Home » Eclipse Projects » Plugin Development Environment (PDE) » Issue creating cheatsheet with command
Issue creating cheatsheet with command [message #54178] Wed, 08 April 2009 09:32 Go to next message
I want to create a cheatsheet containing a task that can be done
automatically by using a command.
I have defined a command in the SAME plug-in with a default handler.
The problem is that the Simple Cheat Sheet Editor is not able to find the
command. If I enter the ID in the XML source code and then change to the
"Definition" tab back, the editor shows an exception that the command
could not be found.
If I run the plug-in, executing the command works.
What am I doing wrong? Is there a criterion for such commands to be found?
Any workaround?
Re: Issue creating cheatsheet with command [message #54204 is a reply to message #54178] Wed, 08 April 2009 09:44 Go to previous message
It seems that the editor searchs for commands in the IDE, not in the
workspace plug-ins and target-platform... *grml*
Re: Issue creating cheatsheet with command [message #594820 is a reply to message #54178] Wed, 08 April 2009 09:44 Go to previous message
Previous Topic:Issue creating cheatsheet with command
Next Topic:how to write extra info on .project and .classpath?
Current Time: Sat Jul 26 06:43:26 EDT 2025
Powered by FUDForum. Page generated in 0.04732 seconds
