Home » Modeling » OCL » OCL Validator error.
OCL Validator error. [message #53939] |
Wed, 16 April 2008 07:07  |
The following Error obtained from my test cases:
Validator-ERROR in org.eclipse.emf.ecore.model; IfExp.qvto:1 : The
instance type name 'null' is not well formed
After debugging it (the info is not clear enough), the error is arisen
due to CollectionTypeImpl doesn't have an instance class established in
the same way as the remaining collections have.
Suggestions
1. In CollectionTypleImpl add the missing
setInstanceClass(java.util.Collection.class) to each constructor -> bugzilla
2. What about suggesting EMF to include more information reported by the
EClassifier::WellFormedInstanceTypeName constraint, such us including
the name of classifier ?
Adolfo.
Re: OCL Validator error. [message #53993 is a reply to message #53939] |
Wed, 16 April 2008 14:18   |
Hi, Adolfo,
Find some replies in-line, below.
Christian
> Suggestions
> bugzilla
The subclasses of CollectionTypeImpl set "concrete" instance classes. OCL
should never create instances of collection types, but only its concrete
subtypes. So, I don't expect that this would ever cause problems, but I
guess there's no harm in setting the instance class. Please, do raise an
enhancement request.
Well, I suppose, technically, the name would be redundant, as
double-clicking the problem marker will select the problem element in the
editor. However, it would be nice to see this information at a glance in
the Problems view. Sounds like a good enhancement request for EMF.
> Adolfo.
Re: OCL Validator error. [message #53998 is a reply to message #53993] |
Thu, 17 April 2008 06:00   |
Hi Christian,
Some in-lined comments below:
Christian W. Damus escribió:
> Hi, Adolfo,
> Cheers,
> Christian
>> Suggestions
>> bugzilla
I think that I don't follow you:
OCL Abstract Syntax allows CollectionTypes (it's not abstract in
OCL.ecore, and obviously in OCLEcore.ecore neither)
OCL Concrete Sytanx allows creating CollectionTypes via
CollectionLiteralExpCS (in EssentialOCL.g)
Why do you say that "OCL should never create instances of collection
types" ?
Anyway the EValidator complains for every CollectionType instance.
Setting the instance class for it could be an option.
Another one could be overwriting the WellFormedInstanceTypeName
constraint for CollectionType in the OCL EValidator.
Well my test cases throw errors in the console, so no chance for markers
So I'll ask in the EMF newsgroup.
Adolfo.
>> Regards,
>> Adolfo.
Re: OCL Validator error. [message #54007 is a reply to message #53998] |
Thu, 17 April 2008 09:27   |
Hi, Adolfo,
Section 8.2 of the OCL spec defines CollectionType as an abstract metatype.
However, this doesn't make sense, because it is clear from the concrete
syntax that it is possible to declare typed elements such as variables and
parameters as having type Collection(<some-type>). Moreover, there would
be no point in defining the Collection(T) data in the standard library if
CollectionType were abstract, because it could not exist. Therefore, MDT
OCL implements CollectionType as non-abstract (its abstractness is an error
in the spec).
What does make sense is the definition in section 11.6.1 of Collection(T) as
an abstract data type. Although the CollectionType metaclass is not
abstract, its instances (Collection data types) are. That is why I
indicated that the Collection type cannot be instantiated in OCL as Set,
Sequence, etc. can. However, this is also why that remark had no relevance
to your particular problem :-) Sorry for the confusion.
Christian
> Hi Christian,
>> Hi, Adolfo,
>> Cheers,
>> Christian
>>> Suggestions
>>> bugzilla
>> OCL should never create instances of collection types, but only its
>> concrete
> types" ?
> Cheers,
> Adolfo.
>>> Regards,
>>> Adolfo.
Re: OCL Validator error. [message #54017 is a reply to message #54007] |
Thu, 17 April 2008 10:33   |
Ok Christian,
Thank you for the aclaration...
However, I think it's very related with my problem, and probably with
something that it's not very clear...Let's see some personal conclusions
Firstly, what I understand from 11.6.1 is that the generic collection
data type is abstract (and it is base class for every collection type IN
the standard library => generic set/bag/sequence/orderedSet data types),
however I must not conclude that every instance of CollectionType
Metatype must be abstract as well. Therefore, having a Collection(Class)
for example could be understood as a valid collection data type. I don't
control OCL specification, and maybe another point could contradict this
afirmation.
Secondly, if you understand that every instance of the (MetaClass)
CollectionType has to be an "abstract" type (which would need any kind
of subtype as Set,Bag,etc), CollectionLiteralExps using the Collection
Keyword would not make any sense. and it should be an error this kind of
literal expressions: Collection {1 ,2 ,3 ,4 }, however:
1. Is not noticed in the CST construction.
2. Is not noticed in the AST construction.
3. I don't know if there is any extra kind of later validation which
could notice it and I'm missing it. But what I'm sure is that my parser
which extends OCL CST and AST construction, and now EValidator, allows
me to create this kind of literal expressions.
BTW: What do you think about an "abstract" data type, it sounds horrible
ahahahaha ;P
What do you think about these conclusions ?
Adolfo.
> Hi, Adolfo,
> in the spec).
> Cheers,
> Christian
>> Hi Christian,
>>> Hi, Adolfo,
>>> Cheers,
>>> Christian
>>>> Suggestions
>>>> bugzilla
>>> concrete
>> types" ?
>> Cheers,
>> Adolfo.
>>>> Regards,
>>>> Adolfo.
Re: OCL Validator error. [message #54027 is a reply to message #54017] |
Thu, 17 April 2008 10:57   |
OMG !!!!!!
No errors showed in the console during in the parsing, but an exception
was thrown while persisting the output model !!!
java.lang.IllegalArgumentException: The value 'Collection' is not a
valid enumerator of 'CollectionKind'
org.eclipse.gmt.umlx.qvt.EssentialOCL.impl.EssentialOCLFacto ryImpl.createCollectionKindFromString(EssentialOCLFactoryImp l.java:507)
Definitely, it seems that Collection should not be used for
CollectionLiteralExps, and something is going wrong... If "Collection"
doesn't feel well to CollectionLiteralExp, probably the we should have
control in somewhere....
And looking into the metamodel again, I think that I finally have
discovered where is controlled... no_collection_instances is the clue,
isn't it ? :D
Well, I think that is sufficient for today...I don't want you to waste
your time more ;P
My unique doubt after all is if there is a part in the specification
which says that no collection data types may be used (I think that the
statement in the 11.6.1 is not sufficient)...Anyway, I'll try to
discover it in the OCL spec.
Cheers !!!
Adolfo.
Adolfo Sánchez-Barbudo Herrera escribió:
> Ok Christian,
> afirmation.
> ahahahaha ;P
> Cheers,
> Adolfo.
>> Hi, Adolfo,
>> metatype. However, this doesn't make sense, because it is clear from
>> the concrete
>> and
>> error
>> in the spec).
>> Collection(T) as
>> relevance
>> Cheers,
>> Christian
>>> Hi Christian,
>>>> Hi, Adolfo,
>>>> Cheers,
>>>> Christian
>>>>> established in
>>>>> Suggestions
>>>>> bugzilla
>>>> classes. OCL should never create instances of collection types, but
>>>> only its
>>>> concrete
>>>> but I
>>>> raise an
>>> types" ?
>>>>> by the
>>>> in the
>>>> glance in
>>> Cheers,
>>> Adolfo.
>>>>> Regards,
>>>>> Adolfo.
Re: OCL Validator error. [message #54036 is a reply to message #54027] |
Thu, 17 April 2008 11:23   |
Hi, Adolfo,
Are you taking the Object Management Group's name in vain? ;-)
On a more serious note: the discussion of the collection types in section
11.6 makes it clear that the standard library type Collection(T) is a
template, as are its subtype Set(T), Sequence(T), and Bag(T) (OrderedSet(T)
is a subtype of Set(T)). Thus, there is one template definition of
Collection(T) and it is abstract. Bindings of the template for different
substitutions of T do not change its abstractness.
Probably, the parser should be more friendly in the validation of
Collection{...} literals, not leaving it to some back-end validation step
to complain about them. Yes, no_collection_instances is important for
validation of AST generated not from text, but the parser could also check
this.
Christian
> OMG !!!!!!
> at
> isn't it ? :D
> your time more ;P
> Cheers !!!
> Adolfo.
>> Ok Christian,
>> afirmation.
>> ahahahaha ;P
>> Cheers,
>> Adolfo.
-----8<-----
Re: OCL Validator error. [message #54055 is a reply to message #54036] |
Thu, 17 April 2008 11:58  |
Hi Christian,
More comments
> Hi, Adolfo,
Hahahahahaha... I'll have to start to use a new variant in Eclipse
newsgroup!!!! ... What about OhMG xD
Definitely the types, metatypes, datatypes, their bindings, and the
family of all of them have overcome me today. I need a deep thought
about this, but It won't surely now.... ¬¬!!
Besides, in QVTo we have a far parent of them: TemplateParameterType...
I'm so lucky :D :D :D ..... ¬¬!!.... Fortunately I'm seeing the light at
the end of tunnel :)
> this.
I see...Well the important is that is checked in somewhere... And I have
find out that I have missed some validation in my parsing process. I
just need to look into how to integrate it ...
About the creation of Collection(Something) in the output models... who
knows... We will see here (newsgroup) with new conclusions ;)....
Fortunately we have its "brother" A.K.A Java which will surely help me
with them ;P.
Adolfo.
> Cheers,
> Christian
>> OMG !!!!!!
>> at
>> isn't it ? :D
>> your time more ;P
>> Cheers !!!
>> Adolfo.
>>> Ok Christian,
>>> afirmation.
>>> ahahahaha ;P
>>> Cheers,
>>> Adolfo.
> -----8<-----
Current Time: Wed Jul 30 15:26:21 EDT 2025
Powered by FUDForum. Page generated in 0.05892 seconds
