Home » Newcomers » Newcomers » How to use plugins?
How to use plugins? [message #54297] Tue, 19 April 2005 01:53 Go to next message
After downloaded a plugin and unzip it into features and plugin directories
of Eclipse, I open File>New>Other to use it, but I cannot see what I
expected. Any help? Thanks!
Sam Hwang
Re: How to use plugins? [message #54536 is a reply to message #54297] Tue, 19 April 2005 09:09 Go to previous messageGo to next message
Hello
Try using "Window", "Open Perspective", "Other..." or "Window", "Show
View", "Other..." (depends whether the plug-in contributes a perspective
or just a view). If you cannot find it in these places, chances are high
that the installation failed or some dependencies are not met.
Hope this helps
Michael Pellaton
Re: How to use plugins? [message #54640 is a reply to message #54536] Tue, 19 April 2005 10:28 Go to previous messageGo to next message
Originally posted by: Chris_Laffra.ca.ibm.com
If you still don't see them, run eclipse once with -clean
Chris Laffra, http://eclipsefaq.org
"Michael Pellaton" <newsgroups@pellaton.li> wrote in message
news:d430dd$1hp$1@news.eclipse.org...
directories
> Hello
> Hope this helps
> Michael Pellaton
Re: How to use plugins? [message #55390 is a reply to message #54536] Wed, 20 April 2005 04:46 Go to previous messageGo to next message
Hello and thanks,
What do u mean installation failed? I just unzipped
eclipse-SDK-3.0.2-win32.zip to a proper place and run the program and that
is all. Have I missed something?
Sam Hwang
??????:d430dd$1hp$1@news.eclipse.org...
>> directories
> Hello
> Hope this helps
> Michael Pellaton
Re: How to use plugins? [message #55443 is a reply to message #55390] Wed, 20 April 2005 06:18 Go to previous message
No, you haven't - I meant the installation of the Plug-in. Possible
cuases of problems when installing Plugi-ns:
- problems with the plug-in regstry
solution of this issue in Chris Laffra's posting of 2005-04-19 16:28h
- plug-in not unzipped to the plugin-directory
plug-in does not show up on the view "Plugins"
- dependencies not met
use the View "Plug-ins" to find out details
- version missmatch
The Views "Plug-in Registry" and "Plug-in Dependencies" are generally
very helpful!
Hope this helps
Michael Pellaton
Previous Topic:IWAB0398E Error in generating WSDL from Java java.lang.ClassNotFoundException:
Next Topic:How to integrate SWT into Visual Editor?
Current Time: Mon Jul 21 21:30:49 EDT 2025
Powered by FUDForum. Page generated in 0.09256 seconds
