Re: Get Session Context through scriptin [message #58238 is a reply to message #56088] |
Thu, 14 July 2005 07:19  |
At first to say thank you to Stavros for posting this topic to this
newsgroup.
It is not really neccessary to have the session in the script. This would
only be a workaround for another problem: it is currently not possible to
set
the DataSource during runtime of an own program.
However, because I needed a fast solution I switched to JasperReport
library
with iReport GUI Editor. JasperReport already provides the possibilities:
1. during design time
* to create template in GUI editor
* use a DummyDataSource for designer
* also use Objects as report parameter with scripted default value
e.g. parameter["ReportUser"] = new DummyUser("Marco", "male")
* write script to access parameter content
e.g. parameter["ReportUser"].getName()
2. during own application runtime
* to load the template
* set real DataSource
e.g. to (DataSource) session.getAttribute("searchResult")
* set real report parameter
e.g. to session.getAttribute("currentUser")
* create PDF with report
IMO BIRT should go a similar way. JasperReport already offers me this
possibilities. Moreover I can use multiple GUI editors all using the same
*.jrxml structure.
FUDForum. Page generated in 0.05709 seconds
