Home » Modeling » TMF (Xtext) » Workflow for GMF editor model
Workflow for GMF editor model [message #54066] Mon, 29 June 2009 16:43 Go to next message
Hopefully I'm posting to the correct group here.
I have created a GMF editor based on multiple linked ecore files and
my GMF editor creates a shared EMF-GMF editor domain in a single file.
I have set up an action to call a workflow from my GMF UI and it appears
to be configured correctly but doesn't actually produce anything. (ie
it's called from java using WorkFlowRunner().... The intention is to
call the workflow on my editor's model files which will be in their own
project directory.
As part of my testing I'm manually testing by running the workflow from
the project explorer (right click run as MWE). I have set up a runtime
config but when I run I get no errors and no output
this is my workflow is as follows (running on OS X 10.5.7)
<?xml version="1.0"?>
<workflow>
<property name="model"
value="platform:/resource/com.xx.yy.ui/templates/default2.ngoss " />
<!--basedir = /Users/steveorobec/DSL/eclipseRc4/workspace/Steve/. -->
<property name="out" value="out" />
<property name="workspace_loc" value="../." />
<!-- set up EMF for standalone execution -->
<bean class="org.eclipse.emf.mwe.utils.StandaloneSetup">
<platformUri value="../" />
<RegisterEcoreFile
value="${workspace_loc}/com.xx.yy.ui/model/contract.ecore"/ >
</bean>
<!-- load model and store it in slot 'model' -->
<component class="org.eclipse.emf.mwe.utils.Reader">
<uri value="${model}" />
<modelSlot value="model" />
<firstElementOnly value="false"/>
</component>
<!-- generate code -->
<component class="org.eclipse.xpand2.Generator" id="generate">
<metaModel id="mm"
class="org.eclipse.xtend.typesystem.emf.EmfRegistryMetaModel "/>
<expand value="templates::Demo::Main FOR model" />
<outlet path="${out}" />
</component>
</workflow>
My test xpt file is in com.xx.yy.ui/templates/Demo.xpt
I have put a copy of my model ecore files in com.xx.yy.ui/model/
and I have put a copy of the GMF editor model output in /templates
When I run the workflow it gets as far as and stops
Jun 29, 2009 9:28:26 PM org.eclipse.emf.mwe.core.WorkflowRunner prepare
INFO:
INFO: EMF Modeling Workflow Engine 0.7.0, Build v200906160748
INFO: (c) 2005-2009 openarchitectureware.org and contributors
INFO:
INFO: running workflow:
/Users/steveorobec/DSL/eclipseRc4/workspace/com.xx.yyy.ui/te mplates/ngossTransformWorkflow.mwe
INFO:
Jun 29, 2009 9:28:26 PM org.eclipse.emf.mwe.utils.StandaloneSetup
setPlatformUri
INFO: Registering platform uri '/Users/steveorobec/DSL/eclipseRc4/workspace'
Jun 29, 2009 9:28:27 PM org.eclipse.emf.mwe.utils.StandaloneSetup
addRegisterEcoreFile
INFO: Adding dynamic EPackage 'http://www.xx.com/2008/contract' from
'.././com.xx.yy.ui/model/contract.ecore'
I have the following in my manifest
Require-Bundle: org.eclipse.core.runtime,
org.eclipse.core.resources,
org.eclipse.ui,
org.eclipse.emf.codegen,
org.eclipse.ui.ide,
org.eclipse.emf.ecore.xmi;bundle-version="2.4.0",
org.eclipse.m2m.qvt.oml;bundle-version="1.0.0",
org.eclipse.emf.mwe.core;bundle-version="0.7.0",
org.eclipse.xpand;bundle-version="0.7.0",
org.eclipse.xpand.ui;bundle-version="0.7.0",
org.eclipse.xtend;bundle-version="0.7.0",
org.eclipse.xtend.typesystem.emf.ui;bundle-version="0.7.0",
org.eclipse.emf.mwe.utils;bundle-version="0.7.0"
I have looked at the OAW docs plus the Eclipse GMF book, tried various
combinations of the above but am stuck. Any idea what I'm doing wrong
please?
regards
Steve
Re: Workflow for GMF editor model [message #54251 is a reply to message #54066] Tue, 30 June 2009 12:04 Go to previous message
I've posted an update to the emft group as I suspect I should have tried
there instead
regards
Steve
Bill Hinge wrote:
> Hi
> project directory.
> <workflow>
> <RegisterEcoreFile
> </bean>
> </component>
> <metaModel id="mm"
> </component>
> </workflow>
> INFO:
> INFO:
> INFO:
> setPlatformUri
> org.eclipse.ui,
> org.eclipse.ui.ide,
> please?
> regards
> Steve
Previous Topic:Can I create GPL + DSL by XTEXT
Next Topic:Xtext from Modelling package issues
Current Time: Wed Jul 30 15:21:52 EDT 2025
Powered by FUDForum. Page generated in 0.02911 seconds
