Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Launching a module from Java
Re: [Acceleo] Launching a module from Java [message #539536 is a reply to message #539481] |
Fri, 11 June 2010 08:31 |
--------------050808060607070402010809
Daniel,
The "package with URI '*' not found" problem indicates that you're
trying to run your generation standalone while not registering the UML
metamodel. Two possibilities :
1) You're using an Acceleo launch configuration to launch your
generation and don't need it to be standalone. In this case you just
have to open your launch configuration and change the combo box at the
bottom from "Java Application" to "Acceleo Plug-in Application".
2) You want the generation to be runnable standalone. In this case you
will need to open the generated Java class (Main.java) and change the
"registerPackage" and "registerResourceFactory" methods to properly
register the UML package and factories (there should be a commented out
line in the methods with the code needed, otherwise you'll have to
follow the explanations on :
http://wiki.eclipse.org/MDT/UML2/FAQ#What.27s_required_to_lo ad_a_UML_.28.uml.29_resource_from_a_standalone_application.3 F
Laurent Goubet
Obeo
Daniel wrote:
> Hi all, I am having some trouble launching an Acceleo module with java,
> I have this main file:
> [comment encoding = UTF-8 /]
> [module main('http://www.eclipse.org/uml2/2.1.0/UML')/]
> [import org::acceleo::module::pim::uml21::gen::java::class /]
> [import org::acceleo::module::pim::uml21::gen::java::enum /]
> [import org::acceleo::module::pim::uml21::gen::java::interface /]
> [import org::acceleo::module::pim::uml21::gen::java::validator::core /]
> [template public main(m : Model)]
> [comment @main /]
> [comment Call the file block in 'class' /]
> [m.packagedElement->filter(Class).classJava() /]
> [comment Call the file block in 'enum' /]
> [ m.packagedElement->filter(Enumeration).enumJava() /]
> [comment Call the file block in 'interface' /]
> [ m.packagedElement->filter(Interface).interfaceJava() /]
> [comment Call the file block in 'core' /]
> [ validator() /]
> [/template]
> Then I want to run it on a model using java so I do:
> java Main othermodels/DosClases.uml othermodels
> DosClases.uml is a uml model.
> And I dont know why I got this:
> Exception in thread "main"
> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1Diagnos
> ticWrappedException: org.eclipse.emf.ecore.xmi.PackageNotFoundException:
> Package with uri 'http://www.eclipse.org/uml2/2.1.0/UML' not found.
> ( file:///C:/Users/Dell/workspace/org.acceleo.module.pim.uml21 .gen.java.migrated/othermodels/DosClases.uml,
> 2, 231)
> at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDe
> mandLoadException(ResourceSetImpl.java:315)
> at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo
> adHelper(ResourceSetImpl.java:274)
> at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou
> rce(ResourceSetImpl.java:397)
> at org.eclipse.acceleo.common.utils.ModelUtils.load(ModelUtils.
> java:346)
> at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator.
> initialize(AbstractAcceleoGenerator.java:311)
> at org.acceleo.module.pim.uml21.gen.java.migrated.files.Main.<init
> >(Main.java:83)
> at org.acceleo.module.pim.uml21.gen.java.migrated.files.Main.ma
> in(Main.java:125)
> Caused by: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package
> 2, 231)
> at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getPackageForURI(X
> MLHandler.java:2591)
> at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getFactoryForPrefi
> x(XMLHandler.java:2422)
> at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType
> (XMLHandler.java:1299)
> at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XM
> LHandler.java:1468)
> at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML
> Handler.java:1019)
> at org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI
> Handler.java:83)
> at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa
> ndler.java:1001)
> ndler.java:712)
> at org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHa
> ndler.java:169)
> at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser
> .startElement(Unknown Source)
> at com.sun.org.apache.xerces.internal.impl.dtd.XMLDTDValidator.
> at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS
> cannerImpl.scanStartElement(Unknown Source)
> at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm
> pl$ContentDriver.scanRootElementHook(Unknown Source)
> cannerImpl$FragmentContentDriver.next(Unknown Source)
> pl$PrologDriver.next(Unknown Source)
> pl.next(Unknown Source)
> cannerImpl.scanDocument(Unknown Source)
> at com.sun.org.apache.xerces.internal.parsers.XML11Configuratio
> n.parse(Unknown Source)
> at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U
> nknown Source)
> at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSA
> XParser.parse(Unknown Source)
> at javax.xml.parsers.SAXParser.parse(Unknown Source)
> at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.
> java:181)
> at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes
> ourceImpl.java:180)
> at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour
> ceImpl.java:1494)
> ceImpl.java:1282)
> ad(ResourceSetImpl.java:255)
> adHelper(ResourceSetImpl.java:270)
> ... 5 more
> Why is searching for a package with the name of the metamodel?
> Thank you very much.
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------050808060607070402010809--
Re: [Acceleo] Launching a module from Java [message #539620 is a reply to message #539536] |
Fri, 11 June 2010 14:12 |
Daniel Messages: 44 Registered: June 2010 |
Member |
Hi, I have tryed to follow the steps but it seems I dont get it:
1- How do i do not to get my code overwritten?
I think it is something related to the tag @Override, but I have been looking in the documentation and I dont find how to make my added code permanent.
2- I have added to the Main.java the following imports (I think) I needed for the added lines:
import java.util.*;
import org.eclipse.uml2.uml.*;
import org.eclipse.uml2.uml.resource.*;
2- Then I added the lines, and I added them where I think they should be added, in the registerPackages and getResourceFactory methods but I dont know if it is correct. Also, instead of:
URI uri = URI.createURI(" jar:file:/C:/eclipse/plugins/org.eclipse.uml2.uml.resources_ 2.0.0.v200606221411.jar!/ ");
I put my 3.1 jar:
URI uri = URI.createURI(" jar:file:/C:/eclipse/plugins/org.eclipse.uml2.uml.resources_ 3.1.0.v201005031530.jar!/ ");
This is the result:
* This can be used to update the resource set's package registry with all needed EPackages.
* @param resourceSet
* The resource set which registry has to be updated.
* @generated
public void registerPackages(ResourceSet resourceSet) {
super.registerPackages(resourceSet);
resourceSet.getPackageRegistry().put(org.eclipse.uml2.uml.UM LPackage.eINSTANCE.getNsURI(), org.eclipse.uml2.uml.UMLPackage.eINSTANCE);
// TODO If you need additional package registrations, do them here. The following line is an example for UML.
resourceSet.getPackageRegistry().put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
* This can be used to update the resource set's resource factory registry with all needed factories.
* @generated
public void registerResourceFactories(ResourceSet resourceSet) {
super.registerResourceFactories(resourceSet);
// TODO If you need additional resource factories registrations, do them here. The following line is an example for UML.
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put(UMLResource.FILE_EXTENSION, UMLResource.Factory.INSTANCE);
Map<URI, URI> uriMap = resourceSet.getURIConverter().getURIMap();
uriMap.put(URI.createURI(UMLResource.LIBRARIES_PATHMAP), uri.appendSegment("libraries").appendSegment(""));
uriMap.put(URI.createURI(UMLResource.METAMODELS_PATHMAP), uri.appendSegment("metamodels").appendSegment(""));
uriMap.put(URI.createURI(UMLResource.PROFILES_PATHMAP), uri.appendSegment("profiles").appendSegment(""));
I dont know if am I doing it right and I dont also know if I have to call this methods from anywhere, but I thought it was the program how should call them.
Doing this I keep getting:
Exception in thread "main" org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1Diagnos ticWrappedException: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'http://www.eclipse.org/uml2/2.1.0/UML' not found. ( file:///C:/Users/Dell/workspace/org.acceleo.module.pim.uml21 .gen.java.migrated/othermodels/DosClases.uml, 2, 231)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDe mandLoadException(ResourceSetImpl.java:315)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:274)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:397)
at org.eclipse.acceleo.common.utils.ModelUtils.load(ModelUtils. java:346)
at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator. initialize(AbstractAcceleoGenerator.java:311)
at org.acceleo.module.pim.uml21.gen.java.migrated.files.Main.<init >(Main.java:89)
at org.acceleo.module.pim.uml21.gen.java.migrated.files.Main.ma in(Main.java:131)
Caused by: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'http://www.eclipse.org/uml2/2.1.0/UML' not found. ( file:///C:/Users/Dell/workspace/org.acceleo.module.pim.uml21 .gen.java.migrated/othermodels/DosClases.uml, 2, 231)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getPackageForURI(X MLHandler.java:2591)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getFactoryForPrefi x(XMLHandler.java:2422)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType (XMLHandler.java:1299)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XM LHandler.java:1468)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:1019)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI Handler.java:83)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:1001)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:712)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHa ndler.java:169)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .startElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.dtd.XMLDTDValidator. startElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanStartElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl$ContentDriver.scanRootElementHook(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl$PrologDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSA XParser.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:181)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:180)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1494)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1282)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:255)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:270)
... 5 more
Re: [Acceleo] Launching a module from Java [message #539734 is a reply to message #539620] |
Sat, 12 June 2010 09:43 |
--------------090002060005020805070301
Daniel,
See my comments inlined below.
Laurent Goubet
Obeo
> permanent.
Simply alter the javadoc tag "@generated". Remove it, change it to
"@generated NOT", change it to "@not-generated" ... As you would for any
code generated by EMF.
> import java.util.*;
Yup, you need these.
> I put my 3.1 jar:
That's how it is intended. As long as you're sure this location actually
points to an existing jar file.
> This is the result:
> * * @param resourceSet
> * @generated
> @Override
Seems like the UMLPackage was already registered...
> UMLPackage.eINSTANCE); }
> * @generated
> @Override
> should call them.
You don't have to call them manually, the superclass takes care of the
calling.
> 2, 231)
Yup, I misunderstood the issue. You're in Eclipse 3.6, not in Eclipse
3.5; thus the UML NsURI you get through
"UMLPackage.eINSTANCE.getNsURI()" is
"http://www.eclipse.org/uml2/3.0.0/UML" (3.0.0) and not
"http://www.eclipse.org/uml2/2.1.0/UML" (2.1.0). You need to add this
last one manually, with an hard-coded String (well, there might be a
constant for it somewhere, but I don't know where that would be). You
need to add this line to the "registerPackages" method :
resourceSet.getPackageRegistry().put("http://www.eclipse.org/uml2/2.1.0/UML",
There might be a better way to do this ... but you'll have to ask on the
UML newsgroup as I don't know of any.
--------------090002060005020805070301--
Re: [Acceleo] Launching a module from Java [message #539814 is a reply to message #539481] |
Sun, 13 June 2010 16:19 |
Member |
Ok thank you very much!
One thing I didnt understand was:
"Seems like the UMLPackage was already registered..."
How do I see that? and also, registering it again like I do could cause any problem?
Anyway I do the changes you told me:
* @not-generated
// NASGUN
resourceSet.getPackageRegistry().put("http://www.eclipse.org/uml2/2.1.0/UML", UMLPackage.eINSTANCE);
* @not-generated
// NASGUN
And now I dont get any exception
The problem is that it only terminates and anything else, but I think the problem here is in the module, because when I tried to launch it with Acceleo I didnt get anything:
http://www.eclipse.org/forums/index.php?t=msg&goto=53962 5&#msg_539625
And I dont know why is that.
Also one more question, if I modify the Main.java like I have done, can I have any problem to launch it from Acceleo, I mean, not standalone?
Thank you very much for your help!
Re: [Acceleo] Launching a module from Java [message #540808 is a reply to message #539814] |
Thu, 17 June 2010 12:13 |
--------------090607070307080202070206
Daniel,
See comments inlined below.
Laurent Goubet
Obeo
> any problem?
The line just above my comment :
is the same as what you did just below :
Adding it again doesn't pose any issue.
> * @not-generated
> @Override
> // NASGUN
> * @not-generated
> @Override
> // NASGUN
> And now I dont get any exception :)
i'll try and answer this in your other message.
Nope, except if you add things in the java launcher that aren't
standalone themselves (if you have to add an import line for
"org.eclipse.core.*" or "org.osgi.*" ... you're prolly doing a "non
standalone" thing :p)
--------------090607070307080202070206--
Current Time: Mon Apr 29 02:01:20 GMT 2024
Powered by FUDForum. Page generated in 0.03557 seconds
