Home » Language IDEs » AspectJ » AJDT development build with updated AspectJ
AJDT development build with updated AspectJ [message #53894] Wed, 22 June 2005 10:30
Originally posted by: mchapman.uk.ibm.com
The build ID is 1.2.1.20050622133424 and builds are available for both
Eclipse 3.0 and 3.1RC2/RC3. There is also a new AJDT download page here:
http://www.eclipse.org/ajdt/downloads/
This uses PHP to automatically show the latest AJDT development builds,
which are now automatically uploaded after every successful build.
Compared with the AspectJ build in AJDT 1.2, the following fixes have been
made:
59636 -log option not producing output - should it?
81846 EclipseAdapterUtils.java:83
83565 BCException "bad type name" thrown when compiling
83630 @AJ sybtax
83807 @AJ around inlining
84260 import static fails when importing a method
84421 Problem with generics in ITDs
86452 compiler cannot compile class with @AfterReturning
86832 Internal compiler error (generics?)
87282 Compilation error on generic member introduction
88606 Parameterized types on introduced fields not correctly re...
90388 BCException incremental change from broken parent to List
90827 StackOverflow while weaving enum/annotation with Enum/Ann...
91053 Generics problem with Set - does not compile with AspectJ 5
91267 NPE at EclipseFactory.java:143 when using generic methods...
91719 Work with Oli B to pull in examples of generating all the...
92334 Exception on rename of aspect type if used in enclosed po...
92906 showWeaveInfo for declare annotations
93345 unresolved joinpoint in cflow causes ClassCastException o...
93460 developer's notebook, chapter 8
94167 NPE in reflect implementation
94243 AJC compiled @AJ aspect + LTW - issue with -Xreweavable /...
95525 @AJ deow
95993 [generics] NPE at ClassScope.java:660 when compiling gene...
96111 privileged access to private generic fields crash ajc
96371 Patch to support loading aop.xml properly
97084 Error in last AJDT for 3.1M6: another project's output in...
97144 ClassCastException at BcelWeaver.java:933
97408 build script generates a corrupted loadtime5.jar
97763 ITD method with generic arg - BCException thrown: Bad typ...
98320 [generics][itds] intertype with nested generic type
98660 ClassCastException compiling aspect with cflow && handler
99089 [generics][itds] ArrayIndexOutOfBoundsException - Generic...
99168 [generics][itds] ITD on generic inner class crashes ajc
99228 [generics][itds] ITD of a field into a generic class
100227 [generics][itds] inner class with generic enclosing class
100260 [generics][itds] methods inherited from a generic parent
Matt.
Matt Chapman
AJDT Development, http://www.eclipse.org/ajdt
Previous Topic:changing method instance variables.
Next Topic:AJDT development build with updated AspectJ
Current Time: Sun Jul 27 06:12:50 EDT 2025
Powered by FUDForum. Page generated in 0.03182 seconds
