Home » Eclipse Projects » Plugin Development Environment (PDE) » Can't see what's wrong
Can't see what's wrong [message #54308] Thu, 09 April 2009 20:22 Go to next message
After adding some dependencies ("Imported Packages") to a plug-in project,
the project is no longer building (no class files generated when I do
"Project" > "Clean..." and there is an error icon on the project in the
Package Explorer). Quite possible that there is a problem with one of the
dependencies, but I can't find any indication of what the exact error is,
either in the Problems View or Error Log, in the manifest editor, or in
the project property pages. And doing Validate Plug-ins in the launch
configuration doesn't return an error, either... Where else can I look?
Re: Can't see what's wrong [message #54336 is a reply to message #54308] Fri, 10 April 2009 03:09 Go to previous messageGo to next message
> project, the project is no longer building (no class files generated
> when I do "Project" > "Clean..." and there is an error icon on the
> project in the Package Explorer). Quite possible that there is a problem
> with one of the dependencies, but I can't find any indication of what
> the exact error is, either in the Problems View or Error Log, in the
> manifest editor, or in the project property pages. And doing Validate
> Plug-ins in the launch configuration doesn't return an error, either...
Does the project build if you remove those "imported packages". If yes, once remove them, do a clean rebuild. And then add the dependency again. If there an error something SHOULD come up in problems view. If not, open a bug report.
hth,
Ankur..
Re: Can't see what's wrong [message #54471 is a reply to message #54336] Fri, 10 April 2009 14:13 Go to previous messageGo to next message
Turns out the error message was being hidden by a rogue custom filter :-)
Now I have:
"A cycle was detected in the build path of project 'xyz'"
But I'm still having trouble seeing what that is due to: Performing "Look
for cycles in the dependency graph" in the manifest editor (in any of the
projects in my workspace) tells me that "the dependency graph of this
plug-in does not contain cycles". And as mentioned, I don't see any
warning or error markers in any of the projects "Java Build Properties"...
Re: Can't see what's wrong [message #54498 is a reply to message #54471] Fri, 10 April 2009 19:41 Go to previous messageGo to next message
Follow-up: I found a circular dependency between the "Imported Packages"
of two plug-ins (though both imports were marked with with
resolution:=optional). After resolving that issue everything works fine.
Wish Eclipse had been able to pinpoint the problem more accurately (and
not simply mark the projects + all projects that depend on them with the
same, unspecific error message)!
Re: Can't see what's wrong [message #54524 is a reply to message #54498] Fri, 10 April 2009 22:11 Go to previous message
>> "Look for cycles in the dependency graph" in the manifest editor (in
>> any of the projects in my workspace) tells me that "the dependency
>> graph of this plug-in does not contain cycles". And as mentioned, I
>> don't see any warning or error markers in any of the projects "Java
I would file a bug if you can. In the plug-in dependencies view, there
should be a "Show State Status" option (in 3.5, this is now in a
separate view known as 'Target Platform State':
http://help.eclipse.org/ganymede/topic/org.eclipse.pde.doc.u ser/guide/tools/views/plugin_dependencies.htm
I wonder if that would have revealed the problem.
Chris Aniszczyk | EclipseSource Austin | +1 860 839 2465
http://twitter.com/eclipsesource | http://twitter.com/caniszczyk
Re: Can't see what's wrong [message #594872 is a reply to message #54308] Fri, 10 April 2009 03:09 Go to previous message
hth,
Ankur..
Re: Can't see what's wrong [message #594913 is a reply to message #54336] Fri, 10 April 2009 14:13 Go to previous message
Now I have:
Re: Can't see what's wrong [message #594923 is a reply to message #54471] Fri, 10 April 2009 19:41 Go to previous message
Re: Can't see what's wrong [message #594935 is a reply to message #54498] Fri, 10 April 2009 22:11 Go to previous message
Previous Topic:override copy action of editorpart (CopyCurrentLine)
Next Topic:what's new in basebuilder R35_M6 ?
Current Time: Sun Aug 31 02:33:31 EDT 2025
Powered by FUDForum. Page generated in 0.05372 seconds
