Home » Language IDEs » Java Development Tools (JDT) » Method call hierarchy feature in M1
Method call hierarchy feature in M1 [message #53906] Tue, 10 June 2003 16:12 Go to next message
I have just installed 3.0 M1 and I would like to commend you guys for the
excellent enhancements in JDT. I would like to make a comment about "Method
call hierarchy" hoping that this is the appropriate venue. If not, please
redirect me.
I am not an usability expert but as a user I think that there is very
limited benefit of "Location" and "Call" fields having such prominent real
estate. It is good that they can be turned off to reduce clutter. How about
moving all other additional metadata into a hover box?
Also, it would be nice to have a feature similar to "Link with Editor" so
that while code browsing "Method call hierarchy" can be updated as well.
Best regards.
Re: Method call hierarchy feature in M1 [message #53927 is a reply to message #53906] Tue, 10 June 2003 16:55 Go to previous messageGo to next message
That call/location is being used to jump to multiply calls in one method.
It is not just information.
What is more annoying of the current implementation is , is that double click
on the method in the tree, doesn't jump to the first location in the method
where that is found. I have to do it through the popup menu (then open)
or double click on that table (Location/Call)
i will make a bug report for that.
johan
"Vladimir Blagojevic" <vladimir@cs.yorku.ca> wrote in message news:bc5e28$9ff$1@rogue.oti.com...
> redirect me.
> Best regards.
Re: Method call hierarchy feature in M1 [message #53994 is a reply to message #53906] Tue, 10 June 2003 17:19 Go to previous messageGo to next message
Originally posted by: adam.kiezun.gmx.net.remove
this is the correct forum
please enter all bug reports to our bugzilla - call hierarchy lives in JDT UI
cheers
a.
eclipse.org
Re: Method call hierarchy feature in M1 [message #55330 is a reply to message #53906] Thu, 12 June 2003 10:37 Go to previous messageGo to next message
turn them off by using the view menu and selecting 'hierarchy view only'
a.
Re: Method call hierarchy feature in M1 [message #55463 is a reply to message #53927] Thu, 12 June 2003 12:14 Go to previous messageGo to next message
"> What is more annoying of the current implementation is , is that double
click
method
Did you notice that it jumps to location if that file is curently open in
the editor area? I agree with you - it is a weird deafult behaviour.
But do you agree with me that having line number and the name of the method
repeated in Location/Call is fairly useless? There must be a better way to
do this.
Re: Method call hierarchy feature in M1 [message #56546 is a reply to message #55463] Fri, 13 June 2003 11:03 Go to previous messageGo to next message
Originally posted by: linnet.nospam.users.sourceforge.net
> click
> method
> do this.
Hi Vladimir,
I'm the developer of the call hierarchy view, so I guess that I'm biased
:-) Anyhow, I'd like to comment.
I don't agree that it's useless. The location part of the view presents
the actual call including the actual parameters used. If your method
doesn't take any parameters, I agree. If you only have one call to a
method, I agree (although it allows you to see the actual details of the
call).
Jesper
Re: Method call hierarchy feature in M1 [message #56684 is a reply to message #56546] Fri, 13 June 2003 13:35 Go to previous messageGo to next message
Hi Jesper,
No doubt that your work is appreciated. The feature is good, serves a
purpose most of the time, all I am saying is "let's make it better".
Use case:
Suppose that a user invoked Method call hierarchy (MCH) on method A. As
currently implemented a tree of method calls that invoke A in selected scope
is presented. Currently there is no option to select a scope. User should
maybe have an optional scope selection - as in search. Not a priority I
guess.
The details of the features I have in mind.
Feature 1:
Improve the the present functionality by introducing one click on the method
element B in MCH tree. One click takes a user to a specified file location
in java editor. File is opened, if necessary, and specified location (call
to A) is highlighted. If multiple calls are made to A from the selected MCH
tree element B, those calls are somehow indicated as well (highlighting,
arrows pointers from left margin etc)
Feature 2:
Introduce hover. Ctrl + mouse over tree element B (that calls A) shows a
source hover for that method B with indication of call(s) made to A. So
basically replicate feature 1 in a different form i.e. java source hover.
Java source hover as currently implemented in JDT might not be suitable
since the current implementation shows only n first lines of selected
element. The better solution might be presenting source of B in a hover
with a scrollable window - similar to F2 - "make hover sticky" feature of
JDT. Anyhow, the goal is to show the source of B and indicate the context of
each call made to A.
By introducing feature 1 and 2 you eliminate the need for the separate
"Location/Call" panel. Functionality is greatly improved , clutter is
reduced and consistency is kept along with features that user is already
familiar with in JDT.
Any opinions?
Best regrads.
Re: Method call hierarchy feature in M1 [message #56820 is a reply to message #56684] Fri, 13 June 2003 14:39 Go to previous messageGo to next message
> Hi Jesper,
I couldn't agree more on the "make it better" idea :-)
> Use case:
> guess.
What do you mean by scope in this context? It's possible to set the
limit the search scope on the view menu. Do you have something else in mind?
> Feature 1:
> Feature 2:
> Any opinions?
I see your point in presenting the same information in another way. I
have taken the liberty of creating a bug report
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=38904) on this matter.
> Best regrads.
Jesper
Re: Method call hierarchy feature in M1 [message #56900 is a reply to message #56820] Fri, 13 June 2003 15:13 Go to previous messageGo to next message
Hi Jesper,
scope
should
> > guess.
mind?
For example: select java method in editor source file. Right click to get
context menu.
The options in the same group along with "Open Call Hierarchy" are "Open
Declaration", "Open Type Hierarchy" etc. Now newly added in M1 is "Open Call
Hierarchy". All I am saying is that "Open Call Hierarchy" and probably "Open
Type Hierarchy" options should be scoped ii.e for these two options add
another scope menu slideout that scopes the search to:
Working Set and Workspace etc.
Think, or even better try doing "Open Call Hierarchy" on toString() method
or "Open Type hieararchy " on Iterator. The point is - it gets messy lol :)
You really need scope IMHO. I want to see where toString() method is called
in Working Set.
Cool, lets see what happens. BTW you don't seem to be employed by IBM/OTI.
You have right priviledges in eclipse cvs? Does some project leader from
IBM/OTI have to approve this "enhacement" ?
Best regards.
Re: Method call hierarchy feature in M1 [message #56953 is a reply to message #56900] Fri, 13 June 2003 15:25 Go to previous messageGo to next message
i'm Jesper's 'buddy' on the eclipse.org side (the guy who releases Jesper's code to cvs :))
yes, we look at the enhancements and decide if that's the right direction
but it's very good to experiment with different approaches - if anything, it's very easy to revert, right?
cheers
a.
eclipse.org
Re: Method call hierarchy feature in M1 [message #57031 is a reply to message #56900] Fri, 13 June 2003 15:53 Go to previous messageGo to next message
Hi Vladimir,
> Hi Jesper,
> scope
> should
>>>guess.
> mind?
> context menu.
> in Working Set.
Ok, I see your point (toString() is a good candidate for
OutOfMemoryExceptions :-) ). The way the call hierarchy works now is
more static - the search scope is related to the view and not to the
current use of the action (the type hierarchy doesn't have a search
scope yet, but AFAIK it's in the JDT UI plan).
I don't know if it would be a good idea to add search scope to the
context menu. If the menu item is changed there should at least be a
way to use the currently set search scope). The keyboard shortcut should
at least be kept as it is.
Again, I may be biased, but that's the way I use it (and the way
whomever I have pursuaded to use the thing use it :-) ).
Jesper
No, I'm just a contributor kept on a short leash by my master :-) No
offense meant, Adam :-)
> Best regards.
Jesper
Re: Method call hierarchy feature in M1 [message #57108 is a reply to message #57031] Fri, 13 June 2003 17:08 Go to previous messageGo to next message
none taken :-)
a.
eclipse.org
Re: Method call hierarchy feature in M1 [message #57471 is a reply to message #56684] Sat, 14 June 2003 09:15 Go to previous messageGo to next message
news:bcd21p$o92$1@rogue.oti.com...
> Feature 2:
Careful -- control+mouse is typically a "drag copy" operation in a tree
widget -- this would be inconsistent behavior. (I'm not sure what "drag
copy" would mean in this view, but that's the normal meaning of it for many
other tree views...)
-- Scott
Re: Method call hierarchy feature in M1 [message #57496 is a reply to message #57471] Sat, 14 June 2003 10:15 Go to previous messageGo to next message
But it is not Ctrl+mouse click but Ctrl+mouse over. I dont thnk that has any
default operation over tree structures- at least not in Microsoft Lookout I
am using to read these newsposts :)
many
Re: Method call hierarchy feature in M1 [message #57597 is a reply to message #57496] Sat, 14 June 2003 16:08 Go to previous message
Yes, but control-mouse-over is a prelude to a control-mouse-click, so it
could be confusing...
-- Scott
news:bcfald$jn$1@rogue.oti.com...
any
I
a
> many
Previous Topic:Allocate memory to application
Next Topic:-> Plugin referrences Project
Current Time: Mon Jul 21 21:37:34 EDT 2025
Powered by FUDForum. Page generated in 0.25872 seconds
