Home » Archived » XML Schema Definition (XSD) » Fetching xml.xsd from the cache
Fetching xml.xsd from the cache [message #53930] Thu, 07 October 2004 05:24 Go to next message
I've seen that the file http://www.w3.org/2001/03/xml.xsd is contained in
the cache of XSD. But when I load a file containing the following import
statement:
<xsd:import namespace="http://www.w3.org/XML/1998/namespace"
schemaLocation="http://www.w3.org/2001/03/xml.xsd"/>
XSD doesn't try to get the schema from the cache but from the internet.
But the Schema for Schema is fetched from the cache. How do I tell XSD to
load xml.xsd from the cache and not from the internet?
Cheers
Klaas
Re: Fetching xml.xsd from the cache [message #53944 is a reply to message #53930] Thu, 07 October 2004 07:03 Go to previous message
--------------040803000906020108030401
Klaas,
The global resource set that loads the schema for schemas is initialized
like this:
public static synchronized ResourceSet getGlobalResourceSet()
if (globalResourceSet == null)
globalResourceSet = createResourceSet();
String baseURL = XSDPlugin.INSTANCE.getBaseURL().toString();
globalResourceSet.getURIConverter().getURIMap().put
(URI.createURI("http://www.w3.org/2001/xml.xsd"),
URI.createURI(baseURL + "cache/www.w3.org/2001/xml.xsd"));
return globalResourceSet;
It takes advantage of the URI converter's URI map to redirect the
physical location of a URI to another physical location. You can do the
same thing in the resource set you create.
Klaas Dellschaft wrote:
>Hi,
>statement:
>Cheers
>Klaas
<html>
<head>
http-equiv="Content-Type">
<title></title>
</head>
Klaas,<br>
<br>
initialized like this:<br>
<blockquote><big><tt><small>
Re: Fetching xml.xsd from the cache [message #592057 is a reply to message #53930] Thu, 07 October 2004 07:03 Go to previous message
Klaas,
like this:
>Hi,
>statement:
>Cheers
>Klaas
<html>
<head>
<title></title>
</head>
Klaas,<br>
<br>
Previous Topic:Fetching xml.xsd from the cache
Next Topic:How to load Include/Redefine/Import Namespaces?
Current Time: Tue Jul 22 01:38:37 EDT 2025
Powered by FUDForum. Page generated in 0.07713 seconds
