Home » Archived » Test and Performance Tools Platform (TPTP) » Why is it so slow?
Why is it so slow? [message #54126] Mon, 20 February 2006 13:07 Go to next message
Originally posted by: remi.edreams.com
Why is TPTP so slow compared to others tools as OptimizeIt? It is a pity
because it is a very nice tool.
Rémi
Re: Why is it so slow? [message #54829 is a reply to message #54126] Fri, 24 February 2006 13:04 Go to previous message
Originally posted by: Navid_Mehregani_nmehrega.ca.ibm.com
This is a multipart message in MIME format.
--=_alternative 00633D0B8525711F_=
Content-Type: text/plain; charset="ISO-8859-1"
Hi R=E9mi,
There are a few things you can do to speed things up:
1) If you're using IAC (i.e. Local Direct Connection), try using RAC=20
instead
2) Selecting fewer profiling options will make things faster
3) The most important thing is to make sure you have your filters set up=20
properly. In your launch configuration -> click on 'Profiling' -> Select=20
your profiling set -> 'Edit' -> 'Next' -> 'Next' -> Set your filter set.=20
Try to exclude everything you're not interested in.
4) If it's still too slow, try profiling to a file: -> in the 'Profiling'=20
tab of your lauch configuration -> click on the 'Destination' tab -> 'Send =
profiling data to a file'. You can later import the profiling file by=20
going to File -> Import
Navid Mehregani
Content-Type: text/html; charset="ISO-8859-1"
<br><font size=3D2 face=3D"sans-serif">Hi </font><font size=3D2><tt>R=E9mi,=
</tt></font>
<br>
<br><font size=3D2 face=3D"sans-serif">There are a few things you can do to
speed things up:</font>
<br>
<br><font size=3D2 face=3D"sans-serif">1) If you're using IAC (i.e. Local D=
irect
Connection), try using RAC instead</font>
<br><font size=3D2 face=3D"sans-serif">2) Selecting fewer profiling options
will make things faster</font>
<br><font size=3D2 face=3D"sans-serif">3) The most important thing is to ma=
ke
sure you have your filters set up properly. &nbsp;In your launch configurat=
ion
-&gt; click on 'Profiling' -&gt; Select your profiling set -&gt; 'Edit'
-&gt; 'Next' -&gt; 'Next' -&gt; Set your filter set. &nbsp;Try to exclude
everything you're not interested in.</font>
<br><font size=3D2 face=3D"sans-serif">4) If it's still too slow, try profi=
ling
to a file: -&gt; in the 'Profiling' tab of your lauch configuration -&gt;
click on the 'Destination' tab -&gt; 'Send profiling data to a file'. &nbsp=
;You
can later import the profiling &nbsp;file by going to File -&gt; Import</fo=
nt>
<br>
<br>
<br><font size=3D2 face=3D"sans-serif">Navid Mehregani</font>
--=_alternative 00633D0B8525711F_=--
Previous Topic:External Profiling startup problems
Next Topic:hyades plug-in versus IAC
Current Time: Mon Jul 14 16:35:00 EDT 2025
Powered by FUDForum. Page generated in 0.07177 seconds
