22 April 2003 22:06 Go to previous messageGo to next message
> Martin
Re: In AGR While Creating Datapool, "Link to Datapool" is not visible [message #1788174] Wed, 30 May 2018 12:09 Go to previous message
Previous Topic:Error in newly installed Oxygen: Unable to locate secure storage module
Next Topic:Welcome
Current Time: Sun Aug 31 19:50:37 EDT 2025
Powered by FUDForum. Page generated in 0.03147 seconds
