Re: BIRT Chart not showing up correctly in PDF [message #534920 is a reply to message #534811] |
Thu, 20 May 2010 15:58 |
If you are using the viewer add &__pageoverflow=2 to the url. This
should size the image to fit. If you are using the api use
PDFRenderOption pdfOptions = new PDFRenderOption( options );
pdfOptions.setOption(IPDFRenderOption.PAGE_OVERFLOW,
IPDFRenderOption.FIT_TO_PAGE_SIZE);
When setting the render options for the render task.
Jason
On 5/20/2010 8:23 AM, Yassir Bouizi wrote:
> BIRT Chart not showing up correctly in PDF format cause the chart is to
> large.
> For example when pie chart use optional grouping and size of chart is
> computed according to the number of groups. What I can do to resolve
> this probleme.Thanks beforehand.
> yassir.
FUDForum. Page generated in 0.02210 seconds
