override copy action of editorpart (CopyCurrentLine) [message #54363] |
Fri, 10 April 2009 08:44  |
I want to write a small plugin for eclipse. It is name is CopyCurrentLine.
As the name implies, When I press ctrl-c or call the copy action via context
menu, I want to copy the current line when nothing is selected by the user.
(like in visual studio)
How can I catch the copy action of an editorpart?
Ken
Re: override copy action of editorpart (CopyCurrentLine) [message #60115 is a reply to message #54391] |
Thu, 07 May 2009 08:09  |
Thanks for your help.
I have implemented it on http://copycutcurrentline.googlecode.com/
Copy/Cut current line in Eclipse as in .NET
What is it?
Press Ctrl-C to copy the whole line in an editor when you select nothing.
It works as usual when you select something. And paste anywhere with Ctrl-V.
Works on Linux. Should work on Mac but not tested.
Download
- Eclipse Update Site
If you are already familiar with installing Eclipse plugins, you can just
use the update site URL below.
http://copycutcurrentline.googlecode.com/svn/trunk/
Tested for Java 6 and above. Tested for Eclipse 3.4 and above.
- Manual Download
Copy
http://copycutcurrentline.googlecode.com/svn/trunk/plugins/c om.lembas.CopyCutCurrentLine_1.0.0.jar
into your dropins folder and restart Eclipse.
"Ankur Sharma" <sharma.ankur@gmail.com> wrote in message
news:grng43$iph$1@build.eclipse.org...
> Kerem wrote:
>> CopyCurrentLine.
>> context menu, I want to copy the current line when nothing is selected by
>> the user. (like in visual studio)
>> Thanks
>> Ken
> You've got 2 options
> 1. Go to Window -> Preferences -> General -> Keys
> Scroll down to find "Copy all from left to right".
> This, by default, has no key binding. Add one of your liking.
> Use it with Home (takes cursor to start of line).
> Save yourself from writing a plug-in.
> 2. If you want a shorted Key binding, you will have to write a plugin
> Need not catch the copy action. Just contribute to the extension
> "org.eclipse.ui.bindings"
> And have a key binding of you liking.
> hth,
> Ankur..
Re: override copy action of editorpart (CopyCurrentLine) [message #594892 is a reply to message #54363] |
Fri, 10 April 2009 09:04  |
Kerem wrote:
> Thanks
> Ken
Need not catch the copy action. Just contribute to the extension "org.eclipse.ui.bindings"
hth,
Ankur..
Re: override copy action of editorpart (CopyCurrentLine) [message #594900 is a reply to message #54391] |
Fri, 10 April 2009 09:32  |
Ankur thank you for your answer.
But in either case I cannot bind ctrl-c to that command. I have to bind
another key.
Isn't there a way to catch copy action?
Or can I change the handler of the copy command "org.eclipse.ui.edit.copy"?
> Kerem wrote:
>> CopyCurrentLine.
>> Thanks
>> Ken
> hth,
> Ankur..
Re: override copy action of editorpart (CopyCurrentLine) [message #594911 is a reply to message #54417] |
Fri, 10 April 2009 13:07  |
> another key.
I am new to commands and really don't know how to hook or override and existing handler. Perhaps some SWT gurus at eclipse.platform.swt newsgroup can help you better than I can.
Sidenote: Why after Ctrl+C ? A similar one wont do? like Alt + C or Ctrl + Alt + C
hth,
Ankur..
Re: override copy action of editorpart (CopyCurrentLine) [message #596996 is a reply to message #54391] |
What is it?
Download
- Manual Download
Copy
> Kerem wrote:
>> CopyCurrentLine.
>> Thanks
>> Ken
> hth,
> Ankur..
FUDForum. Page generated in 0.05664 seconds
