Home » Modeling » GMF (Graphical Modeling Framework) » TargetMetaFeature
TargetMetaFeature [message #53936] Fri, 22 September 2006 09:38 Go to next message
Originally posted by: matthias.thiel.atip.de
I'm trying to generate a plugin (or the source code of it) from an XSD file
by using the tutorial.
I generated the gmftool, gmfgraph, gmfmap and gmfgen files, but the
eclipse environment tells me that the targetMetaFeature in the gmfgen file
is missing (in links->modelFacet).
I would like to add it, but currently I have no understanding of the
gmfgen file and what a targetMetaFeature is, so I want to ask, if anyone
could explain it or if there is a documentation about the semantic of
these XML tags ?
Thanks in advance,
Matthias Thiel
Re: TargetMetaFeature [message #54058 is a reply to message #53936] Fri, 22 September 2006 10:34 Go to previous messageGo to next message
There's no need to modify .gmfgen, the problem should be in the .gmfmap's
LinkMapping. Check that appropriate LinkMapping (you can tell this by domain
element) specifies correct Link Meta Feature ("Target Feature") - the one
that is set when the link gets its target.
Artem
"Matthias Thiel" <matthias.thiel@atip.de> wrote in message
news:bf0cdade34398db5d9a4b6bab8445d80$1@www.eclipse.org...
> Hello,
> file
> these XML tags ?
> Thanks in advance,
> Matthias Thiel
Re: TargetMetaFeature [message #54123 is a reply to message #54058] Fri, 22 September 2006 11:07 Go to previous messageGo to next message
Thank you for the fast answer.
I could resolve this problem, but now I get InvocationTargetExceptions
when trying to generate the diagram code:
!SUBENTRY 1 org.eclipse.gmf.common 4 0 2006-09-22 17:00:16.503
!MESSAGE InvocationTargetException
!STACK 0
org.eclipse.emf.codegen.jet.JETException: InvocationTargetException
org.eclipse.emf.codegen.jet.JETEmitter.generate(JETEmitter.j ava:394)
org.eclipse.emf.codegen.jet.JETEmitter.generate(JETEmitter.j ava:367)
org.eclipse.gmf.internal.common.codegen.JETEmitterAdapter.ge nerate(JETEmitterAdapter.java:35)
org.eclipse.gmf.internal.common.codegen.GeneratorBase.doGene rateJavaClass(GeneratorBase.java:325)
org.eclipse.gmf.codegen.util.Generator.internalGenerateJavaC lass(Generator.java:940)
org.eclipse.gmf.codegen.util.Generator.generateNodeGraphical NodeEditP
olicy(Generator.java:463)
org.eclipse.gmf.codegen.util.Generator.generateNode(Generato r.java:231)
org.eclipse.gmf.codegen.util.Generator.customRun(Generator.j ava:116)
org.eclipse.gmf.internal.common.codegen.GeneratorBase.doRun( GeneratorBase.java:408)
org.eclipse.gmf.internal.common.codegen.GeneratorBase.run(Ge neratorBase.java:69)
org.eclipse.gmf.internal.codegen.popup.actions.ExecuteTempla tesAction.run(ExecuteTemplatesAction.java:120)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:113)
Caused by: java.lang.reflect.InvocationTargetException
at sun.reflect.GeneratedMethodAccessor67.invoke(Unknown Source)
org.eclipse.emf.codegen.jet.JETEmitter.generate(JETEmitter.j ava:386)
... 11 more
Caused by: java.lang.NullPointerException
org.eclipse.gmf.codegen.templates.policies.NodeGraphicalNode EditPolicyGenerator.generate(NodeGraphicalNodeEditPolicyGene rator.java:89)
... 15 more
Do you have an idea ?
regards,
Matthias
> domain element) specifies correct Link Meta Feature ("Target Feature") -
> the one that is set when the link gets its target.
> Artem
>> Hello,
>> file
>> file is missing (in links->modelFacet).
>> these XML tags ?
>> Thanks in advance,
>> Matthias Thiel
Re: TargetMetaFeature [message #54278 is a reply to message #54123] Fri, 22 September 2006 12:31 Go to previous message
There's smth wrong with one of GenNodes, I suppose. Perhaps, missing or
incomplete ModelFacet. This should not happen if validation for your models
says OK.
Artem
news:ef0u7j$srm$1@utils.eclipse.org...
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 11 more
> at
> ... 15 more
> regards,
> Matthias
>> Artem
>>> Hello,
>>> file
>>> these XML tags ?
>>> Thanks in advance,
>>> Matthias Thiel
Previous Topic:Associate Label with a Link
Next Topic:mindmap won't run
Current Time: Mon Jul 07 11:42:08 EDT 2025
Powered by FUDForum. Page generated in 0.07466 seconds
