Home » Eclipse Projects » Remote Application Platform (RAP) » RAP Command Line Launch
RAP Command Line Launch [message #54367] Mon, 22 October 2007 13:23 Go to next message
Originally posted by: andreasruempel.gmx.net
I want to launch my RAP application from command line without using the
Eclipse IDE. Certainly the Equinox launcher has to be used for that. I
have my application plug-in exported as a jar file and the RAP target
platform. Could somebody give me a short step-by-step guide, how to
perform this launch from command line? Can I use my launch configuration
file (the "OSGi Framework" or "RAP Application" launchers) somehow or do
I have to configure independently somewhere?
Thanks.
Andi
Re: RAP Command Line Launch [message #54839 is a reply to message #54367] Tue, 23 October 2007 17:22 Go to previous messageGo to next message
Originally posted by: jkrause.innoopract.com
Create a folder structure as this:
/yourapp
/yourapp/startup.jar
/yourapp/configuration/config.ini
/yourapp/plugins/...
config.ini should contain:
### bundles to start
osgi.bundles=org.eclipse.equinox.common@2:start,
org.eclipse.update.configurator@start,
org.eclipse.equinox.http.servletbridge@start,
org.eclipse.equinox.http.registry@start
# update configurator will load all bundles present in the plugins
# folder of your installation
### install area (replace with your install area path)
osgi.install.area=file:///yourapp
### path to osgi runtime jar - replace path
osgi.framework=file:///yourapp/plugins/org.eclipse.osgi_3.2.1.R32x_..
### no eclipse launch
eclipse.ignoreApp=true
Start the app with
-classpath /<yourapp>/startup.jar -Dorg.osgi.service.http.port=$PORT
org.eclipse.core.launcher.Main
See also: http://www.eclipse.org/equinox/server/http_in_equinox.php
Jochen
Andreas Rümpel wrote:
> Thanks.
> Andi
Re: RAP Command Line Launch [message #54865 is a reply to message #54839] Wed, 24 October 2007 00:48 Go to previous messageGo to next message
Originally posted by: fappel.innoopract.com
I'm not sure, but I thought startup.jar isn't supported with 3.3.0 anymore -
at least eclipse doesn't use it anymore.
See : http://wiki.eclipse.org/index.php/Equinox_Launcher#Startup.j ar.
Ciao
Frank
"Jochen Krause" <jkrause@innoopract.com> schrieb im Newsbeitrag
news:fflor8$hnq$1@build.eclipse.org...
> /yourapp
> Start the app with
> Cheers,
> Jochen
> Andreas R
Re: RAP Command Line Launch [message #55300 is a reply to message #54865] Wed, 24 October 2007 15:51 Go to previous message
Right, the "modern" way is to use org.eclipse.equinox.launcher,
furthermore I used the supplied org.eclipse.equinox.http.jetty instead
of Jochen's suggestion.
It works.
Andi
Frank Appel wrote:
> Ciao
> Frank
>> /yourapp
>> Start the app with
>> Cheers,
>> Jochen
>>> Hi,
>>> Thanks.
>>> Andi
Previous Topic:Help on Eclipse Help System
Next Topic:Switch for disabling widget pooling
Current Time: Sat Jul 26 06:44:58 EDT 2025
Powered by FUDForum. Page generated in 0.04696 seconds
