Home » Eclipse Projects » Eclipse Platform » Caret updates incorrectly
Caret updates incorrectly [message #54042] Thu, 29 May 2003 11:30
Originally posted by: tim.duckdogmedia.com
I've been working on a plug-in for some time now, and I'm almost finished,
but I'm running into one quirky situation with the editor that I'm
creating. The problem is that when I replace text within the editor and
the text that I'm replacing exists on a line different than where the
caret resides, the caret shifts it's position if the replacement text
differs in length from the original text. In my editor I have certain
"headers" to delineate sections of text; i.e.
~~~A Testing Section~~~
test something
~~~An Adding Section~~~
add something
~~~A Delete Section~~~
delete something
...so in my case if I type something in one of the sections that doesn't
fit in that section, let's say I change the add to a delete in the Adding
Section, i.e.
test something
delete something
delete something
...then I need to change the header for the Adding Section; i.e.
test something
delete something
delete something
...all of that works except when I detect the change my caret would be
right after the word delete before I modified the header; i.e.
test something
delete<--Caret is right there! something
delete something
...as soon as I change the header the caret winds up shifting over the
number of characters different in the new header than in the old; i.e.
test something
delete <--Caret is now here! something
delete something
...if the new header has fewer characters then the caret shifts over to
the right, if more character shifts to the left.
Does anyone know how I can prevent this from happening?
Tim
Previous Topic:Printing line numbers
Next Topic:Problem with markers
Current Time: Thu Jul 17 21:39:25 EDT 2025
Powered by FUDForum. Page generated in 0.07332 seconds
