Home » Modeling » TMF (Xtext) » Grammar reuse
Grammar reuse [message #54277] |
Tue, 30 June 2009 17:18  |
I'm trying to create a DSL using TMF and I encountered a problem that I
couldn't solve, despite a lot of search (including here in the newsgroup).
The problem concerns grammar reuse, I will try to explain it with a
simplified example.
Let's say I create a grammar A:
grammar dsl.ProjectA with org.eclipse.xtext.common.Terminals
generate projectA "http://www.ProjectA.dsl"
Model:
(terms += Term)*;
Term:
"big structure goes here" {Term};
And I use that grammar to create a grammar B:
grammar dsl.ProjectB with dsl.ProjectA
generate projectB "http://www.ProjectB.dsl"
Model:
(equations+=Equation)*;
Equation:
left=Term "=" right=Term;
The ProjectB imports (and reexports) the ProjectA, and there are no
visible errors. I still don't get errors during the code generation for
the ProjectB, but when I try to open the generated metamodel, I get an
UnknownHostException. Apparently, the ProjectB.ecore makes a reference to
"http://www.ProjectA.dsl#//Term", which it cannot resolve.
After reading some posts, I modified the GenerateProjectB.mwe file in
order to register the ProjectA Package, and to use it's genmodel:
<workflow>
<bean class="org.eclipse.emf.mwe.utils.StandaloneSetup"
platformUri="${runtimeProject}/..">
<registerGeneratedEPackage value="dsl.projectA.ProjectAPackage"/>
</bean>
<component class="org.eclipse.xtext.generator.Generator">
<language uri="${grammarURI}" fileExtensions="${file.extensions}">
<fragment
class=" org.eclipse.xtext.generator.grammarAccess.GrammarAccessFragm ent "/>
<fragment
class="org.eclipse.xtext.generator.ecore.EcoreGeneratorFragment ">
<genModels
value="platform:/resource/ProjectA/src-gen/dsl/ProjectA.genmodel "/>
</fragment>
</language>
</component>
</workflow>
The generation still doesn't show any error, but the metamodel is still
wrong.
I also tried to import the ProjectA metamodel in the ProjectB grammar
(using import "platform:/resource/ProjectA/src-gen/dsl/ProjectA.ecore" as
projectAmm). With this I was able to create a rule like the following one:
Equation:
left=[projectAmm::Term] "=" right=[projectAmm::Term];
With this I generated a correct ProjectB.ecore, and even a correct editor,
but I don't want references, I really want to parse new terms while
creating my equations. And a rule:
Equation:
left=projectAmm::Term "=" right=projectAmm::Term;
isn't accepted.
Where did I go wrong?
Sorry for the long post, I really don't have any idea, and I hope someone
will be able to help me. Thanks in advance!
Alexis Marechal
Re: Grammar reuse [message #54566 is a reply to message #54277] |
Wed, 01 July 2009 16:37   |
> to "http://www.ProjectA.dsl#//Term", which it cannot resolve.
That's ok. The generated ecore file references the derived EPackage from
the grammar by its nsURI. If you want to open it, you'll have to make
the ecore model available by its nsURI.
> </bean>
This is not needed and should be removed.
> <fragment
> <fragment
> <genModels
> </fragment>
This is correct.
Adding the genmodel is important!
> wrong.
It's not wrong. It is just not openable without the needed context
> as projectAmm). With this I was able to create a rule like the following
> one:
If you want to refer to types from the super grammar you need to import
the metamodel by its nsURI. But you don't reference any types, just
rules. It's sometimes hard to distinguish, especially because they
typically share rthe same name.
> Equation:
Cross references is not what you wanted.
> editor, but I don't want references, I really want to parse new terms
> while creating my equations. And a rule:
> Equation:
You try to refer to types, but types are only referenced from within
cross references (foo=[MyType]) while common assignments, i.e.
containment references point to rules (foo=MyRule).
So left=Term is correct.
> isn't accepted.
I'm not sure what the problem is. The generated ecore files can't be
opened with an editor.
Sven
Re: Grammar reuse [message #56999 is a reply to message #54566] |
Fri, 10 July 2009 05:43   |
Hi Sven,
It's only when a grammar inherits from another grammar in the workspace
the generated Ecore or GenModel files cannot be opened in the editor.
If other models are imported using the recommended platform:/resource
URIs, then the Ecore and GenModel can be opened without problems. This
is because the references in the Ecore file use the platform URI. E.g.
<eStructuralFeatures xsi:type="ecore:EReference" name="ref"
eType="ecore:EClass
platform:/resource/org.xtext.example.mydsl/src-gen/org/xtext /example/MyDsl.ecore#//Type "/>
It would be nice if the generated Ecore and GenModel files could also be
opened when using grammar mixins. This is useful when you want to work
out a transformation to apply in the post processor.
--knut
Sven Efftinge wrote:
>> for the ProjectB, but when I try to open the generated metamodel, I
>> get an UnknownHostException. Apparently, the ProjectB.ecore makes a
>> reference to "http://www.ProjectA.dsl#//Term", which it cannot resolve.
>> </bean>
>> <fragment
>> <fragment
>> <genModels
>> </fragment>
> This is correct.
>> still wrong.
>> following one:
>> Equation:
>> Equation:
>> isn't accepted.
> Sven
Re: Grammar reuse [message #57284 is a reply to message #56999] |
Mon, 13 July 2009 03:05   |
Hi Knut,
I agree.
Please open a bugzilla for that.
Sven
Knut Wannheden schrieb:
> Hi Sven,
> eType="ecore:EClass
> Cheers,
> --knut
>> from the grammar by its nsURI. If you want to open it, you'll have to
>> make the ecore model available by its nsURI.
>>> </bean>
>>> <fragment
>>> <fragment
>>> <genModels
>>> </fragment>
>> This is correct.
>>> still wrong.
>>> (using import
>>> one:
>> import the metamodel by its nsURI. But you don't reference any types,
>> just rules. It's sometimes hard to distinguish, especially because
>> they typically share rthe same name.
>>> Equation:
>>> Equation:
>>> isn't accepted.
>> Sven
Current Time: Fri Aug 29 14:39:38 EDT 2025
Powered by FUDForum. Page generated in 0.05130 seconds
