Home » Archived » XML Schema Definition (XSD) » EMF-based DOM
EMF-based DOM [message #54334] Mon, 01 November 2004 12:45 Go to next message
Originally posted by: gj.puredge.com
I apologize if this question is in the wrong newsgroup. If it is could
someone direct me to the one that would be more appropriate?
I've used the XSD model for a while and I know that it is based on an EMF
model. From what I have seen there also seems to be a DOM under the covers.
I am doing some other similar work, although not with XSD directly, that
will also be EMF based and was wondering if there is an EMF based DOM
implementation anywhere.
Does anyone know of an EMF DOM implementation?
Re: EMF-based DOM [message #54362 is a reply to message #54334] Mon, 01 November 2004 13:01 Go to previous messageGo to next message
Gary,
No, there isn't an EMF-based DOM implementation. (But an instance of
org.eclipse.emf.ecore.xml.type.AnyType can be used to represent
arbitrary DOM-like content.)
Gary J wrote:
>Hi,
>Thanks
Re: EMF-based DOM [message #54389 is a reply to message #54362] Tue, 02 November 2004 12:33 Go to previous messageGo to next message
How do I access org.eclipse.emf.ecore.xml.type.AnyType from the ecore
editor? It doesn't have that as a choice when it comes to assigning types?
Is there an EMF newsgroup? I really don't want to be asking questions about
this stuff in the wrong group . XSD uses EMF and is the only one I know
that's even close ~)
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:cm5tmi$ah5$1@eclipse.org...
Gary,
Gary J wrote:
>Hi,
covers.
>Thanks
Re: EMF-based DOM [message #54412 is a reply to message #54389] Tue, 02 November 2004 12:57 Go to previous message
--------------090508060806000507060303
Gary,
Yes, there is an EMF newsgroup:
news://news.eclipse.org/eclipse.tools.emf
The XMLType package is in the org.eclipse.emf.ecore plugin. The
..ecore/.xsd/.genmodel for it is in the src/model folder of that plugin.
You'd need to load the XMLType.ecore into the Ecore editor before you
can use it.
>Gary,
>Gary J wrote:
>>Hi,
>covers.
>>Thanks
<html>
<head>
</head>
Gary,<br>
<br>
Yes, there is an EMF newsgroup:<br>
<blockquote><a href="news://news.eclipse.org/eclipse.tools.emf">news://news.eclipse.org/eclipse.tools.emf</a><br>
</blockquote>
The XMLType package is in the org.eclipse.emf.ecore plugin.&nbsp; The
plugin.&nbsp; You'd need to load the XMLType.ecore into the Ecore editor
before you can use it.&nbsp; <br>
<br>
<br>
Gary J wrote:
<blockquote cite="midcm8gce$tuu$1@eclipse.org" type="cite">
<pre wrap="">How do I access org.eclipse.emf.ecore.xml.type.AnyType from the ecore
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com">&lt;merks@ca.ibm.com&gt;</a> wrote in message
<a class="moz-txt-link-freetext" href="news:cm5tmi$ah5$1@eclipse.org">news:cm5tmi$ah5$1@eclipse.org</a>...
Gary,
Gary J wrote:
</pre>
<blockquote type="cite">
<pre wrap="">Hi,
</pre>
</blockquote>
<pre wrap=""><!---->covers.
</pre>
<pre wrap="">I am doing some other similar work, although not with XSD directly, that
</pre>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
--------------090508060806000507060303--
Re: EMF-based DOM [message #592274 is a reply to message #54334] Mon, 01 November 2004 13:01 Go to previous message
Gary,
Gary J wrote:
>Hi,
>Thanks
Re: EMF-based DOM [message #592297 is a reply to message #54362] Tue, 02 November 2004 12:33 Go to previous message
Gary,
Gary J wrote:
>Hi,
covers.
>Thanks
Re: EMF-based DOM [message #592309 is a reply to message #54389] Tue, 02 November 2004 12:57 Go to previous message
Gary,
can use it.
>Gary,
>Gary J wrote:
>>Hi,
>covers.
>>Thanks
<html>
<head>
</head>
Gary,<br>
<br>
</blockquote>
<br>
<br>
Gary,
Gary J wrote:
</pre>
<pre wrap="">Hi,
</pre>
</blockquote>
</pre>
</pre>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
Previous Topic:EMF-based DOM
Next Topic:unresolved element ref
Current Time: Fri Jul 25 03:05:44 EDT 2025
Powered by FUDForum. Page generated in 0.29611 seconds
