Home » Archived » Test and Performance Tools Platform (TPTP) » invalid SHA1
invalid SHA1 [message #54234] Mon, 20 February 2006 17:27
I have downloaded and installed EMF 2.1.1 SDK into an extension directory.
I also installed TPTP version 4.0.1 into an extension directory. I
created a simple probe and am receiving the following stack trace when
trying to instrument 3 packges from the probe.
I've searched both this newsgroup and google without any close hits. Any
help would be greatly appreciated.
Timothy Vogel
!ENTRY org.eclipse.hyades.probekit.ui 2 0 2006-02-20 17:26:48.186
!MESSAGE
!STACK 0
java.lang.reflect.InvocationTargetException
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:327)
org.eclipse.jface.dialogs.ProgressMonitorDialog.run(Progress MonitorDialog.java:447)
org.eclipse.hyades.probekit.editor.internal.ui.instrument.In strumentRunnableWithProgress.open(InstrumentRunnableWithProg ress.java:117)
org.eclipse.hyades.probekit.editor.internal.ui.instrument.Pr obeInstrumenterAction.run(ProbeInstrumenterAction.java:89)
org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:246)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3080)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2713)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Caused by: java.lang.SecurityException: invalid SHA1 signature file digest
for sun/security/pkcs11/JarVerifierImpl$2.class
at sun.security.util.SignatureFileVerifier.verifySection(Unknow n Source)
at sun.security.util.SignatureFileVerifier.processImpl(Unknown Source)
at sun.security.util.SignatureFileVerifier.process(Unknown Source)
at java.util.jar.JarVerifier.processEntry(Unknown Source)
at java.util.jar.JarVerifier.update(Unknown Source)
at java.util.jar.JarInputStream.read(Unknown Source)
org.eclipse.hyades.probekit.internal.JarReader.extractAll(Ja rReader.java:126)
org.eclipse.hyades.probekit.ProbeInstrumenterDriver.processJ arFile(ProbeInstrumenterDriver.java:469)
org.eclipse.hyades.probekit.ProbeInstrumenterDriver.instrume ntItems(ProbeInstrumenterDriver.java:308)
org.eclipse.hyades.probekit.editor.internal.core.instrument. InstrumentOperation.instrument(InstrumentOperation.java:154)
org.eclipse.hyades.probekit.editor.internal.core.instrument. InstrumentOperation.run(InstrumentOperation.java:407)
org.eclipse.hyades.probekit.editor.internal.ui.instrument.In strumentRunnableWithProgress.run(InstrumentRunnableWithProgr ess.java:69)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:113)
Root exception:
java.lang.SecurityException: invalid SHA1 signature file digest for
Previous Topic:When will TPTP be JVMTI (JSR 163) compliant?
Next Topic:Automated GUI Recorder issues
Current Time: Fri Sep 12 15:33:13 EDT 2025
Powered by FUDForum. Page generated in 0.02586 seconds
