Home » Modeling » OCL » NPE using OCL ValidationVisitor
NPE using OCL ValidationVisitor [message #54185] Wed, 23 April 2008 06:48 Go to next message
Hi Christian,
Validating a variableExp which doesn't have a referredVariable, throws
an exception. In fact, it's a problem of the ToStringVisitor, which is
used when toString() is invoked in a VariableExp with out referredVariable.
the ToStringVisitior.visitVariablExp method should check that the
referredVariable from the variableExp is not null before getting its name.
If you agree, I could arise a bugzilla with a patch...
the trace:
org.eclipse.ocl.util.ToStringVisitor.visitVariableExp(ToStri ngVisitor.java:203)
org.eclipse.ocl.util.ToStringVisitor.visitVariableExp(ToStri ngVisitor.java:1)
org.eclipse.ocl.ecore.impl.VariableExpImpl.accept(VariableEx pImpl.java:233)
org.eclipse.ocl.ecore.impl.OCLExpressionImpl.toString(OCLExp ressionImpl.java:317)
org.eclipse.ocl.ecore.impl.VariableExpImpl.toString(Variable ExpImpl.java:225)
org.eclipse.ocl.parser.ValidationVisitor.visitVariableExp(Va lidationVisitor.java:320)
org.eclipse.ocl.parser.ValidationVisitor.visitVariableExp(Va lidationVisitor.java:1)
org.eclipse.ocl.parser.ValidationVisitor.visitOperationCallE xp(ValidationVisitor.java:196)
org.eclipse.ocl.parser.ValidationVisitor.visitOperationCallE xp(ValidationVisitor.java:1)
org.eclipse.ocl.ecore.impl.OperationCallExpImpl.accept(Opera tionCallExpImpl.java:357)
org.eclipse.gmt.umlx.eqvto.cst.environment.QVToEnvironment.o clValidation(QVToEnvironment.java:391)
org.eclipse.gmt.umlx.eqvto.cst.environment.QVToEnvironment.o clValidation(QVToEnvironment.java:400)
org.eclipse.gmt.umlx.eqvto.cst.environment.QVToEnvironment.v alidate(QVToEnvironment.java:382)
org.eclipse.gmt.umlx.eqvto.cst.environment.QVToTopLevelEnvir onment.validate(QVToTopLevelEnvironment.java:46)
org.eclipse.gmt.umlx.eqvto.tests.parser.AbstractQVToTestCase .parserTest(AbstractQVToTestCase.java:108)
org.eclipse.gmt.umlx.eqvto.tests.parser.QVToParseTests.testP arseEQVTOperational_ImperativeIterateExp(QVToParseTests.java :214)
at junit.framework.TestCase.runTest(TestCase.java:164)
at junit.framework.TestCase.runBare(TestCase.java:130)
at junit.framework.TestResult$1.protect(TestResult.java:106)
at junit.framework.TestResult.runProtected(TestResult.java:124)
at junit.framework.TestResult.run(TestResult.java:109)
at junit.framework.TestCase.run(TestCase.java:120)
at junit.framework.TestSuite.runTest(TestSuite.java:230)
at junit.framework.TestSuite.run(TestSuite.java:225)
org.eclipse.jdt.internal.junit.runner.junit3.JUnit3TestRefer ence.run(JUnit3TestReference.java:130)
org.eclipse.jdt.internal.junit.runner.TestExecution.run(Test Execution.java:38)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:460)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:673)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:386)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main( RemoteTestRunner.java:196)
Adolfo.
Re: NPE using OCL ValidationVisitor [message #54313 is a reply to message #54185] Wed, 23 April 2008 14:27 Go to previous message
Hi, Adolfo,
Of course, I agree! NPEs in validation of an expression are bugs, except
only in the case that the input expression is a null pointer (which would
be a silly input).
cW
Adolfo Sánchez-Barbudo Herrera wrote:
> Hi Christian,
> referredVariable.
-----8<-----
Previous Topic:RE: OCL Def Operations & Attributes
Next Topic:[Announce] MDT OCL 1.2.0 I200804231800 is available
Current Time: Thu Jul 31 10:40:52 EDT 2025
Powered by FUDForum. Page generated in 0.04594 seconds
