Re: [Teneo] Lazy Properties, Instrumentation, Teneo+Hibernate [message #535014 is a reply to message #534994] |
Fri, 21 May 2010 04:55 |
Martin Taal Messages: 5468 Registered: July 2009 |
Hi Lemao,
You are the first in 4-5 years of Teneo existence to try this I am afraid... I have no experience with it myself. I
guess what happens is that also the generated EPackageImpl got instrumented. I checked the hibernate manual and it seems
that you can specify which classes to instrument. So you could skip the generated EPackageImpl in the instrumentation
task I guess.
btw, if you are using EMF on the server side (in a webapp for example) then you can consider also using the Texo
project. The Texo project generates code which is pure java (so no compile time dependencies) and is much easier to use
in combination with ORM's like Hibernate or EclipseLink. The Texo project also supports generating the orm.xml directly
from an ecore model or xsd. In addition it supports XML/XMI serialization (making use of EMF's capabilities) and a
runtime model (the EPackage).
See here for more information:
http://wiki.eclipse.org/Texo
gr. Martin
Lemao wrote:
> Posting it again... since I forgot to add [teneo] to the subject...
> I am trying to get lazy properties to work with Teneo, but got stuck at
> this exception trying to start my app:
> java.lang.NoSuchMethodError:
> com.me.MyPackageImpl.$javassist_read_ecorePackage()Lorg/ecli
> pse/emf/ecore/EcorePackage;
> at com.me.MyPackageImpl.initializePackageContents(SubmissionTyp
> ePackageImpl.java:645)
> I am running the InstrumentTask against my classes as described in the
> docs.
> Are there any known issues with Hibernate instrumented classes and
> Teneo/EMF? Any ideas of what could have been gone wrong?
> thanks,
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Lazy Properties, Instrumentation, Teneo+Hibernate [message #535187 is a reply to message #535176] |
Fri, 21 May 2010 13:52 |
Hi Lemao,
Hmm, I can really say if Teneo does something related to this NPE. You should debug into the extractFieldInterceptor to
see why it returns null (looking at the source code it can do that).
Regarding Texo, yes please take a look, I am interested in getting feedback on this project.
Regarding notifiers/adapters, I am considering making it possible to generate adapters/notifiers also for Texo but I am
not yet sure if that's possible for list/set associations without creating custom list/set implementations (which I
would like to avoid as it really complicates integration with other frameworks).
There is a bugzilla for this also:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=313493
I am now working on supporting jaxb model annotations. After that I will revisit the adapter/notifier topic (gives me
also some extra days of thinking about it).
gr. Martin
Lemao wrote:
> Hi Martin,
> Thanks for the answer. It was indeed the problem. I tightened the file
> filter a bit and am only instrumenting the *Impl files except the
> factory/package ones. That got me past the exception.
> I then got into another one which seems more Hibernate related (could
> emf/teneo have any impact? not sure). I basically get an NPE in
> EntityEntry.requiresDirtyCheck() in
> FieldInterceptorHelper.extractFieldInterceptor(entity).isDir ty() when
> flushing:
> public boolean requiresDirtyCheck(Object entity) {
> boolean isMutableInstance = status !=
> Status.READ_ONLY && persister.isMutable();
> return isMutableInstance && (
> getPersister().hasMutableProperties() ||
> !FieldInterceptionHelper.isInstrumented( entity ) ||
> FieldInterceptionHelper.extractFieldInterceptor(
> entity).isDirty()
> The Texo project looks interesting. My understanding is that it takes
> the same EMF models but generates its own Java representation, right?
> Also read that adapters/notifications are not generated/supported. This
> could be show stopper for us. I will take a closer look.
> Once again, thanks for your help.
The Netherlands
FUDForum. Page generated in 0.03435 seconds
