Home » Eclipse Projects » Nebula » CDateTime - No more handles
CDateTime - No more handles [message #54093] Mon, 02 June 2008 00:43 Go to next message
Hello there.
We are using the Nebula CDateTime control and after a short time (and
with lots of other MS Windows applications running in the background) we
always get an "org.eclipse.swt.SWTError: No more handles" exception.
I attach the stacktrace below.
Does anybody know, why CDateTime uses so many handles and is there a
workaround/bugfix?
Peter
Stacktrace:
at org.eclipse.swt.SWT.error(SWT.java:3792)
at org.eclipse.swt.SWT.error(SWT.java:3684)
at org.eclipse.swt.SWT.error(SWT.java:3655)
at org.eclipse.swt.widgets.Widget.error(Widget.java:462)
org.eclipse.swt.widgets.Control.createHandle(Control.java:60 8)
org.eclipse.swt.widgets.Composite.createHandle(Composite.jav a:303)
org.eclipse.swt.widgets.Control.createWidget(Control.java:62 4)
org.eclipse.swt.widgets.Scrollable.createWidget(Scrollable.j ava:131)
at org.eclipse.swt.widgets.Control.<init>(Control.java:99)
org.eclipse.swt.widgets.Scrollable.<init>(Scrollable.java:72)
org.eclipse.swt.widgets.Composite.<init>(Composite.java:92)
org.eclipse.nebula.widgets.cdatetime.CButton.<init>(CButton.java:107)
org.eclipse.nebula.widgets.cdatetime.CButton.<init>(CButton.java:104)
org.eclipse.nebula.widgets.cdatetime.Picker_Calendar.createB ody(Picker_Calendar.java:205)
org.eclipse.nebula.widgets.cdatetime.Picker_Calendar.createC ontents(Picker_Calendar.java:258)
org.eclipse.nebula.widgets.cdatetime.AbstractPicker.updateCo ntents(AbstractPicker.java:93)
org.eclipse.nebula.widgets.cdatetime.Picker_Calendar.setFiel ds(Picker_Calendar.java:675)
org.eclipse.nebula.widgets.cdatetime.CDateTime.updatePickerF ormat(CDateTime.java:1035)
org.eclipse.nebula.widgets.cdatetime.CDateTime.setPattern(CD ateTime.java:905)
org.eclipse.nebula.widgets.cdatetime.CDateTime.setFormat(CDa teTime.java:864)
org.eclipse.nebula.widgets.cdatetime.CDateTime.<init>(CDateTime.java:268)
Re: CDateTime - No more handles [message #54625 is a reply to message #54093] Wed, 18 June 2008 07:36 Go to previous messageGo to next message
Hi Peter,
The inner workings of the CDateTime widget have been rewritten to
eliminate this problem. In the interest of time however, the code is
presently hosted back at its original sourceforge location:
http://sourceforge.net/projects/calypsorcp
The active repo is subversion.
cheers,
jeremy
Peter Pfeifer wrote:
> Hello there.
> workaround/bugfix?
> Peter
> Stacktrace:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: CDateTime - No more handles [message #61848 is a reply to message #54625] Mon, 19 January 2009 12:42 Go to previous messageGo to next message
Hello everybody,
Has this been corrected on the CDateTime version hosted on the
dev.eclipse.org CVS server ?
I have problems with the menu bar going white after a CDateTime
selection (combo style) selection on Vista and I found out it might be
related to this...
Please advice
Thanks a lot
Liviu
PS: I have already checked out calypsorcp and the took the latest
version from the dev.eclipse.org but they are apparently quite different
and I don't know what to choose.
Jeremy Dowdall wrote:
> Hi Peter,
> cheers,
> jeremy
>> Hello there.
>> we always get an "org.eclipse.swt.SWTError: No more handles" exception.
>> workaround/bugfix?
>> Regards,
>> Peter
>> Stacktrace:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Re: CDateTime - No more handles [message #61871 is a reply to message #61848] Mon, 19 January 2009 19:24 Go to previous message
Hi Liviu,
Yes, this has been fixed in the dev.eclipse.org CVS.
Use the version from eclipse - it is the one actively being developed
now and the sf version will be going away soon.
The two versions look quite different because part of the move back to
Nebula (beyond going through IP review) involved extracting the core
components of CDateTime into a separate project so that they may be
consumed by other widgets/projects.
cheers,
Jeremy
Liviu wrote:
> Hello everybody,
> related to this...
> Please advice
> Thanks a lot
> Liviu
>> Hi Peter,
>> cheers,
>> jeremy
>>> Hello there.
>>> workaround/bugfix?
>>> Regards,
>>> Peter
>>> Stacktrace:
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
Re: CDateTime - No more handles [message #590510 is a reply to message #54093] Wed, 18 June 2008 07:36 Go to previous message
Hi Peter,
cheers,
jeremy
> Hello there.
> workaround/bugfix?
> Peter
> Stacktrace:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: CDateTime - No more handles [message #593228 is a reply to message #54625] Mon, 19 January 2009 12:42 Go to previous message
Hello everybody,
related to this...
Please advice
Thanks a lot
Liviu
> Hi Peter,
> cheers,
> jeremy
>> Hello there.
>> workaround/bugfix?
>> Regards,
>> Peter
>> Stacktrace:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Re: CDateTime - No more handles [message #593236 is a reply to message #61848] Mon, 19 January 2009 19:24 Go to previous message
Hi Liviu,
cheers,
Jeremy
Liviu wrote:
> Hello everybody,
> related to this...
> Please advice
> Thanks a lot
> Liviu
>> Hi Peter,
>> cheers,
>> jeremy
>>> Hello there.
>>> workaround/bugfix?
>>> Regards,
>>> Peter
>>> Stacktrace:
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
Previous Topic:RowHeader - Sorting and resizing
Next Topic:Gallery with widgets instead of images
Current Time: Tue Jul 15 20:24:17 EDT 2025
Powered by FUDForum. Page generated in 0.05265 seconds
