Home » Language IDEs » Java Development Tools (JDT) » What is "Refactoring with Participants" ... ?
What is "Refactoring with Participants" ... ? [message #54168] Wed, 11 June 2003 04:20 Go to next message
I searched the web site, the build notes, the mailinglists and the planning
notes. However, I was not able to determine the difference between the
"Rename" and the "Rename with Participants" refactorings? Could anyone
please point me to some document describing the intention of this new
implementation?
Boris
Re: What is "Refactoring with Participants" ... ? [message #54459 is a reply to message #54168] Wed, 11 June 2003 08:42 Go to previous messageGo to next message
This is work in progress (you enabled it on the work in progress preference
page).
It corresponds to the plan item described in bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=37937
The new Rename refactoring action doesn't differ from the old one in the
result you are seeing. But it is
coded on a new infrastructure which will allow other plug-ins to participate
in certain refactorings like
rename, move, delete. Those participants can then update non Java resources
like JSPs, plugin.xml, ....
The plan is to fully understand most of the issues til end of M2 and then to
propose a solution (based on the code
and a paper) to the community.
Dirk
"Boris Pruessmann" <boris@pruessmann.org> wrote in message
news:pan.2003.06.11.08.20.21.22334@pruessmann.org...
planning
> implementation?
> Boris
Re: What is "Refactoring with Participants" ... ? [message #56059 is a reply to message #54459] Fri, 13 June 2003 06:42 Go to previous message
Originally posted by: vkyr.nospam-ision.net
Dirk, don't forget to think also about change management integrations -for
none java source files- for the new refactoring infrastructure. It would be
cool to have a handle for change objects and the change preview for these
too. - Possibly some central extension points, which would have to be used
and some interfaces which would have to be implemented by any third party
entension plugins, would yield to the desired solution.
I'am looking forward to hear soon some news about the analyzation results
and possible solutions for the new refactoring infrastructure!
- Regards Valentino
"Dirk B
Previous Topic:Can't debug
Next Topic:Anyone using MyEclipse?
Current Time: Sat Jul 26 12:39:22 EDT 2025
Powered by FUDForum. Page generated in 0.06061 seconds
