Home » Archived » Buckminster » No reader type with id cvs has been registered(I am Trying to connect EMF public CVS and buckminster throws an error)
No reader type with id cvs has been registered [message #537187] Tue, 01 June 2010 11:00 Go to next message
I am trying to include an Eclipse CVS repository in the build of my product, but buckminster tells me that there is no CVS id registered in the reader type extension point.
Have you got any idea of the problem?
Sabri.
ERROR   [0000] : No suitable provider for component org.eclipse.emf.cdo:osgi.bundle/2.0.0 was found in resourceMap file:/var/lib/hudson/jobs/SWIFT_V2/workspace/com.ena.swift.feature.site/swiftV2.rmap
  ERROR   [0000] : No suitable provider for component org.eclipse.emf.cdo:osgi.bundle/2.0.0 was found in searchPath cdo
    ERROR   [0000] : Rejecting provider cvs(:pserver:anonymous@dev.eclipse.org:/cvsroot/modeling,org.eclipse.emf/org.eclipse.emf.cdo/plugins/{0}): No component match was found
      ERROR   No reader type with id cvs has been registered with extension-point org.eclipse.buckminster.core.readerTypes
ERROR   [0000] : No suitable provider for component org.eclipse.emf.cdo.ui:osgi.bundle/2.0.0 was found in resourceMap file:/var/lib/hudson/jobs/SWIFT_V2/workspace/com.ena.swift.feature.site/swiftV2.rmap
  ERROR   [0000] : No suitable provider for component org.eclipse.emf.cdo.ui:osgi.bundle/2.0.0 was found in searchPath cdo
The Rmap is:
<rmap xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.eclipse.org/buckminster/RMap-1.0"
	xmlns:bc="http://www.eclipse.org/buckminster/Common-1.0" xmlns:mp="http://www.eclipse.org/buckminster/MavenProvider-1.0"
	xmlns:pp="http://www.eclipse.org/buckminster/PDEMapProvider-1.0">
	<!-- Place your RMAP content here -->
	<searchPath name="resources">
		<provider readerType="local" componentTypes="osgi.bundle,eclipse.feature"
			mutable="true" source="true">
			<uri format="file:///{0}/{1}/">
				<bc:propertyRef key="workspace.root" />
				<bc:propertyRef key="buckminster.component" />
			</uri>
		</provider>
	</searchPath>
	<searchPath name="cdo">
		<provider readerType="cvs" componentTypes="osgi.bundle,eclipse.feature"
			<uri
				format=":pserver:anonymous@dev.eclipse.org:/cvsroot/modeling,org.eclipse.emf/org.eclipse.emf.cdo/plugins/{0}">
			</uri>
		</provider>
	</searchPath>
	<searchPath name="eclipse">
		<provider readerType="eclipse.import" componentTypes="osgi.bundle,eclipse.feature"
			mutable="true" source="false">
			<uri format="http://download.eclipse.org/technology/epp/packages/galileo?importType=binary" />
		</provider>
		<provider readerType="eclipse.import" componentTypes="osgi.bundle,eclipse.feature,buckminster"
			mutable="true" source="false" >
			<uri format="http://download.eclipse.org/releases/galileo?importType=binary" />
		</provider>
	</searchPath>
	<locator searchPathRef="resources" pattern="^com\.ena(\..+)?" />
	<locator searchPathRef="resources" pattern="^com\.swift(\..+)?" />
	<locator searchPathRef="resources" pattern="^com\.ena\.swift(\..+)?"/>
	<locator searchPathRef="cdo" pattern="^org\.eclipse\.emf\.cdo(\..+)?" />
	<locator searchPathRef="eclipse" pattern=".*" />
</rmap>
I have got the headless buckminster, installed from director:
./director
-r http://download.eclipse.org/tools/buckminster/headless-3.5/
-d /path/to/buckminster-headless/
-p Buckminster
-i org.eclipse.buckminster.cmdline.product
Re: No reader type with id cvs has been registered [message #537254 is a reply to message #537187] Tue, 01 June 2010 12:47 Go to previous message
Hi Sabri,
you have to install the cvs headless feature.
This is described at
http://wiki.eclipse.org/Sample_headless_configuration_(Buckminster)
HTH
Axel
> Sabri.
file:/var/lib/hudson/jobs/SWIFT_V2/workspace/com.ena.swift.f eature.site/swiftV2.rmap
cvs(:pserver:anonymous@dev.eclipse.org :/cvsroot/modeling,org.eclipse.emf/org.eclipse.emf.cdo/plugi ns/{0}):
> The Rmap is:
> xmlns:pp="http://www.eclipse.org/buckminster/PDEMapProvider-1.0"> <!--
> </uri>
> </provider>
> </searchPath>
> <uri
format=":pserver:anonymous@dev.eclipse.org :/cvsroot/modeling,org.eclipse.emf/org.eclipse.emf.cdo/plugi ns/{0} ">
> </uri>
> </provider>
> </searchPath>
> componentTypes="osgi.bundle,eclipse.feature" mutable="true"
> source="false"> <uri
format=" http://download.eclipse.org/technology/epp/packages/galileo? importType=binary"
> /> </provider> <provider readerType="eclipse.import"
> componentTypes="osgi.bundle,eclipse.feature,buckminster" mutable="true"
> source="false" > <uri
> format=" http://download.eclipse.org/releases/galileo?importType=bina ry" />
> </provider>
> </searchPath>
> </rmap>
> /director
> -p Buckminster
Previous Topic:Heads up on Buckminster Version Range Generation
Next Topic:SCM trigger in Hudson with Buckminster?
Current Time: Wed May 14 00:34:41 EDT 2025
Powered by FUDForum. Page generated in 0.03439 seconds
