edit part figures [message #54341] |
Mon, 13 January 2003 10:47  |
Originally posted by: g.wagenknecht.intershop.de
Hi!
What do the GEF experts suggest to use as edit part figures? Currently I
simply use icons but I want to change this to a better GEF conforming way
because I want to profit from zoom and print support. My icon figures are
printed as black boxes.
Any suggestions?
Thanks, Gunnar
PS: Is there a document on how print/zoom support works / will work? (e.g:
How to hide figures that should not be printed.)
Re: edit part figures [message #58797 is a reply to message #54529] |
Tue, 28 January 2003 15:21  |
We do not dispose Colors, if this is what you are asking.
GEF uses mostly System colors, so there is no reason to dispose them. The
Logic example uses a couple of more colors, but they are statically defined
and will remain in memory until you shutdown Eclipse.
"Gunnar Wagenknecht" <g.wagenknecht@planet-wagenknecht.de> wrote in message
news:avv8hm$3b1$1@rogue.oti.com...
> Hi!
> "Dan Lee" <noone@ibm.com> schrieb im Newsbeitrag
> news:avv127$sg8$1@rogue.oti.com...
> > The Figures in the Logic Example have recently been redone so they take
> > advantage of zoom support. Check out AndGateFigure, OrGateFigure,
> LEDFigure,
> > etc. These used to use icons, but now implement the
paintFigure(Graphics)
> > method. This makes the figures look much nicer when zooming.
> How are colors managed? I noticed different colors for AndGateFigure and
> OrGateFigure but it doesn't look like that #paintFigure handel color
> management. Where is it implemented?
> Thanks, Gunnar
FUDForum. Page generated in 0.05049 seconds
