Re: Resource factory needed exception while running Ecore2Java Ant task outside the Eclipse [message #538838 is a reply to message #538801] |
Tue, 08 June 2010 17:57 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Ed Merks![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=ed.merks%40gmail.com) Messages: 33187 Registered: July 2009 |
--------------080607090703080306070703
Axel,
When running outside of Eclipse *all *plugin.xml registrations need to
be done manually. You should run it as an Eclipse ant task.
Axel Guckelsberger wrote:
> this is actually a question regarding EMF, thus I added the corresponding
> newsgroup as well.
> I got this task working by using Buckminster which runs a headless Eclipse
> installation. Don't know how to proceed with pure ant though.
> HTH
> Axel
> login wrote:
>> Hi All,
>> I am trying to run the Ecore2Java ant task outside the Eclipse but i
>> couldnt .
>> I got the follwowing exception .If any body has hints about this condition
>> pls let me knw.
>> Does Ecore2Java task can be run outside the Eclipse?
>> C:\CDEWorkspace\spectrial\build.xml:76: java.lang.RuntimeException:
>> org.eclipse. emf.common.util.DiagnosticException: RuntimeException: Cannot
>> create a resource for
>> 'file:/C:/CDEWorkspace/spectrial/model/spectrial.genmodel'; a registered
>> res ource factory is needed
>> at org.eclipse.emf.importer.ModelImporterApplication.handleGenM
>> odelPath(
>> ModelImporterApplication.java:447)
>> at org.eclipse.emf.importer.ModelImporterApplication.adjustMode
>> lImporter
>> (ModelImporterApplication.java:427)
>> at org.eclipse.emf.importer.ModelImporterApplication.execute(Mo
>> delImport
>> erApplication.java:213)
>> at org.eclipse.emf.importer.ModelImporterApplication.run(ModelI
>> mporterAp
>> plication.java:178)
>> mporterAp
>> plication.java:162)
>> at org.eclipse.emf.importer.ecore.taskdefs.EcoreGeneratorTask.c
>> reateGenM
>> odel(EcoreGeneratorTask.java:81)
>> at org.eclipse.emf.ant.taskdefs.codegen.ecore.GeneratorTask.doE
>> xecute(Ge
>> neratorTask.java:380)
>> at org.eclipse.emf.ant.taskdefs.EMFTask.execute(EMFTask.java:76 )
>> at org.apache.tools.ant.UnknownElement.execute(UnknownElement.j
>> ava:291) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native
>> Method)
>> at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce
>> ssorImpl.
>> java:39)
>> at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe
>> thodAcces
>> sorImpl.java:25)
>> at java.lang.reflect.Method.invoke(Method.java:585)
>> at org.apache.tools.ant.dispatch.DispatchUtils.execute(Dispatch
>> Utils.jav
>> a:106)
>> at org.apache.tools.ant.Task.perform(Task.java:348)
>> at org.apache.tools.ant.Target.execute(Target.java:390)
>> at org.apache.tools.ant.Target.performTasks(Target.java:411)
>> at org.apache.tools.ant.Project.executeSortedTargets(Project.ja
>> va:1397)
>> at org.apache.tools.ant.Project.executeTarget(Project.java:1366 )
>> at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(D
>> efaultExe
>> cutor.java:41)
>> at org.apache.tools.ant.Project.executeTargets(Project.java:124
>> 9) at org.apache.tools.ant.Main.runBuild(Main.java:801)
>> at org.apache.tools.ant.Main.startAnt(Main.java:218)
>> at org.apache.tools.ant.launch.Launcher.run(Launcher.java:280)
>> at org.apache.tools.ant.launch.Launcher.main(Launcher.java:109)
>> Caused by: org.eclipse.emf.common.util.DiagnosticException:
>> RuntimeException: Ca nnot create a resource for
>> 'file:/C:/CDEWorkspace/spectrial/model/spectrial.genm odel'; a registered
>> resource factory is needed
>> at org.eclipse.emf.importer.ModelImporter.loadOriginalGenModel(
>> ModelImpo
>> rter.java:513)
>> at org.eclipse.emf.importer.ModelImporter.defineOriginalGenMode
>> lPath(Mod
>> elImporter.java:167)
>> odelPath(
>> ModelImporterApplication.java:443)
>> ... 24 more
>> Caused by: java.lang.RuntimeException: Cannot create a resource for
>> 'file:/C:/CD EWorkspace/spectrial/model/spectrial.genmodel'; a registered
>> resource factory is
>> needed
>> at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou
>> rce(Resou
>> rceSetImpl.java:394)
>> ModelImpo
>> rter.java:470)
>> ... 26 more
>> Total time: 1 second
>> C:\CDEWorkspace\spectrial>
<html>
<head>
</head>
Axel,<br>
<br>
When running outside of Eclipse <b>all </b>plugin.xml registrations
need to be done manually. You should run it as an Eclipse ant task.<br>
<br>
<br>
<blockquote cite="mid:hulrc7$iju$1@build.eclipse.org" type="cite">
<pre wrap="">Hi,
newsgroup as well.
HTH
Axel
login wrote:
</pre>
<blockquote type="cite">
<pre wrap="">Hi All,
couldnt .
pls let me knw.
'<a class="moz-txt-link-freetext" href="file:/C:/CDEWorkspace/spectrial/model/spectrial.genmodel ">file:/C:/CDEWorkspace/spectrial/model/spectrial.genmodel</a >'; a registered
odelPath(
lImporter
delImport
mporterAp
plication.java:178)
mporterAp
plication.java:162)
reateGenM
xecute(Ge
Method)
ssorImpl.
java:39)
thodAcces
sorImpl.java:25)
Utils.jav
a:106)
va:1397)
efaultExe
cutor.java:41)
'<a class="moz-txt-link-freetext" href="file:/C:/CDEWorkspace/spectrial/model/spectrial.genm" >file:/C:/CDEWorkspace/spectrial/model/spectrial.genm</a> odel'; a registered
ModelImpo
rter.java:513)
lPath(Mod
odelPath(
... 24 more
'<a class="moz-txt-link-freetext" href="file:/C:/CD">file:/C:/CD</a> EWorkspace/spectrial/model/spectrial.genmodel'; a registered
resource factory is
needed
rce(Resou
ModelImpo
rter.java:470)
... 26 more
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
</body>
</html>
--------------080607090703080306070703--
Ed Merks
FUDForum. Page generated in 0.03800 seconds
