Home » Archived » XML Schema Definition (XSD) » Getting fresh Integration builds as soon as possible (was Re: EMF build process)
Getting fresh Integration builds as soon as possible (was Re: EMF build process) [message #53909] Tue, 05 October 2004 14:34
Originally posted by: codeslave.ca.ibm.com
Also, don't forget that you can set Eclipse to watch for updates
automatically and download/install them for you. As Integration builds
appear on the website, so will new UM builds be available which you can
watch for with no effort at all.
If using Eclipse 3.0.1 or 3.1.0, open Window > Preferences then select
Install Update > Automatic Updates, and set a schedule for cyclic checks.
To be honest, I'm not sure if this actually works with 4th-part builds
(such as 2.1.0.I200410061234), but it will at least notify you once the
next release build is available (2.1.0).
Thus, if Automatic Updates doesn't work for 4th-part builds, you can
always point your RSS reader (or just your browser) at:
http://download.eclipse.org/tools/emf/updates/site.xml
and check manually to see if a new build is listed.
(oh... and note that in order for site.xml to be compliant with Eclipse
UM, it's not really RSS... but it is well-formed XML. So, caveat emptor.)
Nick Boldt
Ed Merks wrote:
> Jaap,
> Sorry. We've typically been providing weekly integration drivers,
> usually by Thursday mornings, but with the 2.0.1 release done and
> Marcelo away on holidays, we've been kind of slack. We'll make a 2.1
> build available this week.
> Jaap Reitsma wrote:
>> In the Eclipse FAQ I found a section on the Eclipse SDK build process,
>> stating integration builds are performed on Tuesdays etc.
>> I couldn't find an equivalent statement on the EMF build process. Is
>> it the
>> same as the SDK? I didn't see any (downloadable) integration builds yet.
>> Can somebody explain to me what to expect or give me a pointer? I
>> would like
>> to take advantage of the quick bugfix efforts of the EMF team.
>> Preferably by
>> downloading a stable or integration build as I am not familiar with
>> building
>> the plugins myself.
>> Kind regards,
>> Jaap
Previous Topic:Thanks for submitting! (was Re: EMF Corner launched)
Next Topic:Getting fresh Integration builds as soon as possible (was Re: EMF build process)
Current Time: Sat Jul 26 00:03:23 EDT 2025
Powered by FUDForum. Page generated in 0.03179 seconds
